Old 12-11-2013, 01:16 PM   #1
jaymannj
jaymannj's Avatar
Drives: 2013 silver BRZ
Passanger window problems
Will not open or close with driver door control but will work with passanger side control... Wierd
jaymannj is offline   Reply With Quote
Old 12-11-2013, 01:28 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
Reset it. Hold down passenger control for about 5 secs then close the window and hold it on up for about 5 secs
Old 12-11-2013, 01:29 PM   #3
Boom
(Jo_o)J
Boom's Avatar
Drives: 2013 Raven FR-S
were the lights on the button flashing? She did that to me the other day cuz I tried to roll down the window when it was frozen. Started working again once it all melted...
I like the tuna here
Boom is offline   Reply With Quote
Old 12-11-2013, 01:30 PM   #4
jaymannj
jaymannj's Avatar
No flash whatsoever and its only driver side control thats not working for opening it...passanger side switch works tho
Old 12-11-2013, 01:43 PM   #5
AznBRZer
Drives: 16 CBS WRX Limited
Gee whiz...another thread? I'm about to make a thread so everyone can hassle the mods to make it a permanent sticky.
The car needs to be on ACC 2 mode in order to reset the windows.
AznBRZer is offline   Reply With Quote
Old 12-11-2013, 03:22 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
Hmm I just did it this morning with my engine on.
Old 12-11-2013, 10:19 PM   #7
AznBRZer
Hmmm...must be different on the a/t? It didn't work when my engine was on.
Old 12-11-2013, 11:02 PM   #8
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Works fine for me with the engine on too on the M/T.
OP, it's because your windows iced up and couldn't move, so they won't work on the drivers side control panel or when the door is open, and the lights on the driver side door should slowly flash.
Just roll down the window using the passenger controls, keep holding it until it gets to the bottom, hold for 5 more seconds, roll it up while holding it, and let then hold for 5 seconds. That should reset it.
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 12-11-2013, 11:20 PM   #9
humfrz
Oh.......my......
Maybe we should just go back to the cranks ..... they always worked .....
humfrz
Old 12-13-2013, 11:46 AM   #10
milenko11
Drives: no
I literally had the same thing two days ago. I just did the reset and it's working again.
milenko11 is offline   Reply With Quote
Old 12-14-2013, 08:10 AM   #11
tasinene
Drives: 2013 Scion FRS Asphalt
I dropped mine off this morning for some routine maintenance and noticed the same thing on my way there. Light was flashing, passenger side wouldn't go down with driver control. They'll probable reset it since I mentioned it. Glad to know it's not an electrical issue.
tasinene is offline   Reply With Quote
Old 12-14-2013, 11:23 AM   #12
Danny86
Danny86's Avatar
Drives: 2013 Scion FRS Raven Black M/T
If you read the owners manual it says how to reset it. What it is, is its a safety precaution. The car thinks there is something jamming the window so that's when it stops moving (blinking light) then to reset you just put the car in the "on" position and hold the button of the affected window up for a few seconds until it completely closes and stops flashing. This happened to me the other day it took a couple of tries to get it right but it works.
Sent from my SCH-I545 using Tapatalk
Danny86 is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
Gas Problems Kelbyat07 Issues | Warranty | Recalls / TSB 3 04-20-2013 09:21 PM
An unexpected passanger on my way home. Mr Franky Scion FR-S / Toyota 86 GT86 General Forum 22 12-29-2012 10:47 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
