Old 09-14-2016, 02:41 AM   #1
j0307
j0307's Avatar
Drives: 2015 Subaru BRZ Series.Blue
Someone please tell me what this guy is running
I have a series.blue and I am in love with how this looks, if anyone recognizes it or knows what he has please tell me. I want it.
j0307 is offline   Reply With Quote
Old 09-14-2016, 02:52 AM   #2
EddieBRZ
Drives: Subaru BRZ S
If I'm not mistaken, it's the same rims as mine. It comes with the car in Australia if you get the BRZ S model.
They are Sti Enkei rims 15 spoke 17x7.5+48.
EddieBRZ is offline   Reply With Quote
The Following User Says Thank You to EddieBRZ For This Useful Post:
ERIC86 (09-14-2016)
Old 09-14-2016, 02:53 AM   #3
j0307
j0307's Avatar
Sorry, to clarify I want to know the suspension setup he has, like spacers, amount of drop, etc.
Old 09-14-2016, 07:33 AM   #4
Jmk91
Drives: 2017 Brz Performance Package
Well I'd assume he's running coilovers over the amount of drop. It looks good but hit a few pot holes/enter a few drive ways and or attempt to go over a speed bump... Let me know how the outcome is.
Jmk91 is offline   Reply With Quote
Old 09-14-2016, 08:23 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
I like low but that is beyond daily functionality low.
jasonojordan is offline   Reply With Quote
Old 09-14-2016, 08:27 AM   #6
Teseo
Drives: frs
Wheels can be Enkei rs05rr, maybe xxr 550?
The Following 2 Users Say Thank You to Teseo For This Useful Post:
ERIC86 (09-14-2016), j0307 (09-14-2016)
Old 09-14-2016, 08:31 AM   #7
EddieBRZ
He's not after the rims, just the set up.
I don't think it's running spacers because it clears by a fair bit. Most likely a drop of like 8-9cm. Stock height is roughly 13cm. Plus he has the sti side skirts.
j0307 (09-14-2016)
Old 09-14-2016, 08:38 AM   #8
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
He's running into trouble going over bumps, dips, driveways etc. unless he's on an airbag setup and that photo was just taken when parked. i really hope that he doesn't drive around like that.
shiumai is offline   Reply With Quote
The Following 3 Users Say Thank You to shiumai For This Useful Post:
churchx (09-14-2016), j0307 (09-14-2016), MarkR171 (09-14-2016)
Old 09-14-2016, 09:31 AM   #9
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Probably airbags, because if that's a static suspension, he isn't "running" anywhere.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
The Following 4 Users Say Thank You to MarkR171 For This Useful Post:
churchx (09-14-2016), gramicci101 (09-14-2016), j0307 (09-14-2016), kch (09-14-2016)
Old 09-14-2016, 12:35 PM   #10
kch
Senior Misanthrope
kch's Avatar
Definitely airbags. Can't tell if he has spacers, but if he does, they're no more than 15mm.
The Following 2 Users Say Thank You to kch For This Useful Post:
j0307 (09-14-2016), Toyarzee (09-14-2016)
Old 09-14-2016, 03:10 PM   #11
MarkR171
MarkR171's Avatar
Drives: '05 Elise
As much as the tire/wheel is tucking into the quarter panel, I doubt there is any spacer. I don't think I see open ended lug nuts on extended studs either, so if he has a spacer, he's going to be "running" into more problems very soon.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-14-2016, 03:12 PM   #12
Icecreamtruk
Drives: Track preped NA FRS
There are two types of spacers, one of which does not require you to have open ended lug nuts on extended stufs, dont jump to conclusions.
Icecreamtruk is offline   Reply With Quote
Old 09-14-2016, 03:18 PM   #13
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Anything more than a 3mm spacer is unsafe on the stock studs because you won't have enough stud thread on the outside of the wheel for the lugnuts to sit on.
The "two types of spacers" I think you're referring to are hub-centric and non hub-centric which has to do with proper centering rather than whether or not you need extended studs or not.
Edit: Actually, you may also be talking about the spacers with stud extensions already on them. Those are generally much thicker, and definitely wouldn't fit on the above setup. Like this:
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-14-2016, 03:18 PM   #14
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Running E-85 Tenshi_FRS Southern California 3 06-05-2015 07:01 PM
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 07:18 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Running e85? HSayaovong Engine, Exhaust, Transmission 16 04-24-2014 11:05 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
