Old 09-10-2016, 12:56 AM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
New tune no Oil Temp PID
Quick question for some of u guys that know something about tuning.
I just installed an e tune through ECUtec. I have to have them make revisions and im sure they will have me an answer but itll be monday before i get a response for this problem. before the tune I had oil temp reading. After the tune and header install i have all my OBD2 readings i had before just no oil temp reading. I hit read PIDs on my digital gauge lay out and doesnt pull oil temp at all.
Is this something that was just left out the tune and can be fixed by editing the tune on ecutec or am I just wishful thinking? sorry this is my first tuned car and know nothing about tuning to that extent.
Like i said i know my tuner will get back with me about it on monday but i figured you guys could give me something so I dont question any work i did all weekend lol.
tofurun is offline   Reply With Quote
Old 09-10-2016, 01:15 AM   #2
steve99
Drives: FT86
Thats weird, have ecutek tune latest racerom 9 and standard oil temp pid works fine with torque app
ecutek doesnt usually change and of that stuff.
can you read oil temp via ecutek logging, with ecutek cable
test your guage on another car maybe
Old 09-10-2016, 01:52 AM   #3
tofurun
tofurun's Avatar
Just checking logs and im seeing the oil temp on ecu tek.... HMMMMMMMMMM this is frustrating lol
Old 09-10-2016, 02:11 AM   #4
tofurun
tofurun's Avatar
somehow the tune has change the was that oil temp PID reads because the ecutek has it all day but the second i unplug ecutek and try to read it on my digital gauge i get nothing but every other gauge works perfect.
Old 09-10-2016, 04:26 AM   #5
steve99
Drives: FT86
Ok, ecutek logging of oil temp will be by direct read of ecu ram address
you guage like torque app will send a obd parameter id request to ecu these are standard for any ecu calibration id but the ram address will change
can the guage be setup to read different pid for oil temp ? or check setting
see second post in this thread
http://www.ft86club.com/forums/showthread.php?t=23530
Old 09-10-2016, 01:26 PM   #6
tofurun
tofurun's Avatar
Reading through that thread now. So what youre saying is the ram adress can change but the PID information will not change? I am using an Idatalink through my head unit by maestro. It checks for PIDs and validates. Its pulling all of them like normal but my oil temp is X out now and I dont think there is any way to go in the and change any pid information in the idatalink unit itself.
Old 09-10-2016, 02:20 PM   #7
tofurun
tofurun's Avatar
I read this
Q. I don't have an option for OBD header in the custom PID, do I need this?
A. For certain PID's such as Engine Oil Temperature you need to input OBD header information, you'll need to purchase the Torque Pro App in order to be able to enter the OBD header information.
i am so confused lol. why it pulled it before but not pulling now. ugh
Old 09-10-2016, 08:13 PM   #8
steve99
Drives: FT86
I read this
yes strange it worked before but not now.
If you canot change pid info in guage device, then it would appear something has changed in ecutek rom and its upset the pid information for oil temp. Ecutek dont usually alter this info.
looks like it up to ecutek now
Old 09-11-2016, 01:29 AM   #9
tofurun
tofurun's Avatar
im sure the tuner will take care of me. thanks for your help man. I was just trying to find out if this was normal or not.
Old 09-11-2016, 08:02 AM   #10
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
My new tune is RR9 and it doesn't have Oil Temp either!! Well, that's a lie.
It shows on EcuTek but doesn't show on Torque... strange.
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
tofurun (09-11-2016)
Old 09-11-2016, 08:24 AM   #11
steve99
Drives: FT86
well that's weird mines RR9 but it is A02G and it works fine on torque app, your is A01G from memory, shouldn't make and difference though
Old 09-11-2016, 01:35 PM   #12
tofurun
tofurun's Avatar
I'm not the only one!!! Lol. Idk if that's bad or good. I'll keep you posted on what my tuner says so you can get yours to work too. I'm just glad it's not on my end
Old 09-11-2016, 05:58 PM   #13
tofurun
tofurun's Avatar
What's the rr9 the a02g mean so I can reference this?
Old 09-11-2016, 08:38 PM   #14
steve99
Drives: FT86
RR9 is ecutek race rom revision 9
A02G is the ecu calibration id
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 10:04 PM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 03:49 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
