Old 07-17-2016, 02:43 PM   #15
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I have a hard time understanding how a complete rebuild at the dealer (with repeat failure being a real possibility) could ever be cheaper than a new long block from the factory.
But what do I know, I work in an industry where labor is the highest cost.
justatroll is offline   Reply With Quote
Old 07-17-2016, 02:57 PM   #16
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Originally Posted by dinoniel View Post
Hey guys wanted to update here as promised.
BRZ is still at the dealer. It was towed back to the original dealer who did the first repair. Apparently the higher up managers felt that was the best thing to do.
I got a list of what parts were ordered this time compared to the first time the engine blew. I'll list the parts below:
1st Repair:
-Short Block
-Gasket&seal set
-Oil change
2nd repair (parts that were ordered so far)
-camshaft
-pulley crankshaft
-gasket cylinder head
-spark plug
-spring valve/seal/rocker valve
-Oil pan
-cover assembly/chain
-water pump assembly
-thermo & gasket assembly
-Short Block
Obviously more extensive the second time around, but that's expected because the damage was a lot worse. Parts haven't come in to the dealer yet so still no word on when I will get my car back.
I'll put a disclaimer here that I'm not a mechanic and am at most a weekend DIY'er so I don't know much about engine terminology. Nonetheless feel free to share your thoughts!
Im in for forged internals and lower compression build
tofurun is offline   Reply With Quote
Old 07-17-2016, 03:04 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
1st Repair:
-Short Block
-Gasket&seal set
-Oil change
-camshaft
-pulley crankshaft
-spark plug
-Oil pan
-Short Block
Well then...
This is the problem. You can't pay people enough to take their time or give a shit. Long block is making much more sense now.
Honestly he should've gotten a new long block.....
The Following 4 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
dinoniel (07-17-2016), humfrz (07-17-2016), justatroll (07-17-2016), Ultramaroon (07-17-2016)
Old 07-17-2016, 03:37 PM   #18
Lonewolf
Lonewolf's Avatar
Drives: Moped
1st Repair:
-Short Block
-Gasket&seal set
-Oil change
-camshaft
-pulley crankshaft
-spark plug
-Oil pan
-Short Block
So who is going to be making car payments through this time? You may want to contact SoA about the money you'll be out while your car is out of commission for however long it takes to get the car back to you in working order...
The Following 2 Users Say Thank You to Lonewolf For This Useful Post:
dinoniel (07-17-2016), FRSBRZGT86FAN (07-17-2016)
Old 07-17-2016, 07:27 PM   #19
dinoniel
Pretty much exactly what I said. How can this be cheaper than dropping in a ready made engine from factory if you consider labor. But I know even less than you.
I argued for this. I got nowhere. In the end everyone kept saying "it's not up to the dealer it's up to the area manager and Subaru Rep." I asked for their numbers to speak directly and supposedly no one had it or even knew what days they worked. It was all a big mystery.
This is a good idea. Though they may argue that they covered my rental car/loaner vehicle. I suppose its worth a shot.
I'm just pretty exhausted of dealing with it all. It's a gigantic time toilet. And I will always be worried with the reliability of my only car. The worst part...a salesman from the dealer called last week asking if I want a new 2016 BRZ given my issues with the current one. I told him I would really prefer if my 2yr old car was just given back to me in reliable condition rather than entering a brand new deal. That call just furthers the idea that they really don't get it.
Verdict is still out if I will keep this car after it is fixed. It's hard for me to daily drive a car that has failed me twice without me even driving hard during these events or modding the engine.
Anyway appreciate the support as always
dinoniel is offline   Reply With Quote
Old 07-17-2016, 08:25 PM   #20
They sure are doing a lot of "patching" on that old engine.
Back in the day, I would have thought ...... fine, now it should be like new. However, engines were simpler and/or mechanics were more competent. I'll betcha the kid they have rebuild that engine never rebuilt a FA20 engine before.
I would recommend, after it is fixed, trade it into that dealership for a new car.
Cole (07-17-2016)
Old 07-17-2016, 08:35 PM   #21
Cole
Not a troll
Cole's Avatar
Funny you mention that, I've been watching roadkill nearly all day. Amazing how simple old cars are to work on. Drop a new carb onto that small block motor that's been in a scrap yard for 30 years and she gets to purring again.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
humfrz (07-17-2016)
Old 07-17-2016, 09:23 PM   #22
Yep, just a few steps and most of them would spring to life:
* take the carburetor apart and clean it with Gunk and rebuild with a new kit.
* pull the spark plugs, clean them and squirt some kerosene into the cylinders
* install a used battery
* pop the top off the distributor and clean the contacts with a finger nail file
* disconnect the fuel filter, clean and blow out the lines
* rap on the starter a few times
* mount a couple of used tires/patch a couple of tubes
* add water to the radiator (and oatmeal if it leaks); tape up any leaking hoses
* pour in 5 gallons of new gas
* fire that puppy up ...... you got yourself a running machine
chaoskaze (07-17-2016), Cole (07-17-2016)
Old 07-17-2016, 09:48 PM   #23
FRSBRZGT86FAN
There loss, literally, if the motor spins another bearing it's all there fault for not getting a brand new block and it will cost them more time and money
Old 09-08-2016, 06:35 PM   #24
dinoniel
UPDATE:
Well I left the car at the dealer to have all the work done that I had previously posted. The car was there for over 6 weeks, I told them to take as long as they needed to make it right. Picked up the car on 09/01/16.
Since leaving the dealership I've kept it under 3k rpm. More like 2.5k rpm im so nervous about driving this thing. It's also MUCH louder exhaust such that 3 people over the phone while I was driving asked me if I got a new exhaust or a UEL header. It's not pleasant.
Yesterday (6 days after picking up) the CEL and TCS light turned on. Code P0017. I had the code reset, hoping maybe it was some fluke idle code. This morning same warning light and same code P0017.
Called the dealer twice today no answer. They probably screen my number at this point but I'm so done with this. At what point will subaru admit this car is a lemon? They've poured so much money into fixing the damn thing and it's still not fixed.
Anyway anyone have experience with this code? I read a bit on the forums abt it but it was mostly about the random idling issues which didn't cause repeated warning lights like my case.
Old 09-08-2016, 07:04 PM   #25
Bach415
Bach415's Avatar
Drives: Whiteout FRS
UPDATE:
I would bring it to a different dealership to have the work done. P0017 is a cam issue. (http://www.ft86club.com/forums/showthread.php?t=67821). Might have cause the flat piece to pop off when they were putting the engine back together.
Bach415 is offline   Reply With Quote
Old 09-08-2016, 10:32 PM   #26
gravitylover
dinoniel - Here in NY you should be able to claim lemon at this point and get out of the car.
Old 09-09-2016, 02:19 AM   #27
dinoniel
I was thinking of contacting a lemon law lawyer. I need to do some more research would hate to spend money on a lawyer if there's no chance I'd win some settlement at least to cover the cost of the car and the cost of the lost value secondary to these issues.
The car was bought in Colorado and I'm currently residing in FL so I also need to check which state applies.
Appreciate the comments as always, I will update here when something progresses.
The Following 2 Users Say Thank You to dinoniel For This Useful Post:
Cole (09-09-2016), Guff (09-09-2016)
Old 09-09-2016, 03:25 PM   #28
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I would get out of car after you settle with dealer or sell whatever you decided to do.
Stock Motor is Toast (Spun Rod Bearing) DFW-FRS Issues | Warranty | Recalls / TSB 78 02-13-2018 12:56 PM
rod bearing failure. New long block question. USMCgetsome Engine, Exhaust, Transmission 13 06-12-2016 05:35 PM
Likely hood of a spun bearing aquaman Engine, Exhaust, Transmission 14 02-24-2016 02:37 PM
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 01:24 AM
Engine Failure (Bearing Rod 2) Incursion Issues | Warranty | Recalls / TSB 59 11-27-2014 03:17 PM
