| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I was able to pick up a set of used USA TRD 18 inch staggered wheels and Michelin PSS tires for a good price last week...
I seem to recall that there is a different recommended tire pressure for this setup, and that TRD equipped cars came with a sticker applied over the stock factory recommended pressures. Can someone supply a picture of the TRD sticker for tire inflation pressure? Thanks! |
#2 |
Slow driver, fast biker.
Drives: '16 86, '00 Celica GTS, Sportbikes
Sorry I didn't see your question sooner. Answered your PM.
Will leave this here for those who need the info. This is a TRD sticker that's supposed to cover the original one on the door pillar when the 18's are installed. Part number MDC P/N 00602-18130 |
| The Following 2 Users Say Thank You to Shinigami301 For This Useful Post: | everythingsablur (08-24-2016), nextcar (08-24-2016) |
#3 | |
![]() Armed with this information, I attempted to buy this sticker. The Toyota dealerships I called (3!) claim it is not a part they can order. I called the Toyota Material Distribution center - they verify that the part number is correct and that it is in stock, but they cannot sell to end customers, only dealerships. Oh well, at least now the information is available!!! |
#4 | |
all you need is mspaint, a printer and some elmer's glue
| The Following User Says Thank You to FX86 For This Useful Post: | Qadthane (08-25-2016) |
#5 |
is it just me or does 38PSI cold seem pretty high?
#6 |
The Fail Boat
Drives: CWP S.B.
Is tire pressure different for USA TRD 18" wheels?
Maybe just sidewall to wheel ratio is smaller... Hence more air. Wide guesses. 🌭 + the fact that setup is slightly staggered so front is gonna have more weight on it under breaking. Sent from my iPhone using Tapatalk Last edited by chaoskaze; 08-24-2016 at 06:56 PM. |
#7 |
#8 |
#9 | |
For that matter, the 35 PSI for the rears on a wider tire is effectively a higher pressure! (e.g same pressure over a larger area...) That's my armchair physicist analysis, and I'm sticking to it.
| The Following User Says Thank You to nextcar For This Useful Post: | chaoskaze (08-24-2016) |
#10 |
I Love custom Turbo kits
Drives: Limited BRZ
Staggered tires, WTF?
#11 |
It definitely makes a difference, at least with the Continental DW's- if you run equal pressure, the setup tramlines like a bastard on grooved pavement.
Two pounds difference is enough to completely change the tracking. That three pound difference between front and rear keeps the steering much more sharp than equal pressure front to rear, too. |
#12 |
| The Following User Says Thank You to nextcar For This Useful Post: | Sportsguy83 (08-24-2016) |
#13 |
Well, this is the "official" TRD configuration. Nobody says you have to go this way, but this is how it comes if you purchase it when you buy the car.
#14 |
They are typical USA TRD parts - a bit more show than go. For me they are a vast improvement from the stock tire and wheel setup... granted that is a pretty easy goal to meet!
| tire pressure sensors needed on track only wheels? | snuff58 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-02-2015 01:48 PM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
| Tire Pressure with 16" wheels? | fueledbymetal | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 11-16-2013 09:27 AM |
| Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-05-2013 12:54 PM |
| Recommended Tire Pressure for Aftermarket Wheels and Tires | Chri5 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-15-2013 01:28 PM |
