#15 |
Drives: none
This is a fairly common problem with turbo cars in general. To understand why you first must fully understand all the pressures/forces involved in making your wastegate function. Most people think boost pressure vs actuator spring force is all that's going on... But that's only half the story. You also have to consider the force applied to the wastegate valve/flap by the back pressure in your exhaust manifold. The actuator spring will open the wastegate when the sum of these two forces exceeds the spring force.
When you increase the flow capacity of your exhaust system you decrease the pressure on the wastegate valve, meaning more boost pressure is required to reach the same net force required to compress the spring... So your boost creeps. The only way to remedy this condition is with a lighter actuator spring. Or, I suppose, going back to a more restrictive exhaust, but who wants that? ☺️ Sent from my XT1095 using Tapatalk |
| The Following User Says Thank You to armstrom For This Useful Post: | COO86L (08-26-2016) |
#16 | |
Drives: GT3076r 8th gen Si
#17 | |
Drives: none
-Matt |
| Boost Creep? | #maverick# | Forced Induction | 14 | 08-20-2015 11:46 PM |
| Digital boost gauge w/ vent pod grim speed boost controller | Meetjoeblack | Engine, Exhaust, Bolt-Ons | 0 | 03-09-2015 02:27 PM |
| Does anyone else's headrests creep upwards as they drive? | Silver Ignition | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 03-26-2014 02:35 AM |
| Boost creep | Djen | Forced Induction | 58 | 08-24-2013 05:49 PM |
