#71 | ||
#72 |
Drives: 2013 Subaru BRZ
#73 |
Drives: 2017 BRZ Limited PP
I had tried running with the sound hole plugged (via the power outlet plug) recently and I liked how the car sounded. It seemed like it had a more balanced sound without the intake tube dominating. You could hear the engine, and what little exhaust sound the car has.
I decided to remove the sound generator apparatus and plug the hole left behind in the intake elbow. I used a 1 & 1/2 inch pvc pipe cap to do so. I purchased it from Home Depot for around $1. The cap was white, so I had to paint it. The only paint I had on hand was some touch up paint for my mk4 VW, which is a dark grey color. I decided to try it and it looked decent enough for my purposes. The second challenge I had was that the pvc pipe cap would slip over the intake tube hole and was just about the correct size, but since the pvc plastic is not flexible, it would likely not create a seal even with the worm style hose clamp. I decided to use permatex gasket maker to resolve this. It works, but it does make this mod more permanent in nature. I just made a bead in the cap, and another on the intake and slipped it on. Here is a low quality cell phone pic of the final result. I really like how much it cleans up the passenger side of the engine bay. |
#74 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Lav (05-11-2019) |
#75 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Or for even lower tech:
| The Following 14 Users Say Thank You to geezerbrzeezer For This Useful Post: | #944_10_Series_FRS (03-12-2017), Andrew025 (03-12-2017), Astroboy (07-27-2017), Code Monkey (01-04-2018), Cole (03-12-2017), Lav (05-11-2019), ncted (05-08-2018), new2subaru (01-08-2018), OrangeGuitar (07-10-2017), Overdrive (01-18-2018), Scrappydoo (03-12-2017), theneptune86 (08-19-2020), Tristor (05-03-2018), Ultramaroon (03-12-2017) |
#76 |
lol
#77 |
Drives: 2013 10 series FRS #944
Better to protect the sausage with a condom. Don't want to contaminate the part...
| The Following User Says Thank You to #944_10_Series_FRS For This Useful Post: | geezerbrzeezer (03-12-2017) |
#78 | |
Geezer
Sound idea. And bonus - should your canyon road 'legend in your own mind' hooning ambitions find you obtusely parked in a ravine, pop the hood to enjoy a possibly still warm, condom sterilized, um, 'food' source. |
#79 |
Drives: MY17 Asphalt 86
I went a bit of a different route than anything else I've seen so far for my total sound generator delete.
I started out with a 1 1/4" PVC Plug from Home Depot. I sanded all of the edges down so that the head was round instead of the ugly octagonal head that's on it for plumbing use. Then I prepared it with a quick acetone wipe down and painted it with Rustoleum black spray paint for plastics. ![]() For the firewall plug, I used bryan767's idea of the SharkBite 3/4" plug ![]() All together I think it worked out quite allright.
| The Following User Says Thank You to EnoOnraefi For This Useful Post: | Tristor (05-03-2018) |
#80 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Fixed broken image links since dropbox decided to kill public folder sharing
| The Following User Says Thank You to B-R-Z For This Useful Post: | LuckyEinstein (01-04-2018) |
#81 |
Drives: 2013 WRB BRZ
This is a great DIY and the pictures are very helpful! I'm going to give this a shot. Thank you!
#82 |
Drives: 2017 WRB BRZ
NICE DIY. I just removed the noise generator and went for a test drive, LOVING it! The noise that the generator made always confused me, like "why is it so loud when I didn't put that much throttle in". Now it's a lot more clear.
#83 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
This still works for MY17. Just did it. Also installed the plex plug from the engine side. worked great. Thanks for the DYI super easy.
| The Following User Says Thank You to Elliotw For This Useful Post: | ncted (05-08-2018) |
#84 |
I did this yesterday. It really cuts down on the harshness of the noise coming from the engine. Before this, I wasn't sure if I wanted to do any exhaust mods due to excessive noise/not being able to hear the good noise over the bad. This has totally changed my mind.
| The Following User Says Thank You to ncted For This Useful Post: | Paiser (09-29-2022) |
| Sound Generator to keep or not to keep? | FRS86edition#3 | Scion FR-S / Toyota 86 GT86 General Forum | 73 | 11-24-2013 02:26 AM |
| Sound generator delete for $1.06 | PineappleFriedRice | Engine, Exhaust, Transmission | 13 | 11-10-2013 01:28 PM |
| Sound Generator Tube Delete | Anthony | Engine, Exhaust, Transmission | 8 | 09-01-2013 05:25 AM |
| WTB: OEM snorkle (not sound generator) | Laika | Engine, Exhaust, Bolt-Ons | 2 | 11-08-2012 12:31 PM |
