| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: 2013 Asphalt FRS
Add me to the list one minute they are fine the next they are not working. I'm beginning to wonder if its a ECUTEK bug in the software.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#16 |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Ask him what he set the idle to. One of the preconditions is an idle below 1050 RPM. If your idle is set higher than that the exhaust cams never unlock. Figured this out pretty quick the first time I tuned a car with 1300 cc injectors on pump gas.
| The Following 2 Users Say Thank You to Boosted2.0 For This Useful Post: | BRZoomTX (05-06-2016), FRS Justin (05-06-2016) |
#17 |
And the best cam unlock procedure is just select exhaust angle 1 for live data and let the car idle till it starts bouncing off 0 - once ti does tap the throttle, cam timing will change and you are GTG.
| The Following User Says Thank You to Boosted2.0 For This Useful Post: | FRS Justin (05-06-2016) |
#18 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
my exhaust cams are always slow to come back online. Not sure why. Sometimes it takes a few min.
#19 |
Drives: 10 Series Scion FR-S
I don't know if I'm having this same issue, but after a flashing my car, my exhaust cam will only move from 0 to 2 degrees, and no amount of idling will make it change.
Only way I have gotten the cams to move is to drive around for a few minutes and then the exhaust cams become fully activated, but even after the cams activate, I feel the car is slower than stock and this is the tune I had done a few months ago and had no issues. |
#20 |
Drives: Subaru BRZ
I'd like to bump this thread.
I was in for dyno time (tune update) today and it looked like my cam timing was not "waking up." Baseline pull looked decent enough - but then (I assume after reflash) the cam timing just died. It was reported to me that the cam timing was simply not changing. We started talking about possible cam gear issues (May 2013 build date). But I've had no CELs. Once I was driving home, logging with Torque app, I could see timing was what I expected. Are there any other details or suggestions into what could be taking place here? - ECUTek tune for reference. Thanks for any data that can be shared. |
| The Following User Says Thank You to SpectreRT For This Useful Post: | kanundrum (07-26-2016) |
#21 | |
Drives: FT86
Their is likely a sequence of events that must occurr for the cam timing to become active after an ecu flash or reset. these likely include coolant temp oil temp some timer that activates only after idle rpm falls below say 1000 rpm, for about a minute Ignition advance multiplier must be greater than a threshold think its about 0.2 in stock rom this is switch between base safe and normal cam tables, another threshold about 0.7 for normal\safe. Dyno may also upset cars stability\vsc system , two wheel dyno front wheels stationary so vsc\traction system likely gets upset and may signal ecu to keep in some form of low power mode. even 4 wheel dyno may upset vsc if different loads applied to frtont back wheels. perople often report that cam timing comes good once car off dyno and driven for short period. so that may indicate it was traction\vsc related. its all guessing rearly |
#22 | |
Drives: Toyota 86 GTS
Did you try turning it off and on again?
60% of the time it works every time. Quote:
#23 | |
Drives: Subaru BRZ
Thanks for the reply. Today my tuner logged for a good 90 mins or so with fresh flashes, idle, load etc. What he found was the cam would only go +/- 1 degree. At start it looked like -18 and it never went anywhere.
I have no CEL / MIL. DTC is clean. We're debating replacing the cam actuators, as this has worked for a few folks. I don't personally have the equipment to log / check for cam settings in motion. Maybe I can try that this weekend. Any additional data would greatly help. Replacing all 4 of the cam actuators will be a very costly endeavor.... Quote:
#24 | |
So instead of turning it off and on again, you'll spend a few thou pulling the motor apart?
#25 |
Drives: Subaru BRZ
#26 |
Really? Because you said: "Today my tuner logged for a good 90 mins or so with fresh flashes, idle, load etc." "Baseline pull looked decent enough - but then (I assume after reflash) the cam timing just died." "Once I was driving home, logging with Torque app, I could see timing was what I expected." There's nothing there about restarting the car after flashing. Just that AVCS DID NOT work after flashing, and DID work on your way home. Maybe you should read the thread, it's only 2 pages. If you did restart and idle the car without touching the throttle a couple of times and the cams still don't work, then I'm sorry for your loss. |
#27 | |
Drives: FT86
also not all cel codes will light cel, they are just stored check with scanner if you dont have injector changes maybe try flashing back a stock tune to car. start let it idle for a couple of minutes without touching throttle an see if cams are active at low rpm and load, that will eliminate some weird bug in tune causing problem. |
#28 | |
Drives: Subaru BRZ
ECUTEK is being used. I'll relay the thought of disconnecting the battery and giving that a shot post flash.
We did scan for all DTC, CEL, MIL codes, ECU had nothing to report. Thanks again for the knowledge share. Quote:
| Cam timing adjustments without dyno | StormTrooper | Software Tuning | 17 | 02-19-2014 05:16 PM |
| POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) | stevo_12v | Engine, Exhaust, Transmission | 10 | 12-19-2013 03:02 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
