Old 07-24-2016, 03:22 PM   #1
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
Couldn't get into 6th
so I was on the highway and had to pass a bunch of cars/semis/trailers quickly so I (did not) pass going 160kmph. but when I tried to get into 6th I couldn't so I had to get back into 5th. but at lower speeds it's easier to get into 6th.
why is this? or am I just crazy?
Atticus808 is offline   Reply With Quote
Old 07-24-2016, 03:36 PM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just one of those days when transmission not happy with you. Next time it will be ok..
Jokes aside sometimes I have problem getting into 5th from 6 when I'm going pretty fast... I take it as just one of those weird things with this transmission...
The Following User Says Thank You to chaoskaze For This Useful Post:
Atticus808 (07-24-2016)
Old 07-24-2016, 03:38 PM   #3
Hmmm... sounds like a typical missed shift. If pumped up on adrenaline, did you perhaps release the clutch pedal before getting it into gear? It happens.
Also, sixth can be kind of awkward. Even a little dangerous if you're not paying attention. If you don't have that lever hard over to the right it could bump up between 4th and 6th gates or even worse, drop into 4th which, IIRC, would be money-shift territory at that speed.
Old 07-24-2016, 03:40 PM   #4
Atticus808
Atticus808's Avatar
nope. I kept the clutch in. ever since I pm'd you awhile back I've been very careful. when I couldn't get into 6th I kept my foot on the clutch and brought it back to 5th
The Following User Says Thank You to Atticus808 For This Useful Post:
Ultramaroon (07-24-2016)
Old 07-24-2016, 04:13 PM   #5
Oh, yeah! I had forgotten about that.
edit: How many miles on the car now? It took my trans 10-12K miles to really break in the syncros. 6th is still a bit chunkier than the rest.
Old 07-24-2016, 04:13 PM   #6
GAPF1
Couple of times, I've experienced a balk from the gearbox when shifting quickly from fifth to sixth at relatively high revs.
You can't expect to wield supreme executive power, just because some watery tart threw a sword at you.
GAPF1 is offline   Reply With Quote
The Following User Says Thank You to GAPF1 For This Useful Post:
Old 07-24-2016, 04:47 PM   #7
ryoma
ryoma's Avatar
were you all the way to the right with the shifter? maybe the vibrations and torque from the engine while driving it hard caused a slight momentary shift in the transmission due to the soft OEM bushings when you were trying to get into 6th, causing you to miss the gate. I have never had this problem before, but there have been a couple of times where I missed a 5th to 4th downshift because I couldn't get it into the gate, but that was most likely user error
The Following 2 Users Say Thank You to ryoma For This Useful Post:
Atticus808 (07-24-2016), chaoskaze (07-25-2016)
Old 07-24-2016, 05:30 PM   #8
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
under acceleration, I am just shifting from 4th to 5th at that speed.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
Old 07-24-2016, 07:40 PM   #9
Atticus808
Atticus808's Avatar
it's not my daily so I only have about 5000km lol. it seemed fine shifting at lower speeds. you gotta take your car up here to Canmore. very nice here
nope. I don't remember what rpm I was at but probably around 5500-6000. and thanks for the explanation. it does make sense
Old 07-24-2016, 09:54 PM   #10
Oh hell, it's still brand new! The syncros won't start grabbing effectively until about twice that distance. Next time it won't go into any gear, no worries. Just release enough to go back into neutral and apply steady pressure a second time.
I apologize if I'm repeating myself but it's not like a switch. The higher the RPM, the bigger the difference in RPM between gears, and therefore the more work the syncro has to do to match speed between input and output before allowing the gear to engage.
Been threatening to visit Banff for a long time now. The missus is all in. Just have to carve out a few days to tool around.
Old 07-24-2016, 10:43 PM   #11
gravitylover
...Been threatening to visit Banff for a long time now. The missus is all in. Just have to carve out a few days to tool around.
When you get to Banff make sure to leave some time to go up the Icefields Parkway to Jasper. FKNA beautiful road!!
The Following User Says Thank You to gravitylover For This Useful Post:
Old 07-24-2016, 10:44 PM   #12
radroach
Drives: car
@Atticus808 eventually you might want to change out the gearbox oil for some motul gear 300 or other recommended brand
Old 07-24-2016, 11:21 PM   #13
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I don't have a twin yet, but if it's effectively a "syncro" problem, then a quick tip is to go back to neutral, release the cluth and press it again and then shift in the desired gear, effectively doing a "double clutch" shift.
nico_rsx is offline   Reply With Quote
Old 07-25-2016, 12:14 AM   #14
Added to the plans!
When I first got mine, which already had 1800 miles, I was a double clutching fool because I couldn't bring myself to yank as hard as it took to downshift normally. After about 5K miles I started noticing improvement which continued steadily through about 20K.
Couldn't wait... here's the surprise! hamzam Scion FR-S / Toyota 86 GT86 General Forum 46 08-28-2013 05:54 PM
And They Said it Couldn't be Done!! Batman Engine, Exhaust, Transmission 29 01-29-2013 02:04 AM
Couldn't wait for the FT-86 so I bought... the ZUK switchlanez Other Vehicles & General Automotive Discussions 35 11-23-2011 06:35 AM
New Car... Couldn't wait for Toyota BootpTraphik Off-Topic Lounge [WARNING: NO POLITICS] 62 12-20-2010 10:29 PM
