Old 05-24-2013, 07:45 PM   #29
Tromatic
People sure do put a lot a thpught and energy into bringing themselves down. You own a really cool car. Abuse it, it might break. Use it hard, things wear out.
Take care of it. Drive. Repeat.
Old 05-24-2013, 09:23 PM   #30
Cheddar
Saving them pennies...
Originally Posted by Rampage View Post
Check your math.
Thats what I got you guys for
Cheddar is offline   Reply With Quote
Old 05-24-2013, 09:24 PM   #31
Cheddar
Originally Posted by Marrk View Post
Yeah. I saw it. Crawford. Not Cosworth.
Sorry I get them mixed up at times.
Old 05-24-2013, 09:58 PM   #32
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Thanks for understanding my "Engrish" lol
You know me too well
I remember this when shopping for a Forester and went with the earlier (non HG-failure-prone) engine
Old 05-24-2013, 11:33 PM   #33
Thunderchicken
Drives: 2008 STi
EJ25 is known for head gasket problem (turbo is bearing problem more)... iirc Subaru did re-call on this problem.
But Toyota is well known for head gasket problem too (mkiii supra).
I had to change the blown gaskets on my GM6 (2.5RS coupe). I was racing every month in the summer for several yrs, so it's not the same as defective head gaskets.
My point to the OP is, if you search around, there's always a negative thing bout the car production.
Subaru head gasket issue stems from the gaskets drying out and caused the issue, so Subaru put and additive in the coolant to prevent the issue. The bigger issue is the pistons and the shitty tune that causes pre-det.
The MKIII Supra head gasket issue is from warping due to being not torqued down enough during manufacturing, but later fixed by Toyota and corrected in there publications.
Thunderchicken is offline   Reply With Quote
Old 05-25-2013, 01:49 AM   #34
Marrk
Drives: Honda Fit
You're welcome.
Marrk is offline   Reply With Quote
Old 05-28-2013, 03:48 PM   #35
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I have a 04 wrx wagon, 167k miles still runs very well no issue. Sure it was not tracked but I agrees with many posts above, Subaru knew and tried to improvise. I think most of cause are User abuse or shitty tuning or lack of proper maintaince (ie most of mechanics do not know oem coolant conditioner is needed).
Speed2th is offline   Reply With Quote
Old 05-28-2013, 10:20 PM   #36
FT_Monk
Drives: Over the hill WRX
140K miles here with my 02 WRX and no head gasket issues (yet) despite abuses and mistakes made to the engine. I mean all cars have problem and if you keep fearing somethings that might happen 10 years from now then just take the bus instead.
FT_Monk is offline   Reply With Quote
Old 05-28-2013, 11:23 PM   #37
Marrk
Drives: Honda Fit
Old 03-31-2015, 01:43 AM   #38
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
my engine is leaking....
got my head gasket replaced and now its leaking even worse fml it seems like its only me.... 24k got my gasket replaced at like 22 and now another is leaking wtf
brzadrian is offline   Reply With Quote
Old 03-31-2015, 01:57 AM   #39
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
This was the biggest turn off for me with Subarus. Over complexity for a measly 4 cylinder engine. 2 heads and their gaskets to worry about, 4 cams, pita sparkplug changes, 6L of oil, and a crankcase that splits in half. For only a 2.0L engine. I never liked Subaru much if at all. The only reason why I gave this car the BOD is because of Toyota. If they entrusted Subaru to make a car for them, they must be doing something right. But through and through, this car is a Subaru. I got tricked! Hopefully none of the ugly past problems with Subaru's surface. Head gasket failure being a major one of them.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
ZZT86 (03-31-2015)
Old 07-18-2016, 03:42 PM   #40
Scrub
Drives: 2015 White BRZ MT
I got a head gasket leak at 3k miles only 2 months after buying my BRZ
Scrub is offline   Reply With Quote
Old 07-18-2016, 03:59 PM   #41
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Just saying, but when my old forester needed headgaskets the motor had to be pulled, I'm sure it is the same with this motor.
Old 07-18-2016, 07:00 PM   #42
... & so begin the bromance LMAO
I know, ancient post but I LOLed nonetheless.
ichitaka05 (07-18-2016)
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 10:32 PM
WTB: Blown Front OEM Shocks (SC) WolfSongX Want-To-Buy Requests 8 05-25-2013 06:06 PM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
Initial d blown engine be6sti Other Vehicles & General Automotive Discussions 6 10-15-2012 10:16 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 10:32 PM
