#15 |
Huge E85 fan!
Drives: 2016 Scion FRS
I was in Reverse. Maybe that had something to do with it?
#16 |
...Just add nauseum
Drives: 2003 (AP1) S2000
It also depends on how they wrote the cranking logic.
If you don't trigger the cranking table, you won't get start-related trouble codes. If your bump start turns the engine over faster than max cranking rpm for example, the ECU may use the normal running tables. On Haltech ecu's, cranking tables are used below max cranking RPM. The OEM Denso stuff on this car may have much more complicated logic.
There are many ways to displace.
-Spartarus Last edited by Spartarus; 07-18-2016 at 10:44 AM. |
| The Following User Says Thank You to Spartarus For This Useful Post: | Ultramaroon (07-18-2016) |
#17 | |
#18 | |
...Just add nauseum
I learn something every day
-Spartarus |
| Weird hot start issue | mike the snake | Software Tuning | 21 | 01-18-2021 08:03 PM |
| Weird behaviour on cold start | itsAlex | Issues | Warranty | Recalls / TSB | 40 | 02-10-2018 03:02 AM |
| Car won't start! Making weird sounds. | B_Rad | Issues | Warranty | Recalls / TSB | 35 | 01-25-2017 06:33 PM |
| Bump start in a manual trans? | bayank | BRZ First-Gen (2012+) — General Topics | 11 | 02-16-2014 07:47 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
