Old 07-18-2016, 09:43 AM   #15
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I was in Reverse. Maybe that had something to do with it?
guybo is offline   Reply With Quote
Old 07-18-2016, 10:31 AM   #16
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
It also depends on how they wrote the cranking logic.
If you don't trigger the cranking table, you won't get start-related trouble codes. If your bump start turns the engine over faster than max cranking rpm for example, the ECU may use the normal running tables.
On Haltech ecu's, cranking tables are used below max cranking RPM. The OEM Denso stuff on this car may have much more complicated logic.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Ultramaroon (07-18-2016)
Old 07-18-2016, 02:44 PM   #17
Originally Posted by Spartarus View Post
I didn't write the code that trips the CEL, and given the usual habits of OEM's I'm sure the logic is quite complex.
There could be many reasons it doesn't trip every time.
It may only trip under specific circumstances. If anybody cares enough to get on a hill and figure out the logic, go ahead.
No snarkiness intended in my last. Just adding observations. Apologies if I came off sounding anything less than engaged and curious.
Old 07-18-2016, 03:58 PM   #18
Spartarus
...Just add nauseum
Spartarus's Avatar
No defensiveness intended. It was an interesting observation that I was not aware of.
I learn something every day
-Spartarus
Weird hot start issue mike the snake Software Tuning 21 01-18-2021 08:03 PM
Weird behaviour on cold start itsAlex Issues | Warranty | Recalls / TSB 40 02-10-2018 03:02 AM
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 06:33 PM
Bump start in a manual trans? bayank BRZ First-Gen (2012+) — General Topics 11 02-16-2014 07:47 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
