Old 07-16-2016, 10:37 AM   #29
ZionsWrath
Thanks
ZionsWrath's Avatar
Hmm I find my trans actually shifts better under track driving (WOT). And is notchy as fuk on the street. I have Motul in it
The Following User Says Thank You to ZionsWrath For This Useful Post:
strat61caster (07-16-2016)
Old 07-16-2016, 12:27 PM   #30
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Keep in mind that an adapter plate is not the only thing you'll need even if you find one. The spline count depending on which variant of the T56 you get will be either 27, 30, or 31 (most likely will be 27). The spline count on the FRS is 24. So you'll need to get a different output shaft or find a clutch disk that works with the correct pressure plate and has the correct number of splines.
Dustin is offline   Reply With Quote
Old 07-16-2016, 01:12 PM   #31
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Thank you for exsplining that to us.
Old 07-16-2016, 04:15 PM   #32
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
I'll probably end up with another stock trans anyways I was just curious if there was something out there
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 07-16-2016, 04:47 PM   #33
gramicci101
Off Topic
@FullBlown was making a V160 conversion kit a few years ago. That might work for you.
http://www.ft86club.com/forums/showthread.php?t=53454
Old 07-16-2016, 08:30 PM   #34
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Spline count doesn't matter much. Just need to find the same clutch pads as stock but with the new spline count. The real trick isn't the mount either it's the dam new drive shaft. Car can also use a hydraulic throw out bearing to fix weak fork while doing it.
The factory Subaru fluid is great when cold and around town just at top of the RPMs is I guess not great, I guess.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 07-16-2016, 10:32 PM   #35
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by AdrianSaldana View Post
if you absolutely had to change it what would you get lol
T5 upgraded!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-16-2016, 10:46 PM   #36
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I took my POS truck driveshaft to a shop because mine was 25 years old, the joints were gummed up and it wasn't serviceable, they ended up welding up a custom driveshaft for my 4-banger 134 hp (when new) Nissan pickup.
$560 with universal Chevy truck joints, driveshaft was the nicest thing on that POS when I sold it aside from how cold the AC was.
If my corner shop will do it for less than the price of a set of OE tires I think the driveshaft is one of the least of your worries.
ineedyourdiddly
Old 02-09-2019, 12:18 AM   #37
Macaruchi
Drives: Scion Fr-s fully built engine
Originally Posted by wise345 View Post
Does anyone out there make an adapter to mate the t56 to the FA20 or any other real trans for that matter? I'm tired of the stock transmission it's a piece of junk
Did you find it any adapter for tr56 tremec
Macaruchi is offline   Reply With Quote
What is the thinnest adapter I can use without having to cut the lug nut? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-11-2016 09:32 PM
WtB short hub adapter P_say86 Want-To-Buy Requests 0 07-18-2015 08:39 PM
Adapter help lookchris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-09-2013 11:39 AM
Worksbell hub adapter!?? _F-R-S_ DIY (Do-It-Yourself) Guides 1 12-14-2012 02:27 PM
