Old 07-15-2016, 01:23 AM   #1
midnitz
Drives: white fr-s
MotulGear 75W90 okay for tranny and diff?
So i ordered 4 bottles of Motul 300 75W90 for my transmission and diff, but the shop shipped me MotulGear instead . I'm gonna call them up and ask for an exchange.
If, for any reason, I cant exchange them, has anyone else used MotulGear instead of Motul 300 on tranny and diff?
midnitz is offline   Reply With Quote
Old 07-15-2016, 02:08 AM   #2
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
SemiSynthetic vs FullSynth. Probably a minor difference during normal usage, but I would exchange.
-JvV-
jarnojvv is offline   Reply With Quote
Old 07-15-2016, 02:12 AM   #3
I think you will be OK as long as the bottle says "75W90".
I figure "Motul" is the brand name; "gear" is a descriptor.
They very well be one in the same....... fer sure.
Old 07-15-2016, 02:25 AM   #4
hmmmm........upon further reading, you may wish to consult with the Motul web site (and other forum members) before you put the Motul 300 gear oil in our car's limited slip differential. Seems like they make a "LS" formulation for limited slip differentials.
Old 07-15-2016, 02:27 AM   #5
gramicci101
Off Topic
They do, but it isn't necessary for Torsen or other gear-driven limits slips. It is necessary for clutch-type limited slips.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
kch (07-15-2016), wparsons (07-18-2016)
Old 07-15-2016, 02:33 AM   #6
OK. I reckon that is what this says ........I'm over my pay grade here .....
JohnJuan (07-15-2016), tofurun (07-17-2016)
Old 07-15-2016, 11:32 AM   #7
gramicci101
Off Topic
CSG Mike has said that with the 300LS the limited slip will hold on for just a bit longer before slipping, but he also pushes these things much harder than I ever will. Otherwise, 4 quarts of 300 is cheaper than 3 quarts of 300 and 2 quarts of 300LS. I get mine from AZP Installs.
The Following User Says Thank You to gramicci101 For This Useful Post:
humfrz (07-15-2016)
Old 07-15-2016, 02:42 PM   #8
jarnojvv
jarnojvv's Avatar
300ls definitely locks up earlier than standard fluid.
-JvV-
Old 07-16-2016, 11:49 PM   #9
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
I run regular 300 in both my trans and diff. From everything I have read our Diff does NOT require the 300 LS and I am not sure you can run the LS in the trans.
tofurun is offline   Reply With Quote
Old 07-18-2016, 10:44 AM   #10
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Run Gear 300 in your trans, and you can run EITHER Gear 300, or Gear 300 LS in the rear diff. There is some anecdotal evidence, (from very reliable sources, read: CSG_Mike) that the diff does feel better with the Gear 300 LS, but the difference will likely not be noticeable by the vast majority of users unless you are an experienced driver on the track, pushing the car hard, running the fluid back to back.
I choose to run Gear 300LS in my rear diff since I need to stock both Gear 300, and Gear 300 LS due to my FXT having an R180 in the rear.
JazzleSAURUS is offline   Reply With Quote
Part Numbers for Tranny & Diff Washer BRZY Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 03-24-2025 12:51 PM
STI JDM tranny mount vs Perrin tranny support NVH khrono Engine, Exhaust, Transmission 2 03-15-2016 09:43 PM
Does BRZ come stock w/ magnetic drain plugs (diff/tranny)? Daedex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-05-2014 09:50 PM
Should I change my diff oil and tranny oil Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-24-2014 12:30 PM
