Old 06-22-2016, 08:58 AM   #211
Nickosport
Drives: 2015 WRB BRZ Premium
Originally Posted by stevesnj View Post
From experience i learned that this is the worst way to do this, All you need to do is use the brake adjuster "star wheel" from the front of the hub, loosen and the drum rotor will slide right off.
He was talking about removing the hub from the e-brake assembly, not the rotor from the hub.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
The Following User Says Thank You to Nickosport For This Useful Post:
stevesnj (06-22-2016)
Old 07-14-2016, 06:16 PM   #212
_sams86_
Grasshopper
_sams86_'s Avatar
Drives: Ultramarine
Just order the studs from Subaru dealer for 3$
Toyota charges 8$ per stud and they're the same
_sams86_ is offline   Reply With Quote
Old 07-14-2016, 06:30 PM   #213
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Except the part where they're horseshit. The whole reason this thread exists.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
Tristor (04-18-2018)
Old 07-14-2016, 07:44 PM   #214
_sams86_
Grasshopper
_sams86_'s Avatar
Drives: Ultramarine
I don't disagree with you, i was saying more of when you need to replace 1 or 2 and aren't able to fork over 130-150 for a new set of ARP studs.
Old 07-14-2016, 07:48 PM   #215
Gopherboy6956
True. I did that a few times before I just said FK it and went ARP
Old 07-14-2016, 07:49 PM   #216
_sams86_
Grasshopper
_sams86_'s Avatar
Drives: Ultramarine
Happened to me yesturday 😅
Sent from my Nokia using Tapatalk
The Following User Says Thank You to _sams86_ For This Useful Post:
Old 08-02-2016, 02:51 PM   #217
ChrisD
ChrisD's Avatar
Drives: GT86
I hate to be that guy who says there is no problem when plenty of other people say there is, but I really don't think the stock wheel studs are bad. Perhaps a lot of you are just over tightening them?
I've taken the front and rear wheels off at least 30 times, and not a single one of my threads on any of the wheel studs are showing any sign of stripping.
Every time I've put the wheels back on, I use a torque wrench to torque the wheel nuts up to 120 Nm (89 ft-lbs) as per the service manual instructions.
A lot of other people I know who work on their own cars say that you should just do them as tight as you can... so I'm guessing a lot of people in this thread that have stripped the stock threads might have followed that same theory. The only time I've ever stripped any bolt threads was when I got the wrong torque value for a bolt that holds the rear lower control arms to the suspension strut, and over tightened it by 30 Nm. So if you guys are tightening the wheel nuts up
Maybe I've just been lucky, but it seems unlikely considering the number of times I've had the wheels off.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 08-02-2016, 04:46 PM   #218
qoncept
qoncept's Avatar
I don't know about anyone else, but I'm not. Mine were never unusable but they were definitely stretched and wanted to crossthread after taking the wheels off a handful of times. I torque to 80ftlbs. I wonder if the studs have been improved since the first models.
qoncept is offline   Reply With Quote
The Following User Says Thank You to qoncept For This Useful Post:
Old 08-02-2016, 06:46 PM   #219
ChrisD
ChrisD's Avatar
Drives: GT86
Ah ok, fair enough. I just thought it might explain why a lot of people have issues but I've taken them off loads and never had even the slightest issue with cross threading or breaking. Maybe it's just luck if you get good bolts or bad bolts.
Oh and mine is an older model btw, 2012.
Old 01-31-2017, 12:29 PM   #220
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
Are 5mm spacers safe on stock studs?
fizzymike is offline   Reply With Quote
Old 01-31-2017, 02:57 PM   #221
kch
Senior Misanthrope
kch's Avatar
I wouldn't.
The Following User Says Thank You to kch For This Useful Post:
Old 01-31-2017, 04:12 PM   #222
modernbeat
Vorshlag R&D
modernbeat's Avatar
Drives: A new one every month
No. 3mm can be safe, depending on the pad depth of the wheel.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline   Reply With Quote
The Following User Says Thank You to modernbeat For This Useful Post:
Old 08-21-2017, 09:20 PM   #223
DarkSideFRS
Drives: 2013 pearl white FR-S
Originally Posted by bpracer View Post
Using the tool suggested by jdrxb9 post below, I was a bit overzealous removing all the studs from my rear hub to install my 10mm Ichiba spacer kit.
http://www.ft86club.com/forums/showp...58&postcount=4
Tool prep-
The fork on the tool needs to be opened up slightly, a file would work but a right angle grinder with a flap wheel is much faster. Also, it would be good to shorten the forks a bit to hit the fulcrum in the sweet spot of the tool. Be sure to use a good grease on the tool threads or it will self-destruct faster.
sorry for bumping an old thread, but can the tool still be used without this modification? I've read through this thread and u're the only person who did the modification to the tool. it looks like you're just shortening the fork and expanding the opening inside the fork?
Also, it looks like I can just slip the tool between the hub and backing plate based on your picture. I'm trying not to remove the hub if possible as I'm just putting in OEM-length studs
DarkSideFRS is offline   Reply With Quote
Old 06-08-2018, 02:50 PM   #224
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I will be doing the rears tonight.
Ordered 10. 11 arrived.
via Imgflip Meme Generator
I LIKE TIRES!
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 03:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
