Old 07-14-2016, 12:49 AM   #15
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Originally Posted by FRSBRZGT86FAN View Post
Most of the issues in the manual can be fixed and it can handle the normal boost levels of an sc or turbo at 260-300 whp. I would honestly change fluids, take the clutch spring out if you don't like the clutch feel, and get a short throw to tighten it up if you want it more notchy
I already have an aftermarket clutch and trust me the issues I have won't be solved with fluid. The synchros are bad to the point of I struggle to get it into 4th on a pull sometimes and I'm just with a catback and was stage 2 for a while
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 07-14-2016, 12:49 AM   #16
wise345
wise345's Avatar
Originally Posted by CCJ View Post
The new Miata (chassis code ND) has an infamous transmission already.
Jokes are always funnier when you have to explain them.
That's what I thought you meant lol I just hadn't heard their transmissions were horrible
Old 07-14-2016, 01:51 AM   #17
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I don't think it's terribly hard to destroy a transmission on stock power. Try this for fun and excitement: Drive at 85mph. Shift into first.
On a more realistic level, power shift. Rev match poorly or not at all while downshifting, especially under power. These are all the things that mess up a perfectly good and well-designed transmission on stock power on any car.
Old 07-14-2016, 02:55 AM   #18
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I love my manual gearbox. Feels goooood and pushing over 300whp reliably.
If I was going to out a gearbox in, it would probably be the one out if a 370z. Apparently those things are strong af
COO86L is offline   Reply With Quote
Old 07-14-2016, 09:45 AM   #19
FRS Justin
Drives: 2013 Asphalt FRS
I can just see the rocker arms flying out of the motor on a downshift like that........
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Summerwolf (07-14-2016)
Old 07-14-2016, 09:47 AM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I think you'd do a bit of damage on an 85 MPH 1 shift, lol.
Old 07-15-2016, 04:52 PM   #21
Crunk81us
Drives: Toyota 86
take the clutch spring out?
Crunk81us is offline   Reply With Quote
Old 07-15-2016, 04:56 PM   #22
Apex-Apex
Apex-Apex's Avatar
They're also humongous.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following User Says Thank You to Apex-Apex For This Useful Post:
nickw14 (07-18-2016)
Old 07-15-2016, 06:11 PM   #23
AdrianSaldana
That Guy
AdrianSaldana's Avatar
Drives: Fast and Hard
if you absolutely had to change it what would you get lol
"Knowledge will give you power, but character respect.."
DD: 2007 Suzuki Sv650
Weekend Car: 1969 Chevelle
Summer/Weekend Car: 2014 BRZ
AdrianSaldana is offline   Reply With Quote
Old 07-15-2016, 06:54 PM   #24
Summerwolf
Panda Trueno
Summerwolf's Avatar
T56
Old 07-15-2016, 07:05 PM   #25
gramicci101
Off Topic
http://www.ft86club.com/forums/showthread.php?t=103157
Old 07-15-2016, 07:56 PM   #26
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
http://www.ft86club.com/forums/showthread.php?t=35621
The helper spring sort of dampens the stock feel, I've felt it on a car with and without it, and without it is noticeably better
Old 07-16-2016, 08:41 AM   #27
wise345
wise345's Avatar
T56 or a cd009 is what I'd go for problem is finding a way to mate it to the engine
Old 07-16-2016, 09:27 AM   #28
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
New fluid, heavy clutch and clutch pedal spring removal makes it so much better but under WOT shifts the synchros such ***.
I wish someone made a bellhousing to mate the t56
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
What is the thinnest adapter I can use without having to cut the lug nut? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-11-2016 09:32 PM
WtB short hub adapter P_say86 Want-To-Buy Requests 0 07-18-2015 08:39 PM
Adapter help lookchris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-09-2013 11:39 AM
Worksbell hub adapter!?? _F-R-S_ DIY (Do-It-Yourself) Guides 1 12-14-2012 02:27 PM
