Old 07-09-2016, 03:18 PM   #113
extrashaky
Drives: 2014 BRZ Limited
His story keeps changing in some effort to avoid sounding childish.
It's not working.
"Waaaaah! He got in front of me! Where's my mommy?"
extrashaky is offline
Old 07-09-2016, 03:23 PM   #114
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by justatroll View Post
You must not be picturing what I am describing.
Two lanes merging, both lanes have merged already] and are moving along nicely (the proper zipper merge has already WORKED).
The proper zipper merge in slow traffic is done right before the merging lane ends.
Check out the respective German law:
Ist auf Straßen mit mehreren Fahrstreifen für eine Richtung das durchgehende Befahren eines Fahrstreifens nicht möglich oder endet ein Fahrstreifen, ist den am Weiterfahren gehinderten Fahrzeugen der Übergang auf den benachbarten Fahrstreifen in der Weise zu ermöglichen, dass sich diese Fahrzeuge unmittelbar vor Beginn der Verengung jeweils im Wechsel nach einem auf dem durchgehenden Fahrstreifen fahrenden Fahrzeug einordnen können (Reißverschlussverfahren).
Or the Minnesota DOT instructions that I linked above:
it is actually much safer for motorists to remain in their current lane until the point where traffic can orderly take turns merging which is generally after the "MERGE" sign.
Motorists understand the messages and quickly form two lanes of traffic and take turns merging near the lane closure area.
If traffic merged earlier, they did not do it properly.
mdm is offline
Old 07-09-2016, 03:31 PM   #115
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
It's not working.
Your way says that is OK to SEE TWO LANES PERFORMING THE ZIPPER merge at 5 MPH but you don't think they waited long enough so you drive around them and start your OWN ZIPPER MERGE further up?
Then YOU ARE THE ASSHOLE. PERIOD.
This is a case of "My way is better! everyone else is stupid and they need to get out of my way!".
NOW who is the asshole that feels entitled?
justatroll is offline
Old 07-09-2016, 03:38 PM   #116
extrashaky
Why do you care?
The Following User Says Thank You to extrashaky For This Useful Post:
Ultramaroon (07-10-2016)
Old 07-09-2016, 03:42 PM   #117
justatroll
justatroll's Avatar
Why do you care?
Do you 'care' if you are waiting in line at the bank and someone walks right by the whole line and cuts behind the next person before the teller?
Wouldn't a normal human think "why, didn't he SEE all of us already IN LINE?"
Everyone I know would think "what a self-righteous asshole"
Old 07-09-2016, 03:52 PM   #118
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I think he never realized that if not all of the road real estate is used up in the front on the merging lanes, the queue will get backed up more and possibly disrupt the traffic flow behind where other roads intersect. It's just simple logic, and really easy to figure out if you live in a metropolitan with high volume of cars on the road during rush hour.
krayzie is offline
The Following 2 Users Say Thank You to krayzie For This Useful Post:
mdm (07-09-2016), Ultramaroon (07-10-2016)
Old 07-09-2016, 04:22 PM   #119
extrashaky
If I went into the bank and saw a bunch of people inexplicably lined up 50 feet from the teller while the roped off lane was empty, then yes, I would walk right past all of them to the proper place already marked for lining up. The fact that they decided to line up in the wrong place doesn't mean I have to also.
You're making up your own rules based on what you think is "fair." You could go to the end of the lane the way you're supposed to, but you choose not to. So why does it bother you when someone else follows normal driving etiquette instead of following some imaginary rules you made up?
mdm (07-09-2016)
Old 07-09-2016, 04:39 PM   #120
justatroll
justatroll's Avatar
Pretty self explanatory. There is zero difference in the flow rate between the early and late mergers. However early merge results in smoother flow. Third pic is what you get when you let assholes pass the people trying to zipper merge.
Old 07-09-2016, 05:08 PM   #121
extrashaky
Nah. Third pic is what you get when children worried about other people getting in front of them attempt to block a proper zipper merge. Do you carry tissues in your car for when you lose traffic?
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
Old 07-09-2016, 05:16 PM   #122
justatroll
justatroll's Avatar
"If I went into the bank and saw a bunch of people inexplicably lined up 50 feet from the teller while the roped off lane was empty"
Bad example.
In both my bank analogy AND in the situations I describe above it is completely obvious that there are a lot of people lined up, and you can see that they are lined up for the same thing (in the case of this discussion, they are lined up to take a highway on-ramp).
For you to say "You 200 cars are all fucking stupid and I am right, so I will drive around your line and form my own" make you an "asshole".
"So why does it bother you when someone else follows normal driving etiquette instead of following some imaginary rules you made up?"
Because I am doing the same thing as the OTHER 150 CARS WAITING IN LINE. It is only the rare FEW that don't see it that way and thin it is OK to pass them all on the right and wedge themselves in up front.
Where I come from they call that "special ED".
Old 07-09-2016, 05:18 PM   #123
justatroll
justatroll's Avatar
No third pic is called "Reality"
You should try it for a change.
Old 07-09-2016, 05:27 PM   #124
extrashaky
It doesn't really matter. If they lined up in the wrong place, it's their own fault if they're passed by someone who knows where to line up. They shouldn't get mad at the guy who did it correctly. If they do get mad, they should rethink the life choices that brought them to this point where they're blaming someone else for their own lack of proper driving etiquette.
Old 07-09-2016, 05:37 PM   #125
justatroll
justatroll's Avatar
@extrashaky Like I said:
"You see 150 cars performing a zipper merge in a place YOU FEEL is inappropriate, all the while traffic is moving along happily at 5 MPH. YOU choose to drive around 'all those dumbasses' and move to the front of the line"
That makes YOU the asshole.
I don't care how you try to explain it, that is the FACT.
Old 07-09-2016, 06:00 PM   #126
extrashaky
And yet that opinion doesn't change zipper merge etiquette, nor does it make me feel sorry for you when you're back there two or three cars behind me fuming, with a dangerously high blood pressure because you think you lost something. When that happens, please understand that I'm not laughing at you because you lost, but because you're behaving so childishly about an imaginary insult that simply doesn't matter.
Jaden (07-10-2016)
Timing belts suck LS1M Off-Topic Lounge [WARNING: NO POLITICS] 12 02-02-2016 12:40 AM
I suck at driving... 8km/L that sucks Mikeez Scion FR-S / Toyota 86 GT86 General Forum 105 01-02-2015 08:05 PM
these stock pads suck... Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-03-2014 01:38 PM
All my LED's installed, they suck. Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 26 04-14-2013 08:23 PM
well this may suck. Mikes86 Scion FR-S / Toyota 86 GT86 General Forum 33 12-29-2012 03:35 PM
