Old 06-29-2016, 06:46 AM   #1
ysu
Drives: Toyota 86 GTS Auto
All stock track day
I thought I'll share this - I reckon it's a good test of the stock parts.
The only mod on the car was camber bolts, camber 1.5 all around & alignment set to pretty much zero all around.
(whole album here)
Let's start off with the tyres (front) - they've seen a bit of use, huh?
And how the disc & pad should look - the rears:
And now the sobering truth about the track day pressure - the fronts.
No, those are not grooves on the disc, they are brake-pad material. Burnt & melted pad material.
Also, the edge of the disc is completely white - I'd say it got pretty darn hot
The fluid does not look too good, either.
I've sanded back the pads, they're still usable-ish. They have seen the fires of hell, cracked and battered
They wouldn't withstand another day like this. Their thickness was ~9.7mm before the day. Now they are 4.5-6mm only (unevenly worn). Half of it is gone! (fronts of course)
They'll be good as "if all else fails" spares to drive home just in case.
So yeah, after this test (I really had to see it myself) I'd strongly recommend replacing pads & fluid for tracking, especially if they're not in pristine condition as these were.
ysu is offline   Reply With Quote
The Following User Says Thank You to ysu For This Useful Post:
smg1138 (07-18-2016)
Old 06-29-2016, 08:40 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Was it your first track day?
I saw evidence enough online before i ever went to track i didnt even waste my time trying stock. I mean if you had fun great but its maybe 400-500 expense in pads and fluid to ensure your track day goes without a hitch. IMO pads and fluid minimum even for a complete novice.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
CSG Mike (06-29-2016), jvincent (06-29-2016)
Old 06-29-2016, 09:53 AM   #3
ysu
Yes, first one.
I saw conflicting evidence, hence I wanted to see what happens.
Took spare pads & fluid, but it wasn't *that* bad.
Old 06-29-2016, 09:56 AM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Good feedback.
It's great to see the actual wear that occurs if you decide to try it. I plan on going with some Stoptech street performances before I try anything at least.
JazzleSAURUS is offline   Reply With Quote
Old 06-29-2016, 01:51 PM   #5
CSG Mike
CSG Mike's Avatar
You need some brake pads!
ysu (06-29-2016)
Old 06-29-2016, 01:51 PM   #6
CSG Mike
CSG Mike's Avatar
Originally Posted by JazzleSAURUS View Post
Good feedback.
That won't fare any better than a street pad, unless you're just doing parade laps.
Old 06-29-2016, 01:57 PM   #7
JazzleSAURUS
I know we had a conversation about this before. I've been scratching my speed itch with my autox Forester recently so I haven't needed to upgrade yet.
Darn it. I want more car parts...
Old 06-29-2016, 04:10 PM   #8
stevesnj
stevesnj's Avatar
I did 2 intermediate sessions with stock tires but W2 Pads and Synth Brake fluid. The pads worked awesome, the tires not so much. Until I get proper tires to keep up with the pack I'll stick to novice sessions then when i get stickies I'll be back to intermediate sessions.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
ysu (06-29-2016)
Old 06-29-2016, 11:40 PM   #9
ysu
Yeah, I've got a set of Forza FP3 pads here, some high performance dot4 fluid; the new wheels are on the way, I'll just put some good semi-slicks on those and off we go again!
But I really had to see how things go on stock
Old 06-30-2016, 12:59 AM   #10
Whooosah
Drives: FRS
Nice! Thanks for the pics. Your rotors look just like mine after my first track day. I was glad I did my first day all stock. Great learning experience and got to see what I really needed to spend my money on. Power mods and other goodies would have been great, but after my first track day and smearing the pads it was a lot of fun doing research in brake system upgrades.
Whooosah is offline   Reply With Quote
The Following 2 Users Say Thank You to Whooosah For This Useful Post:
CSG Mike (06-30-2016), ysu (06-30-2016)
Old 06-30-2016, 12:07 PM   #11
CSG Mike
CSG Mike's Avatar
Perhaps I can be of assistance.
gramicci101 (06-30-2016), Whooosah (06-30-2016)
Old 06-30-2016, 09:55 PM   #12
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Agree with that, and in many cases, it's 'especially for a novice'. With little experience, a lot of them are pretty hard on their brakes.
dradernh is offline   Reply With Quote
Old 06-30-2016, 11:35 PM   #13
Whooosah
Drives: FRS
You hooked it up man, thanks I got the W5 and pmu fluid from you and it worked fantastic at my last track day.
The Following User Says Thank You to Whooosah For This Useful Post:
CSG Mike (07-01-2016)
Old 07-01-2016, 10:23 AM   #14
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I have them. He's right.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
track pad front, stock rear? speedy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-26-2014 10:33 AM
Stock car on the track? dejxx Tracking / Autocross / HPDE / Drifting 17 02-28-2014 08:33 PM
PIR track day stock review FRSfan111 Tracking / Autocross / HPDE / Drifting 1 08-11-2013 02:14 AM
good track tyres for the track? stock rims Rejor11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-22-2013 12:35 AM
Any stock FRS/BRZ looking to get some track time in? DNAPoPo Southern California 0 03-21-2013 03:18 PM
