Geo Tyrebighter Esq
Drives: '13 scion fr-s
Issue: Cruise Control no bump up or down
Stock FR-S. No mods. Used to work. Out of warranty.
Now, I can set the cruise at a given speed. Going uphill it will bump up 1mph and then stay there rather than coming back down to what I set it at. Bumping the + or - doesn't do anything anymore. Used to go up or down 1mph like it's supposed to do in the manual. If I hold the lever it will move, but I often pass by the 1mph I wanted. Any ideas how I can get it working again? Lint in the framistat? PB Blaster all over under the dash? Has this been heard of before? Ok. Take it to the dealer and hand over lots of cash that's in short supply I suppose.
"I gotta rock." -- Charley Brown |
#2 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Unplug battery for 10min or so. Replug in. Try it at different speeds. See if there's a difference.
Somewhere in another thread it says cruise control wont work if theres something wrong with your car. Edit: Here ya go http://www.ft86club.com/forums/showthread.php?t=16726
| The Following User Says Thank You to Packofcrows For This Useful Post: | humfrz (06-11-2016) |
#3 |
Geo Tyrebighter Esq
Cruise works in a basic fashion. No CELs or codes that I'm aware of.
It won't increment up or down. I've got a post cam fix twin.
#4 |
Drives: 2005 Toyota Camry
http://www.ft86club.com/files/BRZwiringi.pdf
Page 109 clearly shows the wiring of the cruise control main switch. Since there's only two wires, I'm guessing there is a specific amount of voltage drop or signals that tell the car of each setting for cruise purposes. My guess at this point is a malfunctioning cruise control main switch, assuming the ECU is properly flashed with no CEL. CEL will actually result in the cruise light on the dash being constant yellow instead of green. -alex |
#5 |
Country Boy 4 Life
Short story.
My buddy is a mechanic. He says he sprays a few squirts of Electrical switch cleaner into the ignition, or any switch that is having problems. 90%of the time, he says it fixes it. I have used it on the ignition of an old civic I had. it worked. I have not needed it on the FR-S yet. I'd choose the brand you trust. I have some CRC. https://www.google.com/webhp?sourcei...itch%20cleaner |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 08:37 AM |
| CEL and Cruise Issue??? | mortybryant | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-23-2015 02:49 PM |
| Cruise Control | nospoons | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 06-17-2014 03:28 PM |
| Cruise control | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 05-13-2013 03:01 AM |
| cruise control and speedo issue.. | tibsy92 | Issues | Warranty | Recalls / TSB | 1 | 10-10-2012 01:21 PM |
