Old 06-10-2016, 12:47 AM   #29
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by NOHOME View Post
I was quite impressed when I read that. However we perhaps should not base expectations on the achievements of one outlier.
The breakthrough will come when a talented person packages the solution into a product that will sell at a price that provides value to the market and makes him money. That is known as market disruption and something that we as consumers can look forward to. I myself am patiently waiting for the universal can-bus translator that will work with any car by running the entire code through a Rosetta stone like decoder.
I work in an industry where everything we do was impossible or magic just two years ago. By the time we are done, its just another Bic lighter.
Im hoping to receive it soon.
cf6mech is offline   Reply With Quote
Old 06-10-2016, 01:03 AM   #30
bradsm87
Drives: It has 4 wheels
See the "Canbus Translator" product here:
https://www.facebook.com/AGTEngineering/
bradsm87 is offline   Reply With Quote
Old 06-15-2016, 07:14 AM   #31
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by Spartarus View Post
One more at the moment: CXRacing makes several inexpensive hardware-only kits, from mounts to headers.
Vorshlag does good work, but their kit is yet unreleased. They've had issues integrating the ECU for a little over a year now.
WGP will give you the hardware, but has a bad history with quality control and post-purchase support, and they don't have a real solution for engine management or integration with the stock systems / CANBUS.
At the moment, the only real options for intergration and engine management are Motec and Emtron. Emtron is reasonably priced.
There are no off-the-shelf wiring solutions, despite the half-truths you may get from WGP.
There are several companies working on CANBUS "translators" to use OEM ECU's, but none are ready.
Hi, the hydra EMS could be use with 6 and 8 cylinders engines.
Edit: keeping all electronics working.
That's one of the reasons I buy, first I can tune the FA20 as desire and if some day the swap materialize the ECU thing is already there...
AJPG is offline   Reply With Quote
Old 06-15-2016, 11:28 AM   #32
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by 1800bigk View Post
Thanks man, cx not the best rep either from other platforms I will take my time see what happens
true but Cx's downfalls as far as I know stem from moving parts. There hard parts while not the best have been stated to be decent/acceptable.
fumanchu1 is offline   Reply With Quote
Old 10-02-2017, 01:31 PM   #33
Jgalle17
Drives: Frs
I really want to built a frs or brz but don’t know what engine swap. Im between ls swap or a 2jz. Any recommendations with engine swap is better?
Jgalle17 is offline   Reply With Quote
Old 10-02-2017, 04:38 PM   #34
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
What is your power goal? What is your target application for the vehicle; drag?, drift?, track?, street?, etc
A lot of the 2jz swaps I've seen seem to be focused on huge power and most being drag setups. Personally I think LS is a bit easier, engine fits nicely in the bay with no mods to firewall or radiator mounting.
wutsaiu is offline   Reply With Quote
Old 10-05-2017, 10:52 AM   #35
Jgalle17
Drives: Frs
I would want it for street. And have pretty much 400-450 hp.
Old 10-05-2017, 11:26 AM   #36
Ramn
Ramn's Avatar
Drives: 2015 GTI
LS will get you there easily. If you’re not shooting for more hp then there is not much of a reason to go 2JZ.
Ramn is offline   Reply With Quote
Old 10-05-2017, 04:25 PM   #37
Jgalle17
Drives: Frs
Originally Posted by Ramn View Post
LS will get you there easily. If you’re not shooting for more hp then thereis not much of a reason to go 2JZ.
Thanks guys for the help
Old 10-10-2017, 12:57 PM   #38
NOHOME
Drives: RAVEN
Curious as to what the state of the art is for the rear end when doing a Ls swap?Are most people getting away with the factory parts? That would be a huge savings. When I did the Miata V8 swap, even the low-buck 8.8 conversion stuff was over 2K and some fabrication effort that has to come-out right.
NOHOME is offline   Reply With Quote
Old 10-10-2017, 01:25 PM   #39
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Running stock end on mine with over 500whp with no issues so far. Stock Diff seems to be fine as long as you aren't launching hard on big slicks. The 8.8 swap is 5K for this chassis haha
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 11:19 PM
2jz swap p3raltaboi Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2014 09:09 PM
Key Fob Swap joergasm BRZ First-Gen (2012+) — General Topics 1 10-03-2012 12:40 AM
