#15 | |
Drives: anything you let me
Beautiful work Zeal! Any chance you could do me a huge favor and get 2 quick measurements? The distance between those pins on the Beatrush bar and the depth from the driver side pin to where the Beatrush meets the frame? I'm planning to fabricate my own and curious on material dimensions before pulling the car apart. Thanks! |
#16 | |
Drives:
__________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | Uplink (03-17-2016) |
#17 | |
That's actually a good deal compared to the Beatrush if it's going to be hidden and actually gives me great direction, thanks. The only concern would be that you don't have mounting location for the plastic air dam below the snorkel. I forget the review (maybe Perrin?) but they said without that the air turbulence near the snorkel actually robbed performance from a NA twin. |
| The Following User Says Thank You to Uplink For This Useful Post: | olsonpg (03-17-2016) |
#18 | |
Thank you, much appreciated! And I just got a Dunkin Donuts visual of... 'Time to polish the aluminum...'
#19 | |
"The next test was removing the plastic air diverter which rests between the fresh air scoop and the lower portion of the bumper. This part is installed to help block some of the air from blowing up and around the radiator. With the diverter removed, there was a nice steady noticeable amount of air flow coming from the scoop at 1.5MPH. This sounds like it would be a great way to make our intake system get a little more flow and cool air, or would it After testing this on the road, we found this was a really bad idea. The added pressure and airflow while driving at 45MPH or more would cause the car to run poorly and actually die if you push in the clutch! So the plastic diverter got re-installed and the PERRIN intake would be designed around utilizing this part." |
#20 | |
Drives:
#21 | |
Drives: Whiteout RBv1 FRS
#22 |
Drives: scion fr-s
#23 |
That does look really clean!
#24 |
Drives:
The 86 is looking sharp!
Btw, a Dremel will work just fine to grind down the tabs... what also works well and provides a lot of control and a clean cut are flush cutters. I have used both methods...how much material I plan on eliminating determines my method. Dremeling is obviously better for grinding out a curve. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
#25 | |
Drives:
#26 |
Drives: 2013 Scion FR-S in White
#27 |
Drives: FRS
thats the super street "ratchet bunny" frs. i doubt anyone from superstreet (namely the editor) is on this forum
#28 | |
Drives: scion fr-s
| Is the FRS front grill removal? | mit_peid | DIY (Do-It-Yourself) Guides | 23 | 02-27-2016 12:00 AM |
| front grill | PipeLovoo | Exterior Parts (Aero, Lighting, Etc.) | 8 | 05-28-2014 10:11 AM |
| front grill | PipeLovoo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-21-2014 11:53 AM |
| BRZ Front Grill Photoshop | mikeTee | BRZ Photos, Videos, Wallpapers, Gallery Forum | 16 | 11-16-2013 05:18 AM |
| Front bumper grill. | |-Goku-| | Issues | Warranty | Recalls / TSB | 20 | 09-04-2012 07:42 PM |
