Old 05-10-2016, 04:17 PM   #491
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by Tectoniic View Post
Because I still don't know how to link a single post.....
Look at steve's post about halfway down this page it explains KC Learned better at least for me than in the OP
http://www.ft86club.com/forums/showt...01#post1842501
If your IAM is staying at 1 your ECU is not pulling any timing due to either no knock or a very insignificant amount of knock.
While +/-3 is pretty good for LTFT keep an eye on this to see if it starts creeping up. Your LTFTs should reset a bit after a flash and as they average more and more data you may see them get back up to the +/-7s you were having before or it could just be 91 still in the tank or a different E%
Yeah I've been keeping a close eye on the LTFT's every time I drive the car. The KC Learned is what sparked my interest because it was something other than 0.0.
Instagram: trevor.parque
Old 05-10-2016, 04:18 PM   #492
steve99
Drives: FT86
I just found it weird that it never happened before.. Good to know I shouldn't worry and I should only be worried once IAM fluctuates and FLKC fluctuates more than 1.
KC learned always varies its the amount of knock correction timing available to the ecu at any given load/rpm point, its the value in the Knock Correction Max A table multiplied by IAM then add FLKC (which is usually negative).
The only time KC learned would be always zero is if your IAM was 0 , which would not be good :-)
Old 05-10-2016, 04:22 PM   #493
MisterSheep
Killed Scion
Thanks, I was getting ready for detonation in my future honestly it's great to have someone on this forum that helps out as much as you do
Old 05-15-2016, 10:58 PM   #494
MisterSheep
Killed Scion
Just fueled up at a new e85 station and now im seeing my ltft at idle between +9% to +13% and when im about 5% throttle its around +3% and with 10% to full throttle its staying at 0.00%. I guess this new station has higher ethanol content than that last station but the idle at +13% for ltft kinda scares me. Should i only be worried if i see any higher while on throttle? Or is +13% really high for idle?
Old 05-16-2016, 01:51 AM   #495
steve99
Drives: FT86
don't worry too much about ltft at idle and low rpm, its beat if its below 10% but at idle low rpm its not rearly going to hurt anything. It will vary a bit with ethanol content and also big intake temp changes you get in traffic.
LTFT is the amount of correction applied to get the required AFR.
look at your commanded AFR vs measured AFR (AFR)
cruising around 14
mild acceleration 13
hard acceleration 12 to high 11
Old 05-16-2016, 11:53 AM   #496
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks for these guides @steve99 and dealing with people who can't read, now that a new e85 station has opened up only 10 minutes away I will surely be running e85 daily throughout the summer
Old 05-17-2016, 06:27 PM   #497
FRSBRZGT86FAN
Run through 2 tankfuls of e85 so far and the difference is astounding, can't imagine this car once I get 4.88 gears.
Old 05-25-2016, 07:58 PM   #498
StayPuft209
StayPuft209's Avatar
Drives: Firestorm FR-S
You ran through two tank fills in a day?? Holy cow, I was thinking of running e85 but not if it burns up that fast.
StayPuft209 is offline   Reply With Quote
Old 05-25-2016, 08:55 PM   #499
FRSBRZGT86FAN
I've been flogging it down back roads it's so addicting
Old 05-26-2016, 07:27 PM   #500
StayPuft209
My question to you is, if it's really worth it? On a side note did you try a regular 91 stage 2 tune? If so hows the difference
Old 05-26-2016, 08:22 PM   #501
steve99
Drives: FT86
on E85 you will get about 25% worse fuel economy than petrol for same driving style
From 91 to E85 no ther changes (just tune)you will pick up about 15 hp throughout most of the rpm range noticeably more torque and smoother
Old 05-26-2016, 09:20 PM   #502
FRSBRZGT86FAN
Are you kidding? Did you not read anyone elses stuff?
Of course it's worth it, with my uels and nameless axleback I have to be getting around 180-200 whp. It feels totally different and the car is alive now in most of the rpm range
Old 05-27-2016, 03:59 AM   #503
StayPuft209
Yeah I like to listen to everyone's feedback. I've been meaning to give it a try but just haven't gotten around to it... the closest e85 station to me is about 26 miles away so about 30 mins or less from where I stay.
Old 05-27-2016, 01:26 PM   #504
FRSBRZGT86FAN
26 miles away is kind of tough, you'll need to refill at about a quarter of a tank to make sure you can make it there
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
