Old 05-15-2016, 02:05 AM   #29
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Originally Posted by kev60625 View Post
http://www.emeraldintegrations.com/c...ra-system.html
I bought this one and installed it today. I have absolutely no experience with stuff like this, nor with running wires and found it very straight toward and easy. I had an issue feeding a cable at first, but realized I was feeding the wrong cable..
This.
I did a lot of research, and this turned out to be an awesome plug and play kit - a little pricey but I was looking for as close to OEM as possible, and this is it. The camera is heavy in your hand - just feels like a solid piece, and the image is amazing.
A funny - I thought I'd f**ked the install somehow though - first reverse test showed me the top of a 60' tree in my yard and a shitload of blue sky.
No worries - trunk was open.
Whew!
geezerbrzeezer is offline   Reply With Quote
The Following User Says Thank You to geezerbrzeezer For This Useful Post:
rastapete (05-15-2016)
Old 05-16-2016, 09:23 PM   #30
Djratrap
Drives: BRZ CSB Limited
Originally Posted by ThornhillSubaruOwner View Post
How is the camera? I don't really want to pay hundreds of dollars for a backup camera. Is it durable? (heavy rain, strong winds, high pressure car wash?)
Also, which harness did you buy?
EDIT: Wow, it doesn't ship to where I live, Canada.
Anyone know if this is any good?
https://www.amazon.ca/Car-Rover-Rear...productDetails
So far the camera is good, no complaints. I've taken the car through a no touch high pressure wash and no problems. The camera is nice because it doesn't fog up, so you can still back up if your rear window is fogged/iced in the morning. Also it's so cheap that if it does break, it wouldn't break my bank to buy a new one.
I'm using the autoharnesshouse.com harness. It was plug and play, no splicing.
Djratrap is offline   Reply With Quote
Old 05-17-2016, 03:50 PM   #31
kevroq
Drives: 15' Dark Mettallic Gray BRZ Manual
I just installed the raydeen duo to my aftermarket head unit. Build quality is really good and no complaints about the picture quality. I think picture quality of all of these are about the same so really your paying more for the build quality. Also, keep in mind that some of these come with the parking lines and some do not. The raydeen has the ability to turn the lines off by connecting two wires. This is good if your head unit already has the lines.
Sent from my SM-G930V using Tapatalk
kevroq is offline   Reply With Quote
Old 05-17-2016, 03:58 PM   #32
DGM-BRZ
DGM-BRZ's Avatar
Drives: 2017 CWP STi
Does your backup camera have the guiding lines?
DGM-BRZ is offline   Reply With Quote
Old 05-18-2016, 05:38 PM   #33
Djratrap
Yes, but they are easily disabled. You can also flip the image.
The Following User Says Thank You to Djratrap For This Useful Post:
DGM-BRZ (05-18-2016)
Old 05-18-2016, 10:03 PM   #34
DGM-BRZ
DGM-BRZ's Avatar
Talking
Perfect, I guess I know which one I'm buying
The Following User Says Thank You to DGM-BRZ For This Useful Post:
Djratrap (05-19-2016)
Old 05-19-2016, 01:07 PM   #35
Djratrap
The most difficult part of the install was guiding the camera wire through the trunk (metal coat hanger) and getting the end of the camera plug through the rubber trunk grommet. I'd recommend using some type of lube fore that, as the grommet is VERY narrow (insert sex joke).
Also if you ever thought about installing a factory sub/oem audio plus, it would be a good time to do so, since you'd be using the same wiring route.
Old 05-19-2016, 01:20 PM   #36
DGM-BRZ
DGM-BRZ's Avatar
I'm most likely going to get professional help to install my Tail lights and might as well ask him to do the backup cam as well. I'm on a lease and I don't want to screw anything up. (I do plan to buy the car, but just in case)
Old 05-19-2016, 02:53 PM   #37
Djratrap
Tail lights are very simple, plug and play. i wouldn't waste the money on the tails. the camera on the other hand, might be a bit more work.
DGM-BRZ (05-19-2016)
Old 05-19-2016, 05:47 PM   #38
techie182
Drives: 2013 FRS
Installing backup camera is not hard as you think.
Finished installing mine.
Installed backup camera with 2 parking sensors attached.
Total cost was $50 with hardness.
That rubber grommet on trunk is no joke. I gave up and zip-tied my wires.
BTW FR-S don't come with trunk lid liner?
Its bare metal on mine. I need to find way to tuck in my wires.
techie182 is offline   Reply With Quote
Old 05-19-2016, 05:50 PM   #39
kevroq
Do you have a link to the parking sensors and photos of the install by chance?
Old 05-19-2016, 06:09 PM   #40
DAEMANO
Time Traveller
Don't know if you need this, but kits for this are on eBay all day for $60-$70 including clips.
http://www.ebay.com/itm/Genuine-Suba...item1e9e1d777e
Old 06-07-2016, 11:52 PM   #41
DGM-BRZ
DGM-BRZ's Avatar
Sorry gotta bump this topic again.
Anyone have any other back up camera recommendations aside from Rydeen Duo? I was going to try the one from China but it doesn't ship to my area.
Looking for something that doesn't require drills/holes, has decent quality, fairly priced.
Thanks
Old 06-08-2016, 12:52 AM   #42
geezerbrzeezer
Geezer
To defeat the rubber trunk grommet - tape the cable end, pour in a little bit of liquid soap for lube, fasten a long zip tie to the cable and pull it through - literally took 30 seconds, the cable will slide right through even with the existing ones clogging up the path, and according to what I read, soap will not degrade anything.
tobin (06-08-2016)
100% Plug-&-Play Rearview Camera Installed from camera-source.com (Pics) zthang DIY (Do-It-Yourself) Guides 10 12-18-2015 05:14 PM
Few questions I could not google-fu answers for on rearview camera... N757QQ Electronics | Audio | NAV | Infotainment 12 03-01-2015 02:29 AM
Rearview camera without drilling holes sav Electronics | Audio | NAV | Infotainment 41 08-16-2014 02:27 AM
