| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3095 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Looks good to me, should give you no issues
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#3096 | |
Drives: 2015 Scion FR-S
After all, the car is just an 1" drop on stock struts and it's practically for daily drive usage. I just want some nice set of wheels/tires without having to worry about rubbing though a staggered set up may cause the tire to wear out faster over a square set up. If I ever decide to track the car or go with a bigger/wider wheels then I'll consider coilovers w/ camber adjustments and indeed do square. |
#3097 |
Drives: 2015 BRZ Limited MT
Could anyone give me some advice on fitment for the following setup on stock suspension, and also a what-if on a 1" spring drop?
front: 18x9 +35 - 225x40x18 rear: 18x9 +20 - 225x40x18 |
| The Following User Says Thank You to pancake For This Useful Post: | LANI86 (09-19-2016) |
#3098 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
alright guys, i am new at tires. i want to know if both these tire sizes fit on stock wheel and stock height? 235/45/17 or 245/45/17 or 235/40/17, 245/40/17 which is better? i do autox and drag once in a while, so i want to rubbing, just enough clearance. thanks in advance
#3099 |
Drives: '13 BRZ 6MT Limited GBS
Fitment Question
Hey what's going on guys? I'm sitting on stock suspension atm but am getting Tein Street Basis Coilovers in the near future. I'm looking at doing a squared setup with 18x9.5+35. And was wondering which tires would be best suited to get a properly fitted look (not into the stretch look) and not rub on OEM height. 245/40/18 or 245/35/18. Thanks in advance for your help!
#3100 | |||
Looks way better when lowered 1", is about flush then (rear +20 may poke a bit depending on camber). Quote:
245/45/17 is +4.3% off in diameter from factory setup 235/40/17 is -0.9% off in diameter from factory setup 245/40/17 is +0.4% off in diameter from factory setup Your goal is to be as close to the factroy diameter. However the 7" wide stock wheels are not ideal to host 235 or even 245 wide tires... If you have to choose one of them, I'd rather take 235/40/17 My suggestion however would be 225/45/17 (+1.4%) on the stock 7" wheels. If you want 245 tires, I would at least go for a 8" wide wheel Quote:
| The Following User Says Thank You to Killerbee For This Useful Post: | pancake (05-13-2016) |
#3101 |
Drives: 2015 Subaru BRZ TS GT
Hi, i really want to buy some Enkei NT03+M's, 18x9.5 +40 all around in 225x40x18 tyres.
However, I'm worried about fitment and rubbing and was wondering if this could work. I'm lowered 1 inch on STI springs only. |
#3102 | |
Thightest I've seen was a 18x9.5 +38, and that was very very tight already. Your's is another 2mm more inside. Also, 225 on 9.5" wide wheels is generating alot of strecht, I would not advise to do this (you can, its just my opinion that you should not)
#3103 |
thanks for the quick response and for clearing up my inquiries. Looks like ill get 88.5 inch whees instead for now.
#3104 |
Drives: 2014 Subaru BRZ
#3105 | |
Thanks man!
Can't wait to get these installed soon, appreciate the help!
#3106 |
#3107 |
Drives: 2015 FRS
Hey guys quick couple questions for you. So I will be swapping my stock wheels out for a 17x9 (still debating) preferably the RPF1s if money allows. I am a little confused when it comes to the tire selections on these small cars. I am really looking for function over looks but would enjoy the idea of a wider tire than stock. I am not much for the stretched look, so what would be my best options? Is the 225/45/17 going to be my best bet or could I get away with something wider. The reason I want to stick to 17s is due to the weight for autocross and retaining the sporty driving. Would going to an 18 be that big of a difference in the handling? I think 17s suite me personally better as the car is daily driven and not sure I wanna cough up money for low profile 18s every few months. Would I be better off with a 17x8 and just have a custom set made with that 35 offset (clear future BBK)? The car will be dropped in the near future on the TRD springs until I can afford a nice pair of coilovers. Any help would be greatly appreciated, I have scoured the threads only to be left more confused then when I started.
After looking some more at the calculator would 245/40/17 be a better choice? |
#3108 | |
soo... to give you a full recommondation, you have to talk about all the mods. I'm missing the offset of the 17x9 wheels, you noticed something +35 for a 17x8, so I guess you have the same on the 17x9. This will stick out in the front a bit, specially when not lowered. Nothing drastically, but so you know. Now my answer is only covering your tire/wheel " question, not fitting, so if you give me your full fitting plans I can comment on that aswell. Generally, on a 9" wide wheel I would suggest 245 tires. Either 245/40/17 if on 17" wheels, or 245/35/18 if on 18" wheels. This will be about "flush" with the wheel. 225 will be slighly stretched. The difference between an 17" and 18" is pretty small. If you're not a professional driver, you will neither notice a difference, nor improve your time on a track depending on this choice. While they are lighter in theory, practically if you compare the same wheel in 17 and 18" its very little, and nothing you notice while driving. However, if you buy a super lightweight wheel in 17", and compare it to a shitty heavy weight 18" wheel, yes, it makes a difference, and I guess this is mostly where the "only 17" for track" voices come from. Tirewise, it is only 5% less tireflank, so its neither that much more expensive, nor is it that "low profile". We are talking about an about 10cm high tireflank on an 17" tire, or 8.5cm on an 18" tire, so its not that big of a deal. 17" or 18" choice should be by what you like more from an optical point of view. Performance wise its sooooo little you will only notice it if you drive professional on a racetrack, and price wise its also not that big of a difference. Hope this helps a bit, cheers
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
