Old 05-10-2016, 12:15 AM   #1
TexasFRS
Gear shifting
Do all FRS' make a clanking noise when shifting gears? Or is this just that mine? 😅
TexasFRS is offline   Reply With Quote
Old 05-10-2016, 12:19 AM   #2
NP86GT
Drives: 2012 Toyota 86
I don't know if I would call it "clanking" but I can definitely hear mechanical shifting when changing gears.
NP86GT is offline   Reply With Quote
Old 05-10-2016, 12:21 AM   #3
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Uh...mine doesn't!
billwot is offline   Reply With Quote
Old 05-10-2016, 01:22 AM   #4
Impureclient
Drives: 2015 FR-S
Originally Posted by billwot View Post
Uh...mine doesn't!
Me neither? *Secret handshake
Old 05-10-2016, 02:25 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes they all make a bit of noise. Not a grinding noise but nice mechanical actuall gear change. One of the first issues everyone noticed about manuals.
You'll be fine. One thing many people do is changed tranny fluid to some pricy gear oil like Motul, Redline, Amsoil, etc. Pretty much everyone is on the same page that switching fuilds made shifting smoother. And on cold days/warm ups 2nd gear is a bit of a struggle to get into but smooth as butter once it's up to temp.
Old 05-10-2016, 02:43 AM   #6
Do all FRS' make a clanking noise when shifting gears? Or is this just that mine? ��
Well, hello, TexasFRS and welcome to our fine forum........
I figure you have a manual transmission ..... ??
If so, yes, the transmission does make some "mechanical" sounds when shifting gears. In the FRS it's more noticeable because of the "light" insulation and because the driver is sitting right next to the transmission.
Also, the shift lever is almost directly in contact with the gears.
Here is my stock suggestions for shifting the FR-S:
First off, this transmission is happier when it is warm.
I would suggest that when shifting, wind up the last gear pretty tight (4-5,000 rpms) before shifting into the next higher gear.
Also, when shifting, pull (or push) the shift lever slowly and firmly into the next gear.
It's not a toggle switch ..... the lever is moving heavy transmission parts.
I suggest you NOT "lazy leg" it ……. do push the clutch pedal all the way to the floor.
If this technique doesn't help, you may consider changing the transmission oil.
Cole (05-10-2016), jcw99 (05-11-2016)
Old 05-10-2016, 06:39 AM   #7
dnieves
Drives: FR-S 10 Series
No clanking noise on mine.
dnieves is offline   Reply With Quote
Old 05-10-2016, 07:18 AM   #8
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
I just hear the mechanisms moving around like they should. It sounds different from this.
The Following 4 Users Say Thank You to themadscientist For This Useful Post:
chaoskaze (05-11-2016), daiheadjai (05-11-2016), krayzie (05-10-2016), Tcoat (05-10-2016)
Old 05-10-2016, 09:34 AM   #9
TexasFRS
Thank you guys for replying I was a little worried this is my first manual car
Old 05-10-2016, 12:21 PM   #10
billwot
Yeah, I think we had that figured out!
Old 05-10-2016, 12:30 PM   #11
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Mine doesn't.. maybe you should take yours back?
Instagram: trevor.parque
MrFisty (05-23-2016)
Old 05-10-2016, 12:35 PM   #12
Teseo
Drives: frs
Totalled.
The Following 2 Users Say Thank You to Teseo For This Useful Post:
MisterSheep (05-10-2016), SlammedSilly (05-10-2016)
Old 05-10-2016, 12:45 PM   #13
PureShield
PureShield's Avatar
Originally Posted by Teseo View Post
Totalled.
Part out?
PureShield is offline   Reply With Quote
Old 05-10-2016, 12:47 PM   #14
PureShield
PureShield's Avatar
Your fine. The gearbox in the 86 is really notchy and has a mechanical feel to it.
The Following User Says Thank You to PureShield For This Useful Post:
humfrz (05-10-2016)
transmission gears
Jolt in AT shifting to second Gear at 7000rpm jxl00 Issues | Warranty | Recalls / TSB 9 04-08-2016 07:32 PM
Shifting from 1st-2nd gear... FRSpappa Engine, Exhaust, Transmission 13 05-24-2014 11:06 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 01:13 PM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 04:54 PM
Clicking shifting 2nd gear and R radroach Issues | Warranty | Recalls / TSB 0 03-16-2013 12:36 PM
