Old 05-07-2016, 12:33 PM   #519
Noxcyn
Noxcyn's Avatar
Drives: '15 Scion FR-S - Ashphalt (MT)
Originally Posted by B-R-Z View Post
That's the thing, is something I may not or hardly even notice worth having to nurse the tune with logging every X weeks and having to be more concerned about gas quality? My engine feels super peppy and powerful as it is, and it runs healthy. Idk, I'll sleep on it I guess.
Once i logged it a few times and see the knocking is not an issuee (i pump 91 and could pump 93/94 if i really wanted to)
The knock is very little and minor. Some logs have no knock at all. I dont log any more really it was mostly at first cause some people get crazy knock from what ive seen so in imo its worth it.
Noxcyn is offline   Reply With Quote
The Following User Says Thank You to Noxcyn For This Useful Post:
B-R-Z (05-07-2016)
Old 05-07-2016, 01:03 PM   #520
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by WRBrzRX View Post
yes, update yours, it feels closer to e85 down low, it made me switch back permanently until track days
I'm confused. It sounds like you're saying it's good, yet you switch back (to the old tune?) permanently on track days?
B-R-Z is offline   Reply With Quote
Old 05-07-2016, 02:32 PM   #521
WRBrzRX
Drives: runs&drives
sorry, I dont have any reason to switch off of 93 until track days when Ill load up an e85 map
WRBrzRX is offline   Reply With Quote
Old 05-08-2016, 09:57 PM   #522
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
Here's another log I did today
Again, I'm running JDL UEL catted header, don't feel any issues with car, and I'm still a beginner when it comes to all things tuning. I know knock is bad, but don't know why, etc.
Let me know what you see, it was a short drive. If there's some tips on how I should be running the car when I log so it can be more informative for logging purposes.
Thanks for all the help!
http://www.datazap.me/u/pinetree/sta...og?log=0&data=
pinetree is offline   Reply With Quote
Old 05-08-2016, 10:24 PM   #523
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
You really need to log RPM and don't log the o2s2 (since it stays at 0 all the time in your logs anyway)
DocWalt is online now   Reply With Quote
The Following User Says Thank You to DocWalt For This Useful Post:
pinetree (05-08-2016)
Old 05-08-2016, 10:35 PM   #524
pinetree
pinetree's Avatar
I'll keep that in mind next time I log, thanks!
Old 05-09-2016, 12:20 AM   #525
alchemy
Drives: 86 GTS 2015
Hi there,
Any idea when us Australians get to put the new tunes on our cars?
Cal ID is D00G
Currently running OFT stage 1, getting OFH soon and would love to put on the updated Stage 2 map!!
alchemy is offline   Reply With Quote
Old 05-09-2016, 01:00 AM   #526
Ginosaur
Drives: 2015 Toyota 86 GTS Manual
Originally Posted by alchemy View Post
Hi there,
Cal ID is D00G
HAHA I check here everyday if D00G has been updated with the launch control function
Ginosaur is offline   Reply With Quote
Old 05-09-2016, 01:47 AM   #527
steve99
Drives: FT86
Hi there,
Cal ID is D00G
Anyone on 98 ron fuel would be better copying tge tables out of @Wayno s example tunes as they have latest cam timing adjustments as per the usa ofh tunes an lots of other tweaks and ignition timing specificly for 98 ron fuel
just use romraider to copy over changed tables
dont hold your breath for lc\ffs mods to d00g roms though though
Old 05-09-2016, 10:51 AM   #528
alchemy
Drives: 86 GTS 2015
@Ginosayr I am literally the EXACT same, lol I literally check these every day hoping that D00G has been updated with launch control
@steve99 I was always told that I should put nothing in my car other than tunes that come from the open flash guys, are Wayno's example tunes as good as the current updated USA stage 2 tunes? I'm just being critical because there's no dyno charts or anything to prove the credibility of wayno's adjustments? (with all due respect to wayno of course)
Old 05-09-2016, 11:40 AM   #529
steve99
Drives: FT86
Yes they have latest AVCS cam adjustments, ignition timing for 98 etc.
their based on oft maps
unless your A01G or A01I you will have to transfer the tables across into your rom calid.
yes you have to be carefull with matching defs and oft tunes.
dyno see here from club dyno day. The OFT tunes making the best hp were tweaked by wayno and one myself
http://www.ft86club.com/forums/showthread.php?t=91909
Old 05-09-2016, 01:19 PM   #530
GT86Dan
GT86Dan's Avatar
Drives: 2013 scion frs
So complete tuning noob here. Read through 20+ pages I will be finally uploading the OFH tune today. Im running the grimmspeed intake and gruppe-s header. Anything i should be looking out for ?? I will data log this coming week as well.
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you. Jeremy Clarkson
GT86Dan is offline   Reply With Quote
Old 05-10-2016, 05:14 PM   #531
steve99
Drives: FT86
Read the links below on logging and flashing reset learning
Old 05-10-2016, 10:20 PM   #532
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
OFT only reads engine fault codes
I suspect its a code related to can buss error, possibly due to oft comms interrupting can buss at some time can happen if you plug in or remove oft when engine running. its likely P0700 or P0155 from memory.
If you have torque app and a Bluetooth adapter torque will clear all codes.
or just disconnect a battery terminal and press brake pedal then reconnect battery should clear it.
But you will reset your fuel trims and likely get the dead throttle pedal for a couple of drive cycles
This just happened to me. I unplugged the OFT while the car was running and got the check engine light. There's no other way of getting rid of it other than unplugging the battery?
eSOLOR is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 12:56 PM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 01:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 02:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
