Old 05-05-2016, 01:49 PM   #15
Worstenemy453
Drives: 2013 Argento FR-S
I get a vibration during braking that I am assuming is rotors. I'll check them out. But I heat these rotors up quite a bit. I practically drive like it's auto x every day.
Sent from my SM-N900V using Tapatalk
Worstenemy453 is offline   Reply With Quote
Old 05-05-2016, 02:41 PM   #16
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Do you mind explaining why you didn't like the HC+800? At $70 cheaper for a set the HC's were probably going to be my next pad over the DS2500.
In order to be on-topic; have fun OP:
http://www.ft86club.com/forums/showthread.php?t=23680
Most of the usage in that thread is way overkill for your needs. Buying rotors without measuring the thickness of the existing ones is like replacing headlights once a year so they don't burnout on you unexpectedly, despite the fact that most last well over 5 years.
Only the hardcore track guys are using up rotors quickly on this car, most people are sailing past 60k miles on OE rotors even with occasional track and frequent autox usage.
http://www.ft86club.com/forums/showp...&postcount=175
at 12K the rears where shot too...
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
strat61caster (05-05-2016)
Old 05-05-2016, 04:43 PM   #17
CSG Mike
CSG Mike's Avatar
OP what exactly are you doing with the car?
I would add Carbotech AX6 and G-Loc R6 to that list of pads to consider.
Old 05-05-2016, 04:48 PM   #18
Worstenemy453
Very aggressive back road driving. My car sees the abuse that most weekend auto x guys will see. I just want the least dusty pad that will last a decent while and stop the car. I have had enough heat in my brake pads during spirited daily driving that I have noticed the faded stopping power.
Old 05-05-2016, 05:08 PM   #19
Tokay444
HPS were the absolute worst pads I've ever run.
I can't comment to the other two choices.
Old 05-05-2016, 05:11 PM   #20
jasonojordan
Drives: 2013 satin white brz limited
I have hawk hp+ ive done some spirited driving runs. Never had any issue with fade but as commented above they dust like crazy and squeal when not at operating temp(so 80% of the time its driven)
jasonojordan is offline   Reply With Quote
Old 05-05-2016, 05:30 PM   #21
CSG Mike
CSG Mike's Avatar
Try the G-Loc R6, front and rear, with upgraded brake fluid.
Worstenemy453 (05-05-2016)
Old 05-05-2016, 06:14 PM   #22
Worstenemy453
Good enough. I have some motul 600 fluid laying around.
The Following User Says Thank You to Worstenemy453 For This Useful Post:
CSG Mike (05-05-2016)
Old 05-05-2016, 06:21 PM   #23
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yeah, HC+800 dust quite a bit. Thats why i like black wheels lol
Brake Fluid Question... Lebby83 Tracking / Autocross / HPDE / Drifting 2 11-02-2015 11:15 AM
Brake Warranty Question... Uplink Scion FR-S / Toyota 86 GT86 General Forum 43 05-08-2015 12:53 PM
STR 660 Brake Fluid Question babykwiss Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-25-2014 01:00 AM
Brake fluid question barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-01-2013 12:08 AM
Brake flush question... N_I_N Tracking / Autocross / HPDE / Drifting 18 06-09-2013 08:13 PM
