Old 04-28-2016, 04:17 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Surakusa View Post
Appreciate it bro.
Sorry we tried If anything you can shop around to different dealers
Old 04-28-2016, 05:45 PM   #16
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Originally Posted by FRSBRZGT86FAN View Post
I know this because for the longest time I had techstream on my laptop and tried it on a friends celica with an alarm issue, even with a pirated copy it doesn't work, it requires the physical toyota tech stream login and tech number
Just to be clear, you couldn't even log into the tech stream? Or you made it in, but registering codes requires you to provide actual credentials?
Known do-it-yourself mechanic. "If you have the drive, you can learn..."
"The left lane is meant for fast passes, not slow asses..."
Surakusa is offline   Reply With Quote
Old 04-28-2016, 05:52 PM   #17
FRSBRZGT86FAN
Techstream is the software, they also have an online system called techinfo which is what I used to get TSBs to upload to the forum several time, it's also where the service manuals and other stuff like key registration are. Its a $50 subscription I believe, but even then it asks for your tech id which only a technician has......
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Surakusa (04-28-2016)
Old 04-28-2016, 06:15 PM   #18
Apeks
Drives: bananaphone
I've had no trouble with programming new remotes on the frs/brz with a pirated copy of techstream before, and I've done programmed new G keys with it as well. Unfortunately never had any luck with the twins.
Apeks is offline   Reply With Quote
The Following User Says Thank You to Apeks For This Useful Post:
Old 04-28-2016, 07:01 PM   #19
Surakusa
Mechanical Guru
Surakusa's Avatar
I wonder what makes them so different. Why are they different from say a camry, or a corolla?
Old 04-28-2016, 07:06 PM   #20
Apeks
Drives: bananaphone
Not too sure, From what one toyota technician told me he said that it was a denso ECU by subaru, but made to run on techstream. which confuses me considering that i'm able to program remotes.
Old 04-28-2016, 07:10 PM   #21
Surakusa
Mechanical Guru
Surakusa's Avatar
I had that suspicion... I wonder if BRZ owners have had better luck?
Old 04-28-2016, 07:31 PM   #22
Apeks
Drives: bananaphone
Nah I have a BRZ, I gave up and just used the Chip from the Valet key.
Old 04-28-2016, 07:34 PM   #23
Surakusa
Mechanical Guru
Surakusa's Avatar
Haha! that key is pretty worthless. perhaps I should do that. lol
The Following User Says Thank You to Surakusa For This Useful Post:
Apeks (04-28-2016)
g-chip, key, key fob, keys, programming
programming Key to transponder Decimus Southern California 1 03-21-2016 10:54 AM
Key FOB programming milkesfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 10-21-2015 04:56 PM
Key fob programming sambrz BRZ First-Gen (2012+) — General Topics 4 10-08-2015 11:08 AM
Guys i dont know if its clear coat chip or paint chip.. HELP BRZ_Kamil Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-19-2014 11:23 PM
