Old 04-23-2016, 02:13 AM   #1
FRSW12
Drives: FRS
High quality stem valve for Rays wheels?
Well, I purchased a set of Rays wheels used and they did not come with any OEM Rays stem valve. Is there any quality aftermarket/JDM stem valve that you guys would recommend? Not a huge fan of the regular rubber ones
FRSW12 is offline   Reply With Quote
Old 04-23-2016, 02:39 AM   #2
vc86
Drives: 2014 FRS
I have set of oem rays valve stem that i didnt use from my set of wheels.
I can sell them. pm me an offer
vc86 is offline   Reply With Quote
Old 04-23-2016, 10:56 PM   #3
PeterFRS
PeterFRS's Avatar
Drives: FRS
i guess if you really want rays,
my te37 came with rays valves but i ditched them to use my factory tpms valves..
just thought i'd throw it out there as an option
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 04-27-2016, 01:00 PM   #4
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I got some brand new from when I bought my wheels. PM me and make an offer. They are new in the package still.
gdrider77 is offline   Reply With Quote
Old 04-27-2016, 01:53 PM   #5
8R6
8R6's Avatar
Drives: FRS
depending on which wheel you have, chances are you can just use valve stems for an RPF1 fine
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
JazzleSAURUS (05-05-2016)
Old 05-05-2016, 03:29 PM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I run the Enkei valve stems in all my wheels.
They fit great in:
Enkei RCG4, 04 STi BBS, OEM 05 FXT wheels, 02 WRX BBS Prodrive Options, 2000 RS GC 5 spokes.
They tend to run around $40 a set, don't leak, and are available in black.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
8R6 (05-05-2016)
Leaking valve stem - Warranty? Eldari Issues | Warranty | Recalls / TSB 6 02-02-2016 07:15 PM
Works Valve Stem & RS-R Lug Nuts xDBOYx Wheels and Tires 7 11-29-2014 06:23 PM
Questions about Valve Stem Fitments Stayreal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2014 05:25 PM
Are your valve stem caps safe? qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-18-2013 02:32 AM
Can this valve stem be rebuilt? ayau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 12-24-2012 03:57 AM
