#855 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
I didnt see the voltage. My switch is temporarily mounted right behind the TSC buttons (where the Heated seat switch is on the LIMITED cars) and I didnt look down at all. But i was likely WOT for 6 secs on the way down before braking. Coming back it was likely 8 secs or more, i was at the top of 3rd gear before i had to scrub some speed off to make my first turn. Procede? Possibly. My first order of business at the moment is to install my JRZ coils. I just got them delivered after 4 months of waiting for JRZ to change the valving for me. So, I need to install them and let them settle and then get a proper race alignment. But i need to PM @Lord09 since i believe he has his for sale. I also just tuned my 16 Golf R, so I have been a little busy with side projects. The golf had some issues that i had to work out.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#856 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Sounds like fun. If I remember the aux charger that rob recommended was around 80 bucks and was an easy install.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#857 | |
CAR-AHOLIC
http://www.ft86club.com/forums/attac...1&d=1460991730 http://www.ft86club.com/forums/attac...1&d=1460991730 This is how i work on my cars.
#858 | |
Lol that first picture looks like it's floating.
#859 |
CAR-AHOLIC
Yeah, I'm a Jedi.
Anyways, yes i need to get an AUX charger and Procede. Both i can do in my garage so there is no excuse. Thank you for the education.
| The Following 2 Users Say Thank You to brzaapi For This Useful Post: | new2subaru (04-20-2016), Sojhinn (04-18-2016) |
#860 | |
Drives: White 2014 BRZ
I've pulled from 0-125mph (top of fifth before). That's what 20-25 seconds? Still around 21-22V.
JDL Turbo kit - Ecutek, HRI tuned.
#861 |
Drives: 2013 FRS
track day coming
I have a track day coming up in a month. This will be my first time at the track with the ESC. I have the most recent version of the ESC, a procede controller and plan to pick up an aux charger.
From my experience at this track, I expect I'll run out of boost with this system or trigger the thermal protection. So what then? Will it hurt anything to shut it off and stay out there unboosted? Am I OK to run on the same OFT tune with the system shut off or should I remove it and flash back to a Stage 2 tune? I don't want to damage the system. I bought the ESC primarily for street use, but I don't want it to be a liability at the track, and would be prepared to uninstall for a day if recommended.
#862 | |
Keep everything on... It will handle the thermal issues on its own. And run it like you want.
#863 | |
CAR-AHOLIC
I ran my car on the track with the system off for 1 session and with it on for 3 other sessions. It wont make any difference. Your OFT tune will run fine whether the ESC is on or off. In fact I still drive my car with the ESC off quite a bit. Once i taxed my ESC, it still worked fine....it just didnt produce quite the same level of power. But you could still feel it kicking in. If the ESC is turned off, technically it would cause a slight air restriction, but likely nothing that would be of consequence. When i had my first ESC on my other BRZ...I used to remove the ESC (motor/turbine only) assembly and reinstall my std inlet tube. Took 5 mins. This way i was legal for STX events. It didnt matter that i still had all the ESC bits still installed. So, to recap you should be fine to run however you wish. I bet you get power longer than i did. My batteries were brand new last week. And they were charging back up much faster these last two days, than they were during my track sessions.
#864 |
Drives: BRZ series blue
It doesn't run rich with the lack of extra air that the tune expects to see?
#865 | |
Not exactly. My MAF was off 10% with it installed when I did my street tuning on ecutek. Had to rescale. We specifically did WOT runs with it on and off to adjust. I wouldn't call it slight but still doubt anything bad would happen. Just more of an FYI.
| The Following User Says Thank You to stevo585 For This Useful Post: | brzaapi (04-21-2016) |
#866 |
Drives: 2013 FRS
Thanks all. Very much appreciate having the benefit of your experience. Will run it as is and see how it goes.
#867 | |
Yeah you should be fine as the thermal safe guards won't let anything bad happen. And since you are running a procede it will allow airflow as you open up throttle. Just don't worry about it and have fun!
#868 | |
CAR-AHOLIC
To be honest, if someone was still using the foot pedal switch, and I still am. Then i would leave the system on, but slightly move the switch back as to not engage the turbine. This way you still get the benefit of the partial turbine spin when it detects a vacuum, to assist airflow. But, the ESC still doesnt produce boost. Why do this? Well sometimes i like to keep my car pure NA and see what i can do. Besides, sometimes my fellow drivers will say " you beat me cause your boosted". Then I show them that i can still do it when i am NA. The ESC helps, but it doesnt give me a 5 sec faster lap time. But horsepower guys (i use to be one) are ignorant to such things. However, rdub-s....this does not apply to you since you are on the procede. We are all just sharing ideas here on the board, cause its fun to talk about our cars and our ESC toys. I am no expert at all. But you wont have any issues. The ESC is actually quite robust. Sohjinn is right, just run it. Everything else here is academic. Let us know how you do. I have another event this weekend. The wife and I are splitting time on the BRZ. So I will report back on how well my batteries have broken-in.
| The Following User Says Thank You to brzaapi For This Useful Post: | DC2R (04-29-2016) |
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 08:08 AM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
