#295 | |
Drives: 2013 Raven FR-S
#296 | |
Do you have an intake? At some points you get super rich that may just be overrun so it's ok , if you have an intake you should try scaling the maf. But I don't see many issues with knock like what shiv said to look out for, it looks safe to me
#297 | |
Only on other uels, some people are asking stupid questions like "WILL THIS WORK ON A STOCK HEADER CAR durrrrrrr"
#298 |
Drives: FT86
#299 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Going to flash this weekend and see how it goes...Using Tsudo UEL.
#300 |
Drives: 2014 WRB Subaru BRZ
K&N drop in filter. Going to do 3 gear pull and see how it does. Thanks for reply and saying that everything safe so far.
#301 |
Drives: FR-S 10 series
@B-R-Z running tsudo uel catless with invidia catless fp, mp, n1. Running fine 100miles in. No logs to post unfortunately. But def feels peppier on lower end.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
#302 |
Hey Steve, How come when I try to edit the new tunes in romraider I get an error that stuff is disabled was that done on purpose? I used the provided definitions too
#303 | |
#304 | |
Drives: FT86
you might have to up the user level in romraider if your getting the error from romraider when you open rom that romraider has disabled editing to table xxxxxxx then this is bad it means rom has tables that dont match, it possible if its B01C rom that its got flex patches in it what is exact error message |
#305 | |
#306 | |
Drives: FT86
eeek that mismatched rom and def, definitly do not edit. so you sure your using the new rom and new definition ?, make sure you delete any other definition pointers to other def in romraider, make sure their is only one definition in romraider. |
#307 | |
Drives: 2015 CWP BRZ Limited
#308 | ||
OK I fixed it, so I removed/uninstalled romraider then ONLY added the definitions for the new OFH tunes and did not add the ones for the normal ots stage 2 tunes and its fine now and perfectly editable.
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
