go_a_way1
Old 04-01-2016, 04:58 PM   #3053
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
17x9 +35
245/40 R17
1.2" Drop All Around
-1.5 Camber All Around
Stock Struts
Will this clear the front spring perch and not rub under hard cornering? Seems like I should be okay.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 04-09-2016, 08:06 PM   #3054
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by Phantobe View Post
17x9 +35
245/40 R17
Stock Struts
Should be okey. Worst case you have to change the camber a bit, but thats really just worst case.
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Phantobe (04-12-2016)
Old 04-10-2016, 12:16 AM   #3055
Alejandro45
Drives: FRS Scion 2016
Varrstoen Wheels
Varrstoen Wheels 18x9.5 offset 35 will clear on the rear of the FRS? will this fit with 225/40/18 tires with Eibach sportline drop 1.4 inch with stock struts ?
Please Help
Alejandro45 is offline   Reply With Quote
Old 04-10-2016, 01:37 AM   #3056
swarb
Originally Posted by Cubix View Post
Just wondering if Enkei 16x8 + 25 with the stock tires would fit at all. I'm thinking it'll be too much stretch (?). Also want to drop an inch on Eibach Pro-Kit.
Wat? Stock tires are 17's!
Old 04-13-2016, 12:48 AM   #3057
lupindub
Drives: Scion FR-S
This isn't necessarily a fitment question but I did not wan't to start a dedicated thread to this.
So if we had a 17x6 +48 offset wheel and a 17x9 +48 offset wheel and put a 38mm spacer in, in theory they would stick out of the car an equal amount since they are the same offset? Or am I understanding this wrong?
P.S - these are just random made up numbers and I am not actually going to replicate this setup.
lupindub is offline   Reply With Quote
Old 04-13-2016, 02:54 AM   #3058
swarb
Yes if you put the spacer on the 17x6.
http://www.frsproject.com/
The Following User Says Thank You to swarb For This Useful Post:
lupindub (04-13-2016)
Old 04-13-2016, 07:19 PM   #3059
lupindub
Drives: Scion FR-S
So the wheel I just bought unbeknownst to me came in with a wheel stud hole with a 1.5cm diameter... Stock lug nut on the car is 1.25cm. So pretty much I can or cannot put these wheel's on the car?
Old 04-13-2016, 07:29 PM   #3060
swarb
1.25 is the thread pitch. Not the width of the studs.
Sounds like you got the wrong bolt pattern.
Old 04-13-2016, 08:45 PM   #3061
lupindub
Drives: Scion FR-S
Okay I worded my last question incorrectly. So pretty much I am going to order some adapter's and when I am choosing the stud size, do I choose 12x1.25 or 12x1.5? I am going from 5x100 to 5x114.3
Old 04-13-2016, 09:27 PM   #3062
swarb
Doesn't matter. 12x1.25 is better so everything matches.
Old 04-14-2016, 05:53 PM   #3063
frs86rocketbunny
Drives: FRS
Cool Tiers and rims and offset
What wheels and off set and tires will fit Stock height FRS not really trying to go low any more since it's not my thing no more if any one can help thanks ?
frs86rocketbunny is offline   Reply With Quote
Old 04-14-2016, 06:20 PM   #3064
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
You can find the answer to this, and many other wheel related questions, here: http://www.ft86club.com/forums/showthread.php?t=7535
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-15-2016, 02:00 AM   #3065
Kendallkab
Drives: Black MT LMT BRZ
I might be pushing it a bit but could this work maybe?
18x9.5 +38 all around
5mm spacer for the rear ( going for a flush look )
245/40 for tires
According to the frsproject site this would work on a 1.4 in drop using coilovers unless I'm reading it wrong
Would I need to drop it less?
Could I drop it at all?
Kendallkab is offline   Reply With Quote
Old 04-15-2016, 02:21 AM   #3066
swarb
245/40 for tires
You are fine other than the tires are a little tall. Depending on camber, you might not even need the spacers.
Kendallkab (04-15-2016)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
