Old 04-10-2016, 06:31 PM   #1065
tha_alkaholiks
tha_alkaholiks's Avatar
Drives: DMG Subaru BRZ
either something really weird is going on or your backing off the throttle at at 4500 or so
hmm.... I think I was backing off the throttle, I'll try and get a better log when I get the chance.
tha_alkaholiks is offline   Reply With Quote
Old 04-10-2016, 11:42 PM   #1066
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by tha_alkaholiks View Post
No worries, did a WOT pull during the log, here: http://datazap.me/u/thaalkaholiks/ue...zoom=2631-2748
As I said, useless.
Old 04-11-2016, 03:39 AM   #1067
tha_alkaholiks
Originally Posted by Wayno View Post
As I said, useless.
Whoops, sorry, it was my first time logging
Hopefully these two are less useless:
http://datazap.me/u/thaalkaholiks/lo...zoom=5027-5121
http://datazap.me/u/thaalkaholiks/lo...zoom=1551-1650
Old 04-11-2016, 06:42 AM   #1068
steve99
Drives: FT86
Those loogs look pretty darn perfect, i gather they are wayno's tunes.
I think you owe him a beer or two
Old 04-11-2016, 07:07 AM   #1069
tha_alkaholiks
Thanks for having a look at them for me @steve99! Yes, wayne's tunes are terrific, definitely owe him a cold one.
Old 04-11-2016, 04:51 PM   #1070
D_Thissen
D_Thissen's Avatar
Heres a quick log. K&N Drop in, Borla UEL, Stock OP/FP and Q300. Shiv's OTS 93 Stage 2 tune running PC Ultra 94. I have around 75km on the tune and there appears to be some (-0.65FLKC) around 2700-3200 RPM, is that something I should be concerned about??
Cheers!
http://www.datazap.me/u/dthissen/bor...3?log=0&data=2
Last edited by D_Thissen; 04-11-2016 at 04:55 PM. Reason: Forgot to add the data log...
Old 04-11-2016, 05:50 PM   #1071
steve99
Drives: FT86
Cheers!
Any knock correction less than -1 is generally acceptable unless its occurring frequently enough and of long enough duration to drop the IAM below 1, which in your case its not.
just check you exhaust isn't hitting anywhere or any loose bolts/washers as this can be interpreted as knock by knock sensor.
if your ever concerned about that level of knock. plug your oft into a stock car on stock tune and check out the knock, you will be surprised.
example here from stock car in south aftrica
http://datazap.me/u/steve99/south-af...0-27-28&solo=2
Old 04-11-2016, 06:04 PM   #1072
D_Thissen
D_Thissen's Avatar
Thanks Steve. I'll check that out. Also the gas is a few months old (car was in storage) would that have any effect on knock?
Sent from my Nexus 6P using Tapatalk
Old 04-12-2016, 09:01 PM   #1073
HLHachiRoku
Drives: 2015 HL FR-S
So i changed fuel, as the costco stuff was sending my adv mul to sit at 0.63 and wasn't changing. =\ Seemed to lose power as well. I'm back to 0.93 but my flkc is all over + and - not above 1 or below 1 from the looks of it though which is good i was informed. This is getting frustrating. Using 91 grade cause its all we have here in az =\ Almost want to hit up e85.....
http://www.datazap.me/u/hlhachiroku/...0&data=1-12-13
HLHachiRoku is offline   Reply With Quote
Old 04-12-2016, 10:59 PM   #1074
steve99
Drives: FT86
looks like the costco fuel was rubbish, new stuff look much better, the positive flkc is the ecu returning timing normal if iam is less than 1 , looks like new fuel is fine and iam will likely return to 1 , just do a couple of light steady throttle runs from 2000 to 6000 in 2nd or third and it will get your iam back to 1, see flashing reset learning link below
HLHachiRoku (04-13-2016)
Old 04-13-2016, 02:46 PM   #1075
xero404
I just got a jrsc carb legal kit running on the carb legal tune. With Crawford BPBs the UEL headers on 91 with an exhaust i was trying to stay out of boost. Should make it to tuner tomorrow alright?
http://bit.ly/20C1w9x
xero404 is offline   Reply With Quote
Old 04-13-2016, 05:34 PM   #1076
churchx
churchx's Avatar
Drives: 2014 GT86
Carb certified tunes cannot be legally altered. You can replace them with some custom tunes maybe providing more gains, but that's that, it won't be carb legal anymore imho.
Old 04-13-2016, 06:27 PM   #1077
xero404
yep getting a custom tune. Tomei UELs were never carb legal to begin with.
Old 04-13-2016, 09:20 PM   #1078
HLHachiRoku
Thanks again Steve! So this morning it finally went back to 1.0! around 70-75F. Started driving home after work, hopped on the freeway, droped back down to this below. Costco is claimed to be top tier to... I don't get it, the quick trip I filled up at wasnt as I just saw but better gas.. Grrr lol give me my 93 back.
=\ intake temps are pretty high, its about 95F out. Could be the cause of the drop, but i dont see that much flkc. most is positive.. Drove around trying the reset trick again, 2nd gear 2-6k and then 3rd gear 2-6k, nothing... =( Atleast it isn't as low as the 0.69 I got with the costco gas XD. Still felt pretty peppy. haha Going to continue to monitor it throughout the week, could be some costco gas floating around in there still. I had maybe a gallon and 1/2 left when i filled up. Was almost going to flash the new stage2 ofh map, even tho i have a jdl uel. See if it might help any, heard its a great tune so far, lol.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
