#1 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Now that spring has sprung I am getting the car ready for this track season. Yesterday I installed my 17x9 wheels with fresh track rubber on them and went on my routine drive down the street to fill up with E85 and decided to hit the highway on my way home for a run around a tight on-ramp to get a feel for the grip from the new tires. The car ran fine and temps were good up until this point. I pulled 2nd gear hard and 3rd gear at par throttle before getting back into 5th for my cruise home about 3 exits down the highway. About 3 minutes later when I was about 1 mile from my exit I see the CEL trip and I look down to see my coolant temperature gauge pegged in the red. ![]() I get off the highway at my exit and limp the car home another half mile and immediately shut it down and found it spewing coolant out of the reservoir and the fans in high speed mode. It didn't take much diagnosis to see that it was the thermostat that had failed and stuck closed allowing no coolant to circulate. There was no milkshake in my coolant and the oil was clear and at the right level. Nothing else leaking from anywhere as the car continued to idle fine when I tested it after it cooled down. I realized that I was very lucky to not get stranded or have a catastrophic engine failure. ![]() Back on jackstands last night for emergency surgery, which happened today. My findings... ![]() OEM (88 C) thermostat on left, Mishimoto (76 C) on the right The pin at the bottom of the Mishimoto thermostat worked its way out of the assembly and as a result the thermostat was stuck closed and overheated the engine very quickly. I found that pin sitting in the bottom of the thermostat cover piece. I put the OEM thermostat back in, filled the system back up with coolant and bled it properly at both ends and thankfully after a test drive all is well. Crisis averted. My BRZ lives to see another day. I am posting this thread as a warning to other owners who may currently have or are considering purchasing this thermostat. I highly recommend leaving your OEM thermostat or swapping it back on. I will not be using the @Mishimoto lifetime warranty on this part. I have heard from several owners with these and different cars that failures with both the Mishimoto thermostats and the radiators (pinhole leaks) are common. Caveat emptor.
| The Following 14 Users Say Thank You to ATL BRZ For This Useful Post: | akyp (04-08-2016), Anthony (04-07-2016), BatStig (04-08-2016), Calum (04-08-2016), Clipdat (04-07-2016), D_Thissen (09-28-2016), go_a_way1 (04-07-2016), Jmonty (04-07-2016), JonAvalon (04-08-2016), kster1 (04-08-2016), Slysdexia (04-08-2016), Teseo (04-08-2016), Tye300 (04-08-2016), whataboutbob (04-11-2016) |
#2 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Such a tiny thing that could potentially cause such catastrophic problems.
#3 | |
Drives: TOYOTA
| The Following User Says Thank You to Ro_Ja For This Useful Post: | ATL BRZ (04-08-2016) |
#4 |
Drives: 2000 Toyota MR2 Spyder
Far from the first time I've heard of this failure. Their rad caps are not known for reliability either.
| The Following User Says Thank You to 2ZZW30 For This Useful Post: | ATL BRZ (04-08-2016) |
#5 |
Drives: '23 BRZ Limited
This is why none of the Miata track guys have bought Mishimoto for years.
The only people I see buying them on a regular basis are the cheap E30/E36 BMW guys. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | e1_griego (04-08-2016) |
#6 | |
Thupercharged
Radiator fans didn't mount to rad correctly either, the mounting brackets on the rad were not correctly welded/placed. Drain plug was plastic and never sealed correctly. They did honor the warranty, I just decided not to use it. That being said, I just purchased a mishimoto IC for my wrx and am pretty happy with it as far as fitment... but a leaky IC is a lot different than a failed thermostat or radiator
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#7 |
Drives: 15 BRZ LTD, 05 FXT
My Mishimoto radiator for my Forester XT failed and they were prompt about replacing it, but a welded aluminum radiator should not have pinhole leaks at all.
After 4 caps failed I put an OEM cap on and the problem was resolved. I won't buy their products in the future.
#8 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Well just to share another experience. I installed the thermostat on my 2nd BRZ in August 2014. It failed April 2015.
I have since stayed OEM on thermostats. Luckily the BRZ/FRS coolant system seems to run pretty good on its own. Oil, now thats another story.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
| The Following User Says Thank You to brzaapi For This Useful Post: | ATL BRZ (04-08-2016) |
#9 |
Update: Mishimoto have reached out to me with a sincere apology for my experience and I agreed to send the failed unit back to them for analysis with their engineering team.
I'm still not going to swap thermostats on this car ever again unless the OEM unit fails on me, which hopefully never happens.
#10 | |
Drives: 2013 Subaru BRZ
Again, we apologize for the inconvenience and poor experience. We will be reaching out shortly with further details regarding the acquisition of the failed component. Thanks -John |
#11 | |
Drives: whiteout FR-S
| The Following 2 Users Say Thank You to DrWill For This Useful Post: | nickmerronesucks (04-12-2016), zeal86 (04-11-2016) |
#12 |
Drives: Toyota 86 GTS
Truly professional would be to not make shit products worse than oem in the first place.
#13 | |
there is literally no company that manufactures parts of any sort that has not experienced a failure of some sort. it happens. its how the company deals with it when it happens that defines them |
#14 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
we had the exact same problem on our kraftwerks boosted project!
we installed the low temp mishimoto thermostat to gain some extra cooling, after only 3000km the thermostat failed like yours, leaving us with 2 blown headgaskets! we now also have back our original thermostat in it. after that issue happened i had a supra mishimoto thermostat on order for a 900hp project, when it arrived it wasn't flat on the mounting service, it was bend where they are pressed together. so we did not use it. don't think i will use them again, my confidence is gone after 2 parts gone wrong in one week.... if they want to rectify this problem, they can contact me direct for pictures, the GT86 project we had to pull the engine, replace gaskets and bolts, had to resurface the heads, .... because a stupid new "racing" thermostat failing!! $$$ very costly mishap. |
| The Following User Says Thank You to ST-A For This Useful Post: | Wayno (04-10-2016) |
| Tags |
| letbashmishimoto |
| F/S: Mishimoto racing thermostat | Trac Toy | Canada Classifieds | 0 | 03-13-2016 06:35 PM |
| Sandwich plate - oil temp reading "accuracy" | 1Cor10:23 | Engine, Exhaust, Transmission | 3 | 04-08-2015 01:36 AM |
| WARNING TO ALL BUYERS OF FT86CLUB: NEVER EVER SEND MONEY VIA PAYPAL "GIFT" FOR A PART | husker741 | Site Announcements / Questions / Issues | 5 | 04-23-2014 11:22 AM |
| Changing outside temp from "F" to "C" | Cyau | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 09-14-2013 09:28 PM |
| Product Release! Mishimoto Racing Thermostat for the FR-S/BRZ! | Mishimoto | Announcements, Contests, Giveaways | 1 | 08-23-2013 05:02 PM |
