Old 04-06-2016, 09:44 AM   #757
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I felt this same thing. It seemed to vary rather substantially based on weather.
I felt that way with the v1 but not later iterations or with the procede.
Also logging with an actual boost gauge shows me that things have remained consistent.
I think our butt dynos are not always as consistent as we think.
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (04-06-2016), raven1231 (04-06-2016), stevo585 (04-06-2016)
Old 04-06-2016, 01:59 PM   #758
WNDSRFR
Drives: FR-S,GTI
But you're in San Diego where it's always "relatively" cold. I lived there in the Navy so I know. Yeah, every now and then you'll have a Santa Ana but if you want to experience hellish heat and humidity, then come on down. Anytime between May and September will be fine.
There is a very large difference in power between say 50 degrees and 95. But the car still has a lot more power with the ESC than without.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Old 04-06-2016, 02:01 PM   #759
Sojhinn
Sojhinn's Avatar
Haha that's true.
Btw- I have some information regarding the big cranks. (Personal experiences) we might have some maintenance to do with them.
Will post later as soon as I'm done.
Installed Mods:
Old 04-06-2016, 08:17 PM   #760
stevo585
Drives: White 2014 BRZ
Originally Posted by brzaapi View Post
Well, if you are ready to move on to a conventional SC or Turbo setup...and you want to sell your ESC system. Let me know.
And, yes i am being serious. I would love to have a newer system on my BRZ, and let my buddy FI his Miata on my older ESC system.
I actually have a first year kit. It's used. Unlike most I run a custom Ecutek street tune with both 93 and 2x e85 maps saved in the ecu. Otherwise my setup is in my sig. I do have a stock catback and overpipe to keep it quiet. My tuner did recommend I get a catback but I doubt it will do much of anything noticeable.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
brzaapi (04-07-2016)
Old 04-06-2016, 08:20 PM   #761
stevo585
I do have a V1 but with latest and brand new big cranks. Only difference is the lighter compressor right? Is that worth upgrading too? You remember I did run a 13.8 @ 101 on e85. That was in 45-55F weather at night. Which if you do a et calculator using that trap and 2950 lbs. It says 234hp.
Old 04-06-2016, 10:40 PM   #762
Sojhinn
Sojhinn's Avatar
I wouldn't recommend the upgrade currently especially if you are using the big cranks. I would recommend the procede if you didn't snag that. I like the pre-spooling of the procede and how it can warm up the batteries for us.
I am currently trying to find out if we need to do maintenance on our batteries. I'm testing a few things still... I wanted to report some findings today but I have some inconclusive evidence. I'll try hopefully tomorrow.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
stevo585 (04-07-2016)
Old 04-07-2016, 02:33 AM   #763
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
I'm debating on getting the big crank batteries. what's the usual boost you get on your runs. I can't seem to get more that 3- 3.5psi max and i'm thinking it's the batteries. I have v1.5
shaynek is offline   Reply With Quote
Old 04-07-2016, 10:14 AM   #764
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Well, I may still be interested. I ran OFT on my last ESC BRZ. But currently I am also running Ecutek with DT flex fuel and ACE Header.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 04-07-2016, 01:40 PM   #765
fenton
I had a HUGE scare today. I was about 100 miles from home and noticed my car didn't have it's usual kick ass power. When I stepped on the gas the meter seemed to work properly. I just had no power. So I turned the ESC off and floored it. It felt about the same. So I floored it again and turned on the ESC with the petal still to the floor. No difference! OH CRAAAAP. So I turned it off and drove home thinking what a slug this car is without it.
Well, yesterday I just happened to disconnect the big power cable to check the voltage, so that's a good place to start. Checked that out. Nope everything's fine. So I turned on the ESC and the key and engaged the switch (no Procede) and listened. It sounded like the compressor was bound up. OH shit! So I'm thinking, maybe (hopefully) the air filter got sucked into it or something. Otherwise I'll have to go without the ESC for at least 2 weeks while it goes to fukn Canada and back. That's gonna suck BAD.
So before I pull the compressor off I figured I should check ALL the wiring. Checked the three cables going to the motor and ONE WAS DISCONNECTED. You would not believe how happy that made me to see that!
I reconnected it and taped the inline connectors together and went for a test drive. Unbelievable... It was like the very first time.
I love my ESC. I would get rid of the car if I couldn't have it.
Either that or get a turbo and blow it up!
Just as a FYI, you should never floor the car wtih the ESC off and then turn the ESC on while still WOT.
It is very very hard on the system and can damage the controller.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
WNDSRFR (04-07-2016)
Old 04-07-2016, 01:59 PM   #766
WNDSRFR
Drives: FR-S,GTI
Thanks for the info. I guess I was lucky one of the wires was disconnected.
I won't do it again.
Old 04-07-2016, 03:29 PM   #767
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Has anyone here compared driving the phantom to a Jackson,vortech, kraftwerks, etc.. ?
Your impressions ?
I tried to search for any comparisons - couldn't find it. I know someone somewhere has.
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 04-07-2016, 03:36 PM   #768
stevo585
Wow sounds low. Its always over 4 psi. My min-max was .28 to .33 bar (4.1-4.8 psi) according to ecutek logging the MAP sensor during the 2 hour street tuning. Otherwise I dont monitor boost I have no gauge yet.
Probably is your batteries, be my first guess anyways. Altitude has an effect too. I'm only 75 ft above sea level.
Old 04-07-2016, 03:39 PM   #769
stevo585
No.. its not for sale ...sorry maybe in a year. Not sure I want to put 5k+ into this car that ill never get back.
Old 04-07-2016, 03:42 PM   #770
stevo585
Your impressions ?
My guess would be the ESC would get the jump for a few seconds as the centrifugal gets to high rpm. Then just pulls away...
A positive placement would likely instantly just pull away from what I hear about the edelbrock/Harrop from my tuner.
He said during tuning that the ESC felt alot like a normal boost sprintex. Note he has tuned over 600 different twins.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
