Tracking / Autocross / HPDE / Drifting What these cars were built for! |
Platinum Member
Drives: Toyota 86 Vortech SC
OEM Crash Bolts, top and bottom
Anyone running OEM crash bolts top and bottom on the track?
I'd be interested to hear your observations and opinions. I've run crash bolts in top hole only (-1.3°) for 2 years (28 track days) but I'd like a bit more camber and I don't want to go the coilover route.
#2 |
Drives: Scion FRS
The OEM bottom bolt is the same as the crash bolt you put in the top.
#3 | |
Platinum Member
Thanks. So I guess that plan won't work... ![]()
#4 |
You could look into aftermarket tophats.
Are you still on stock struts and springs? |
#5 |
Drives: 2015 CWP BRZ Limited
Or just use aftermarket camber bolts in addition to the OEM crash bolts.
The Following User Says Thank You to jawn For This Useful Post: | funwheeldrive (04-04-2016) |
#6 |
Band
Drives: Asphalt FR-S
Yes, I'm running SPC bolts top and bottom with the Swift Spec-R springs, aligned to -2.5 degrees camber. It's probably not the best setup long term since the overall bolt diameter is lower than normal, but at least they are high grade bolts.
Since moving from just lower camber bolts to both upper and lower in october, I've only done 3 track days, 4 time attacks, and 2 autocrosses. One of the time attacks I went sideways into the curbing hard enough to fold in the rocker panel, and the bolts held up. |
The Following User Says Thank You to flais For This Useful Post: | DarkSunrise (04-01-2016) |
#7 | |
Drives: 10 Series Scion FR-S
The Following User Says Thank You to Cartman For This Useful Post: | flais (04-01-2016) |
#8 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I can also vouch for the SPC bolts on the bottom as well.
But Toyota does make OEM crash bolts in different sizes if you need it for legality/classes rules. The MR2 Slyder guys I have seen run multiple at times but cant give feedback on slipping (though I havent seen anyone complain). 12mm: 90105-14147 13mm: 90105-14146 Its wierd cuz the 14mm bolt is different part numbers for the FRS and the older cars but these bolts are generic across the Toyota line. Dont see why it wouldn't work but again all this is just searching google and the spyder forums so ymmv And actually curious why nobody tried this in CS lol. |
#9 |
C-Street AutoX
Rules are very clear, you can only use the Subaru part # nothing aftermarket/SPC
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
#10 | |
Or does it specifically have to be an option for that car? edit: nevermind. read the fule and it has to be factory way of adjustment so that would be car specific.
#12 |
Ex-MR2 owner
Drives: Scion FRS
I'm running the OEM crash bolts on top, SPC camber bolts on the bottom. I was able to get -2.1 of camber on stock suspension.
#13 |
Canada Eh!
Drives: '13 FRS
OEM 14mm crash bolts up top, SPC 14mm camber bolts in the bottom. Going in for alignment this weekend. Before (Stock Camber) on TRD Lowering Springs ![]() ![]() ![]() After (14mm OEM top, SPC bottom) still on TRD springs ![]() ![]() ![]() |
#14 |
Drives: 2016 White Pearl BRZ Premium
Have SPC bolts in the top holes up front, and got roughly -1.0 degree on each side. SPC 14mm camber bolts en route for the lower holes. Looking for that -2.5 deg sweet spot... Anyone think that will be doable with the SPC bolts in both holes?
Alignmemt w/ Crash Bolts. Thoughts? | EAGLE5 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-21-2014 02:06 PM |
Crash bolts alignment change | ABQautoxer | Tracking / Autocross / HPDE / Drifting | 39 | 03-24-2014 05:45 PM |
Cheapest Crash bolts | FReSh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 08-14-2013 11:12 AM |
FS: OEM Subaru crash bolts (2) | ayau | Brakes, Suspension, Chassis | 0 | 12-27-2012 11:29 PM |
Another crash bolts alignment thread | jeebus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 10-28-2012 12:29 AM |
