Old 03-28-2016, 06:36 AM   #15
jaime3
jaime3's Avatar
Drives: Scion FR-S
Hello!
Do you know if the Pulse module work as described in Si_Chris' post below? (Doesn't blink until off brakes for 8 seconds).
The pulse module we use blinks every time you use the brakes. It doesn't stay blinking. It only does it 5 times then stops. I haven't heard of one that you have to wait 8 seconds or so for it to blink again when pressing the brake. It could just possibly be a bad module but from what we use at work, it goes off every time
jaime3 is offline   Reply With Quote
Old 03-28-2016, 12:50 PM   #16
wwilder9
Drives: 2016 BRZ
This morning on the way to work, I pushed the brake and it would flash then go solid, If I hit the brakes right away after letting off them it would not flash, just stayed solid. If I waited a little longer it would flash again. I will have to time it to see how long before flashing again. I can also get some pictures of the module if people would like. It had some writing on it. Its only three wire hookup. Looks to be in series with the positive, and grounded to the negative. Looks to be a simple charge-discharge timer circuit.
wwilder9 is offline   Reply With Quote
Old 03-28-2016, 01:39 PM   #17
Agent 86
Drives: 2017 Cayman S
Kahtec http://www.kahtec.com/smart_stop.htm
I installed one of these on our BRZ and our Outback. On the Outback, the 3rd brake light blinks 5 times each time you apply the brakes. If you stay on the brake the light remains solid.
On the BRZ, the 3rd brake light blinks 5 times, remains solid, but will only blink again if 8 seconds elapse between brake application.
Because the BRZ is so low, I felt I needed something to alert distracted drivers. I also installed an Intec high mount 3rd brake light.
Kahtec offers several types of flashing modules. Installs in minutes and can easily be uninstalled.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
The Following User Says Thank You to Agent 86 For This Useful Post:
soulreapersteve (03-29-2016)
Old 03-28-2016, 01:49 PM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Which one did you get?:http://www.kahtec.com/US_Order_Form.htm
I'm very interested in buying one, I've been getting alot of people that ride right up onto the tailgate under light braking to a stop or won't see the car. I'm guessing you got the Blinking Smart Stop Delay?
Old 03-28-2016, 02:10 PM   #19
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Multiple cars are now coming with them form the factory. There is a bunch of peer reviewed academic literature on their effectiveness in reducing the number of rear end collisions. They are expected to be mandatory, just as daytime running lights are now mandatory, on all new vehicles. They need to pulse, not flash to be legal. So on/brighter/on, not on/off/on.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-28-2016, 05:21 PM   #20
Poodles
Drives: 2015 Series.Blue
The original intent was to have them flash at a rate that was based off how hard you were braking (I think F1 cars have this)
I have it in my Valenti 4th brake light. Haven't had many people come even close to hitting me because of it though.
Old 03-28-2016, 05:25 PM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Those are about as annoying as Harley rider's flashing headlights.
The Following User Says Thank You to Summerwolf For This Useful Post:
PERRIN_Chris (04-01-2016)
Old 03-28-2016, 06:32 PM   #22
tracerit
Drives: '13 SSM BRZ Limited 6MT
Installed a similar setup but with a cheap $50 mustang high mount light yesterday. [ame="https://www.youtube.com/watch?v=7QdpBxfboEk"]kahtec standard + mustang high mount brake light - YouTube[/ame]
I got the annoying one with no delay (so it always flashes six times then solid). Figured I coast most of my way in a low gear that I barely brake but I've seen too mnay people run up close to me a few times that this brake light was installed just for them
tracerit is offline   Reply With Quote
Old 03-28-2016, 07:25 PM   #23
ARTBRZ
Aloha!
ARTBRZ's Avatar
I need one of these. Maybe I can annoy those people who tailgate me. But I think I'll need the one that doesn't turn off.
ARTBRZ is offline   Reply With Quote
Old 03-29-2016, 07:19 AM   #24
Agent 86
On our BRZ we have the Blinking Smart Stop Delay.
On our Outback we have the Blinking Smart Stop Standard.
The Following 2 Users Say Thank You to Agent 86 For This Useful Post:
FRSBRZGT86FAN (03-29-2016), soulreapersteve (03-29-2016)
Old 03-29-2016, 07:39 AM   #25
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Thank you! The one that you have for the BRZ is what exactly I'm looking for.
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
Old 03-29-2016, 01:22 PM   #26
acetothermus
Drives: Flying in a Blue Dream
I've been noticing a worrying trend of people riding right up on my rear end when I'm stopping. I've been employing my own version of this...I just push and release the brake pedal a few times when I see someone obviously not slowing down. This might be a better solution.
Do you do any cutting of the wire harness?
acetothermus is offline   Reply With Quote
Old 03-29-2016, 03:52 PM   #27
FRSBRZGT86FAN
+1 Hows the install? Do you have to splice into the third brake light harness with like t tap connectors?
Old 03-29-2016, 07:48 PM   #28
Agent 86
Yes, although I wouldn't call it a harness. You must clip a single wire. Take a look at this link http://www.kahtec.com/install_smart_stop.htm . You'll find the instructions here.
I did not have to clip the OEM wires. Since I removed the OEM 3rd brake light, I just took the connector off that, and soldered the Kahtec module to that connector.
My experience with Shiv & his products at Open Flash Tablet / Open Flash Header TouchMyHonda User/Vendor/Sponsor Reviews, Feedback, Comments 5 10-23-2015 10:57 AM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
*Auto* Light from windows flash on driver's door Walla Walla Issues | Warranty | Recalls / TSB 7 12-05-2013 01:09 PM
Aftermarket Reverse light with triple flash on braking? Bonks86 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-19-2013 11:03 AM
