Old 03-26-2016, 12:41 PM   #1
OUGrad05
Drives: 2015 BMW 335i M Sport, 2004 Z06
Drain plug leaking...what to do...
Guys I finally found a car yesterday about 200 miles from my house. Went looked at it, took it for a quick test drive, everything check out great. Carfax/Autocheck look good. It was a long haul home and I noticed this morning pulling the car out a small puddle of oil under the car. At first I thought it was water or condensate from the AC.
Nope, definitely oil when I got out to look. So I put the car on stands and it appears to be coming from around the drain plug. So I'm not sure if it's been cross threaded or what? It was tight, I loosened and retightened myself (hand tight). I'm a bit annoyed because the dealership is 200 miles away, but overall it seems like a really good car. I am annoyed that after a day the drain plug seems to have an issue.
Is this common or is something else amiss??
OUGrad05 is offline   Reply With Quote
Old 03-26-2016, 01:03 PM   #2
OUGrad05
Originally Posted by MTpockets View Post
I would try a new Subaru drain plug gasket for ~$1.44
PN 803916010
I'm just going to run it over to the local toyota joint at 1:45 they'll do a change and my guess is replace the gasket as part of the change. I don't have time to go pickup gear/parts and do it myself today
Family coming in for Easter so I just need it done.
Old 03-26-2016, 02:50 PM   #3
Don't guess, specify and look for it on the invoice.
JohnJuan (03-28-2016)
Old 03-26-2016, 03:58 PM   #4
OUGrad05
Oh ya, and I told the service advisor specifically, fix the leak around the drain plug even if it requires a new plug, definitely replace the gasket. He said they do the gasket/washer every change. Should be good to go in a bit.
Old 03-27-2016, 01:40 AM   #5
Guys I finally found a car yesterday ............ I am annoyed that after a day the drain plug seems to have an issue.
CONGRATULATIONS on your purchase .........
A leaking drain plug isn't (or shouldn't be) a common issue.
Hopefully, a new gasket will fix er up.
Worst case, a new oil pan and new plug would be required.
Don't listen to those old coots that will talk about ..... re-tapping and installing a larger drain plug ........ or using plumbers tape ...... or sticking a corn cob in it .......
Old 03-27-2016, 02:30 AM   #6
apelpapa
apelpapa's Avatar
Drives: 2013 SPD Black FR-S
People at the dealership just love to over or under tighten the nut, they did it to me too. I didn't even bother using my last free oil change, trust them ~0%. But other than that congratulations! Im sure you will love the car, I do two years later, just boosted about a week ago and I love it even more!
apelpapa is offline   Reply With Quote
Old 03-27-2016, 11:08 AM   #7
OUGrad05
It was the gasket, all is good now
The Following User Says Thank You to OUGrad05 For This Useful Post:
MTpockets (03-27-2016)
Old 03-27-2016, 03:19 PM   #8
Yaaaaaa...............
Brings to mind the old proverb:
For want of a nail the shoe was lost.
For want of a shoe the horse was lost.
For want of a horse the rider was lost.
For want of a rider the message was lost.
For want of a message the battle was lost.
For want of a battle the kingdom was lost.
And all for the want of a horseshoe nail.
Guff (03-27-2016), MTpockets (03-27-2016)
Old 03-28-2016, 01:19 PM   #9
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
If you find its the plug, I suggest you get a fumoto drain valve. I have them in my daily and brz and its awesome.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz
Romanov is offline   Reply With Quote
Old 03-28-2016, 03:01 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Could also be double-stacked.
http://www.ft86club.com/forums/showthread.php?t=54142
Ultramaroon (03-28-2016)
Greddy Oil Drain Plug - Leaking Pokeguyjai Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 09-25-2016 05:16 PM
SOLD: Greddy Magnetic Oil Drain Plug (NJ) zc06_kisstherain Engine, Exhaust, Bolt-Ons 8 05-15-2016 10:07 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 02:07 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 07:20 PM
