#995 | |
| The Following User Says Thank You to phrosty For This Useful Post: | oldgunfan (03-18-2016) |
#996 | |
Drives: Toyota 86 GTS
You should have 1.1 @3800 in LL and probably around 68/69 @ 3.2V in MAF scale, depending on which one you're using. On your car it looks like MAF scale should be smooth but instead looks like you have a dip @ 3.2V. Did you try just Shiv's scale with LL of 1.1 @ 3800? It looks like you're using US.Lean and you need to change 3.2V to 68 to smooth it out. |
| The Following User Says Thank You to Wayno For This Useful Post: | oldgunfan (03-18-2016) |
#997 |
Drives: GT86
Hey guys,
could someone please explain me how to reduce/eliminate knock? I got some FBKC up to -1.41 on Wayno's stage1 98 v98 tune between 3200-3700@0.5-0.6 load. (Fuel is BP Ultimate Super, it is fine, when not the best available here, no e85 fuelstation available) So i decided to pull some timing out of Base Timing B like in the Knock Correction thread vom steve99. Like below: ![]() Now i got some FBKC spikes up to -2.09! and a couple of -1.41 again. Did i something wrong? Does the Base Ignition Timing need to be a "lower" or "higher" value? IAM is still at 1 all the time, but -2.09 is pretty huge.. You can see the FBKC below: http://datazap.me/u/rezi/170320161?l...zoom=1465-1695 http://datazap.me/u/rezi/170320165?l...zoom=2995-3941 http://datazap.me/u/rezi/170320163?l...4&zoom=90-1007 I really dont know what the heck is going on. Gonna "beat" the crap out of it. If it still persists i'm going to flash back
#998 |
Drives: FT86
make sure your on @Wayno s latest version of tune , you might have to make it run a bit richer in that area and see if that helps you may need to change the ol and cl fuel maps
#999 | |
If it doesn't drop IAM, then don't worry about it. You won't feel it at low load. If you really, really want to smooth out that area you can do this change attached. It's important not to pull timing from the adjacent high load columns where no knock is happening. If you do that you're just detuning your car for no reason. Better to pull from the adjacent low load column where the timing ramps right up. You shouldn't pull timing based solely on the base timing table. You should be looking at base timing + kca combined. If you did you'd see there's a mountain of adv in those cells @ 0.5.
| The Following User Says Thank You to Wayno For This Useful Post: | Rezi (03-17-2016) |
#1000 |
Drives: GT86
Thanks Wayno for you help!!
Only the changes in picture 1 on my current rom? Or do i use the last one where you changed the complete timing of the map? |
#1002 | |
The other 2 are total timing - 6. And if it still knocks there without dropping IAM, forget about it. |
#1003 | |
Drives: 2014 BRZ sterling silver
#1004 | |
There are no load limits OTS tunes worth copying. And copy LL from here. http://www.ft86club.com/forums/attac...6&d=1458280187 |
#1005 |
Drives: GT86
@Wayno @steve99 , thank you so much!!
The logs are looking really good! * one FLKC of -1.3 between 6000-6500rpm when doing 3rd gear wot pull from 2000-7000 *one FBKC of -1.41 when AC was on @3500-3600 The rest is looking really good. Absolute zero FLKC and very little -0.69FBKC. IAM was always at 1. LTFT are looking much much better. It is between +0.78% / -1.57% the most of the time. Idle @ -5.47% which is normal. And this is without MAF-scaling. Fuel used was 90% BP Ultimate 98. (got some litre of OMV MaxxMotion 100 in it, but i think it is better to log with the "lowest" fuel) WOT FLKC: http://datazap.me/u/rezi/190320164?log=0&data=1-10-11 FBKC w/ AC?: http://datazap.me/u/rezi/190320165?l...zoom=6477-6622 Rest: http://datazap.me/u/rezi/190320161?log=0&data=1-4-10-11 http://datazap.me/u/rezi/190320162?log=0&data=1-4-10-11 http://datazap.me/u/rezi/190320163?log=0&data=1-4-10-11 |
#1006 | |
#1007 |
The new US.Lean has 68 @ 3.2V
#1008 | |
| The Following User Says Thank You to Wayno For This Useful Post: | Rezi (03-18-2016) |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
