Old 06-14-2012, 12:11 PM   #15
Jayde
Jayde's Avatar
Originally Posted by ahausheer View Post
Keep in mind most belts that slip a little will make noise but this should not happen on a new car. Once the belt is heated up and or has dried any condensation on the pulleys the noise goes away. That pulley should not be moving like that at idle. Maybe at high load/rpm but at idle? Whats going to happen when you rev it hard, that thing is going to shake it self apart.
When it was chirping for me, it almost sounded as if it was coming from the injectors, not the belt.
I'm going to see if I can find any other engine videos to see if I can see that pulley moving.
Jayde is offline   Reply With Quote
Old 06-14-2012, 12:26 PM   #16
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Seemed like DI noise to me
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 06-14-2012, 02:15 PM   #17
fenton
After my commute to work today mine was making the chirping noise again.
Here is a quick video of it.
[ame="http://www.youtube.com/watch?v=bmooGfYQxms"]Scion frs idle noise - YouTube[/ame]
fenton is offline   Reply With Quote
Old 06-14-2012, 02:50 PM   #18
csaba
Drives: scion tc
I dont have the car but that thing is noisy
csaba is offline   Reply With Quote
Old 06-14-2012, 03:57 PM   #19
ahausheer
Re-member
Drives: Toyota camry
In both vids there is a lot of injector noise and I think some of the higher frequencies sound injector related but I also hear another high frequency that sounds off. I'm using ear bud headphones. I hear a high frequency noise that is at a faster tempo than the injectors, it also sounds slightly intermittent (it doesn't maintain exactly the same tempo, which injectors will).
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-14-2012, 04:22 PM   #20
Jayde
Jayde's Avatar
Well I just ran it for 15mins or so, and I didn't hear any chirping, but I noticed that if I let it idle for an extended period of time (say, 15secs+), when I give it gas the rpms will drop to 400-500 then go up. Seems to be an issue with the FR-S.
Old 06-14-2012, 07:03 PM   #21
Jayp
Drives: Scion FR-S
Mine makes that sound too, not all the time though. I too thought it was normal but I'm starting to think I should take it to the dealer too, to get it checked out.
Jayp is offline   Reply With Quote
Old 06-14-2012, 07:16 PM   #22
Jayde
Jayde's Avatar
Mine hasn't made it since the one time last night. A comment on the OP's video said he took it (FR-S) to a Toyota dealer and they said it was fine.
Old 06-14-2012, 07:24 PM   #23
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
louder exhaust will solve this problem
uspspro is offline   Reply With Quote
The Following 3 Users Say Thank You to uspspro For This Useful Post:
Jason@Nameless (06-15-2012), Neilus (06-27-2012), OrbitalEllipses (06-27-2012)
Old 06-14-2012, 08:29 PM   #24
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Agreed.
That being said, my car makes the same noise occasionally after being driven for a while. It is more frequent than the injectors (slight pulsing, sometimes just a constant high-pitched sound) and sounds very different than the clicking. I've owned two wrx's before, and while I will be the first to say that boxer engines are naturally noisy, this noise doesn't sound familiar. However, I haven't noticed any performance or idling issues.
enjoyminutemaid is offline   Reply With Quote
Old 06-15-2012, 03:16 PM   #25
Jayde
Jayde's Avatar
Here's a vid of mine doing it as well. It seems to be intermediate, since some times it'll do it, and other times it won't. Happened as I was getting back to work after going to the bank and getting lunch.
[ame="http://www.youtube.com/watch?v=UK_4uZz-oQo"]BRZ Chirping - YouTube[/ame]
You can also see the idler pulley moving back and forth in the vid too.
Old 06-15-2012, 03:49 PM   #26
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Originally Posted by Don@Accelerated View Post
I don't believe I hear a belt chirping. Not alteast in the video. All I can hear is the high pressure direct injection pump and nozzles.
-Don
I'm with Don. The tensioner pulley is on a spring loaded tensioner so seeing it move is probably not that big of a deal. Maybe compare it to another FA20 engine if you want some extra assurance. But the tick is most certainly DI pump and nozzles. Very typical of newer gas direct injection vehicles. Hell, the Kia Optima Turbo & Hyundai Sonata Turbo have a 2" thick high density foam inside the engine cover to quiet it down as much as possible, but it's still diesel-status.
The other thing that makes youtube sound diagnostics a bit tough is that most smart phones have extremely sensitive microphones for high frequency noises. So for one of us to compare what we hear on a car in person to your video is a tough comparison as well.
Jason Griffith
Engineering Director
Nameless Performance
Jason@Nameless is offline   Reply With Quote
Old 06-15-2012, 04:01 PM   #27
Jayde
Jayde's Avatar
You can hear the chirping sound in all the videos. It sounds like a cricket. It's higher pitched then the ticking from the injectors.
The Following User Says Thank You to Jayde For This Useful Post:
theneptune86 (03-04-2022)
Old 06-15-2012, 04:11 PM   #28
Jason@Nameless
Turn the A/C on and see if it stops? So hard to tell where its coming from but that higher pitched sound doesn't sound like belt squeal to me at all. Sounds like bearing noise.
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 04:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 11:16 AM
