Old 03-17-2016, 04:17 AM   #1
pxtang
pxtang's Avatar
Drives: White Limited BRZ
Help with Valenti alignment
Hi! I need a little help with the Valenti install, if I'm not posting on the right place then please guide me, I'm still a little new here.
So, through steps on the internet, I've managed to get my Valenti (orignal) installed. However, I feel like I'm not inserting them right, since there's a small gap on the far side and I can try to push it in a little from the outside.
This is what it looks like:
Have I done something wrong? How can I fix this?
Thanks!
pxtang is offline   Reply With Quote
Old 03-17-2016, 05:17 AM   #2
HachiRo
Drives: 2013 White-Out FRS
Will check mine tomorrow morning. There's nothing between the tails and the body of the car right?
Also, authentic Valenti? There are fake ones that look VERY very similar on eBay and other sites.
*Edit*
Looked through pics of my car and don't see a similar gap. Will confirm tomorrow morning.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 03-17-2016, 11:59 AM   #3
pxtang
pxtang's Avatar
*Edit*
Yeah, got it through a group buy here recently. No one else has reported the same problem. I have this on both sides of the car, not sure what I did wrong...
Nothing between either. Took the old lights out and put new ones in.
Old 03-17-2016, 12:33 PM   #4
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
Did you tighten the nuts down all the way?
thecarfilmer is offline   Reply With Quote
The Following User Says Thank You to thecarfilmer For This Useful Post:
pxtang (03-17-2016)
Old 03-17-2016, 01:46 PM   #5
pxtang
pxtang's Avatar
I'll try that again tonight - mine came with 8mm gaskets and they were already kinda pushing through, so I wasn't sure I'd already tightened enough. My left side has less of a gap and I think I tightened it more than the right, so you might be right. Thanks!
The Following User Says Thank You to pxtang For This Useful Post:
thecarfilmer (03-17-2016)
Old 03-17-2016, 01:54 PM   #6
thecarfilmer
IG: @nickwiththefrs
The same thing happened to me. I just had to tighten them down all the way and it worked.
pxtang (03-17-2016)
Old 03-17-2016, 03:25 PM   #7
pxtang
pxtang's Avatar
That's great to hear will definitely try tonight and get back with my results, thanks!
Old 03-17-2016, 03:32 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
just don't go too ham on those nuts/bolts
The Following User Says Thank You to continuecrushing For This Useful Post:
pxtang (03-17-2016)
Old 03-17-2016, 04:42 PM   #9
HachiRo
Yeah. Go bacon instead.
Kidding, but really, if worse comes to worse, remove the gasket?
If anything the gasket is to prevent water leak on older models (someone correct me if I'm wrong please), which can also be prevented using waterproof putty, which I used.
The Following User Says Thank You to HachiRo For This Useful Post:
pxtang (03-17-2016)
Old 03-17-2016, 04:50 PM   #10
continuecrushing
lol @HachiRo
Also, I know sometimes the lights/gaskets get bound up a bit, if you will, on the bolts, causing it to not seat as in its spot.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
HachiRo (03-17-2016), pxtang (03-17-2016)
Old 03-17-2016, 04:59 PM   #11
KDad2
KDad2's Avatar
Drives: 2013 Raven
Loosen all the nuts. Push in a little on the light until you get it seated properly. Then hand tighten the outside and then the inside nuts. The newer versions have a thicker gasket. Once you get it aligned, then go ahead and tighten in a diagonal pattern. I usually start with the outside bottom, then inside top, and so forth.
I had problems with the sections of the LED's stop working on the early production runs. So, I've re-installed them a number of times.
KDad2 is offline   Reply With Quote
The Following User Says Thank You to KDad2 For This Useful Post:
pxtang (03-17-2016)
Old 03-18-2016, 03:41 AM   #12
pxtang
pxtang's Avatar
Thank you to everyone who helped! It ended up being a problem with nuts not being tightened enough. The tip to push in and hand tighten first also really helped. Lights look great, no awkward big gap anymore!
thecarfilmer (03-18-2016)
Old 03-18-2016, 04:10 AM   #13
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Best way is push the tail light in with your hand and then screw in the nuts
KungFuWaffle is offline   Reply With Quote
The Following User Says Thank You to KungFuWaffle For This Useful Post:
pxtang (03-18-2016)
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 04:44 AM
WTT smoked valenti's for red valenti's Scuba86 Exterior Parts (Aero, Lighting, Etc.) 0 07-30-2015 11:26 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 07:51 PM
WTB: Smoked Valenti Tails. Smoked Valenti Reverse. Spec-D Headlights. Kephrii Want-To-Buy Requests 0 02-18-2015 02:42 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 10:53 PM
