Old 03-17-2016, 12:51 AM   #15
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by zeal86 View Post
Install the Beatrush front beam brace and polish the radiator and AC condenser lines/ends as well as powder coat the surrounding brackets to add some visuals to the opening.
Here mine...
Beautiful work Zeal! Any chance you could do me a huge favor and get 2 quick measurements?
The distance between those pins on the Beatrush bar and the depth from the driver side pin to where the Beatrush meets the frame?
I'm planning to fabricate my own and curious on material dimensions before pulling the car apart. Thanks!
Uplink is offline   Reply With Quote
Old 03-17-2016, 01:12 AM   #16
zeal86
zeal86's Avatar
Drives:
I'll try to get you those measurements soon... I've been really busy polishing aluminum lately... lol
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
Uplink (03-17-2016)
Old 03-17-2016, 01:13 AM   #17
Uplink
Uplink's Avatar
Originally Posted by olsonpg View Post
Here comes zeal with his car porn again. Always making my car jealous I'll have to delete my history.
Heres a cheaper alternative to the Beatrush crash bar that I just ordered.
http://www.enjukuracing.com/products...scion-frs.html
Plan on giving it a shot of red for some extra bumper opening sweg for anyone that cares to look.
That's actually a good deal compared to the Beatrush if it's going to be hidden and actually gives me great direction, thanks.
The only concern would be that you don't have mounting location for the plastic air dam below the snorkel. I forget the review (maybe Perrin?) but they said without that the air turbulence near the snorkel actually robbed performance from a NA twin.
The Following User Says Thank You to Uplink For This Useful Post:
olsonpg (03-17-2016)
Old 03-17-2016, 01:15 AM   #18
Uplink
Uplink's Avatar
Thank you, much appreciated!
And I just got a Dunkin Donuts visual of... 'Time to polish the aluminum...'
Old 03-17-2016, 01:52 AM   #19
Uplink
Uplink's Avatar
Found it... http://blog.perrinperformance.com/br...design-part-2/
"The next test was removing the plastic air diverter which rests between the fresh air scoop and the lower portion of the bumper. This part is installed to help block some of the air from blowing up and around the radiator. With the diverter removed, there was a nice steady noticeable amount of air flow coming from the scoop at 1.5MPH. This sounds like it would be a great way to make our intake system get a little more flow and cool air, or would it…
After testing this on the road, we found this was a really bad idea. The added pressure and airflow while driving at 45MPH or more would cause the car to run poorly and actually die if you push in the clutch! So the plastic diverter got re-installed and the PERRIN intake would be designed around utilizing this part."
Old 05-29-2016, 11:15 PM   #20
zeal86
zeal86's Avatar
Drives:
Originally Posted by danny_d19 View Post
So I like the look of some 86's without the front grill, but hate the look of the styrofoam painted or stock crash bar painted. So I'm wondering if anyone has any pictures of the front grill cut out below the solid section that covers the styrofoam/crash bar?
Poor photo shop example of my car to illustrate what I mean
Curious... what did you decide to do about your front grille?
Old 05-31-2016, 08:12 PM   #21
danny_d19
danny_d19's Avatar
Drives: Whiteout RBv1 FRS
Took it all out, just need to trim or paint the tabs
danny_d19 is offline   Reply With Quote
Old 05-31-2016, 09:11 PM   #22
stevemp5
Drives: scion fr-s
this one is the best I've seen! looks like a modified brz one or he just filled the holes with putty or something like that
stevemp5 is offline   Reply With Quote
Old 05-31-2016, 09:31 PM   #23
danny_d19
danny_d19's Avatar
That does look really clean!
Old 06-01-2016, 03:06 PM   #24
zeal86
zeal86's Avatar
Drives:
The 86 is looking sharp!
Btw, a Dremel will work just fine to grind down the tabs... what also works well and provides a lot of control and a clean cut are flush cutters.
I have used both methods...how much material I plan on eliminating determines my method. Dremeling is obviously better for grinding out a curve.
Old 06-01-2016, 03:07 PM   #25
zeal86
zeal86's Avatar
Drives:
The mod to the front beam brace is really well executed!
Old 06-28-2016, 11:34 AM   #26
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Any word on what was done here? I'm very interested in this smooth option
HuntingtonFRS is offline   Reply With Quote
Old 06-28-2016, 03:06 PM   #27
8R6
8R6's Avatar
Drives: FRS
thats the super street "ratchet bunny" frs. i doubt anyone from superstreet (namely the editor) is on this forum
8R6 is offline   Reply With Quote
Old 06-28-2016, 04:16 PM   #28
stevemp5
Drives: scion fr-s
I'm pretty sure that he cut the grill as in the photo and then sand it forms and use some filler for body, primer,paint ect ect. I'll try this technique when I will be on vacation. I'm pretty sure that's how he did
Is the FRS front grill removal? mit_peid DIY (Do-It-Yourself) Guides 23 02-27-2016 01:00 AM
front grill PipeLovoo Exterior Parts (Aero, Lighting, Etc.) 8 05-28-2014 11:11 AM
front grill PipeLovoo Cosmetic Modification (Interior/Exterior/Lighting) 1 05-21-2014 12:53 PM
BRZ Front Grill Photoshop mikeTee BRZ Photos, Videos, Wallpapers, Gallery Forum 16 11-16-2013 06:18 AM
Front bumper grill. |-Goku-| Issues | Warranty | Recalls / TSB 20 09-04-2012 08:42 PM
