MODERATOR-SAMA
Drives: Swagtron Scooter
Please post a reply in this topic if you have new information.
I need your help to complete the data in this list! Need to determine how much your car has lowered? Distance between hub center and top of fender opening Front is 14 7/16" and rear is 14 5/8" Need to convert the metric spring rate to standard? http://tinyurl.com/kg-to-lb Want to install your own coilovers or springs? Strut Replacement/Coil Spring Install DIY Need to determine your spring rates? ridetech.com/info/spring-rate-calculator Want more information on basic suspension tuning? http://www.rapid-racer.com/suspension-tuning.php Code:
SPRINGS Front/Rate Rear/Rate Part # MSRP
OEM Toyota 86 0.0"/2.3k 0.0"/3.3k TBD $---
OEM Toyota GT86 (EU)0.0"/2.3k 0.0"/3.3k TBD $---
OEM Scion FR-S M/T 0.0"/2.3k 0.0"/3.8k F:SU003-04144 $83.90
R:SU003-04147 $83.90
OEM Scion FR-S A/T 0.0"/2.3k 0.0"/3.8k F:SU003-04145 $83.90
OEM Subaru BRZ M/T 0.0"/2.7k 0.0"/3.5k F:20330CA010 $79.70
R:20380CA010 $79.70
OEM Subaru BRZ A/T 0.0"/2.7k 0.0"/3.5k F:20330CA020 $79.70
R:20380CA010 $79.70
Code:
SPRINGS Front/Rate Rear/Rate Part # MSRP Eibach Pro-Kit 1.0"/3.6k 1.0"/4.9k 8210.5.140 $359 Eibach Sportline 1.4"/3.8k 1.4"/5.3k 4.10582 $359 Espelir Active GT 0.5"/3.2k 0.5"/5.0k 4536190109385 $TBD Hotchkis Sport 1.0"/3.3k 1.0"/4.7K 19445 $221 Intrax --- --- --- $--- Mach V 0.7"/TBD 1.0"/TBD TBD $239 Race Comp Yellow 0.8"/4.5k 0.8"/4.5k RCE-BRZ $349 RS-R Down 0.5"/2.8k 0.5"/4.5k T065D $TBD RS-R S/Down 1.0"/3.2k 1.2"/4.5k T065S $TBD RS-R Ti2000 Down 0.5"/2.8k 0.5"/4.5k T065TD $TBD RS-R Ti2000 S/Down 1.0"/3.2k 1.2"/4.5k T065TS $TBD Swift Sport FRS 1.0"/3.0kg 1.0"/4.5kg 4T909 $399 Swift Sport BRZ 1.0"/3.8kg 1.0"/4.5kg 4F912 $399 STi Pink 0.6"/TBD 0.6"/TBD F:ST20330AS000 $210.97 R:ST20380AS000 Tein H-Tech *NOTE* 0.9"/2.9k 0.7"/4.8k SKSA0-G1B00 $TBD Tein S-Tech *NOTE* 1.2"/3.3k 1.0"/5.0k SKQ54-AUB00 $280 TRD (same set on CO)0.6"/3.5k 0.6"/5.8k MS260-18001 $548.00 Code:
COILOVERS Front/Rate Rear/Rate Part # MSRP_ AirREX Kit Basic 0.0-3.0"/-- 0.0-3.0"/-- S-JP09006 $3575 AirREX Kit Digital 0.0-3.0"/-- 0.0-3.0"/-- S-JP09006 $5155 Amuse Hi-Tech TBD-TBD/8K TBD-TBD/8K TBD $TBD$ Apex'i N1 +1.6-2.4"/10k +0.8-2.0"/8.0k 264CT090 $TBD$ Blitz Damper ZZR 0.0-2.0"/6.0k 0.0-2.0"/4.0k TBD $TBD$ BC Racing BR-Type TBD-TBD/TBD TBD-TBD/TBD TBD $TBD$ BuddyClub D1 Damper TBD/9k TBD/7k BC02-D112ZN6 $1549 **(solid upper mounts) BuddyClub RSpec Damper TBD/9k TBD/7k BC02-RSD12ZN6 $1799 **(pillow ball, w/ upper camber adjust.) Cusco Spec-A 0.2-1.4"/4.5k 0.4-2.0"/5.0k 96560JCB $1707 Cusco Zero-A +1.0-1.4"/5.0k +1.0-2.0"/5.0k 96560NCN $2374 Cusco Zero-A w/PB +1.0-1.4"/5.0k +1.0-2.0"/5.0k 96560NCP $2640 D2 Racing RS 0.5-3.5"/7.4k 0.5-3.0"/5.0k D-SC-06 $1525 DG-5 TBD-TBD/TBD TBD-TBD/TBD TBD $TBD$ Fortune Auto 500 TBD-TBD/6.0K TBD-TBD/7.0K TBD $1149 Fortune Auto 510 TBD-TBD/8.0K TBD-TBD/8.0K TBD $1499 Ground Control Kit 1.0-1.5"/6.7K 1.0-2.5"/7.7K TBD $TBD$ HKS Hipermax IV 0.0-2.8"/6.0k 0.0-3.0"/4.0k 80230-AT001 $2250 HKS Hipermax IV GT TBD/8.0k TDB/6.0k 80230-AT001V $2350 JRZ RS1 TBD-TBD/CSTM TBD-TBD/CSTM TBD $TBD$ KSport Kontrol Pro 0.5-3.5"/7.5k 0.5-3.0"/6.3k CSC080-KP $1600 KW Variant 3 0.8-2.0"/6.1k 0.8-2.0"/7.1k 35258004 $2299 ISC Basic C TBD/10k TBD/7k S018B-C $1150 **(Includes Solid Top Plates) ISC Basic S TBD/10k TBD/7k S018B-S $1150 **(Includes Solid Top Plates ISC N1 C TBD/10k TBD/7k S018-C $1250 **( Includes Front Camber Plates with pillow-ball upper mounts and thrust bearings.) ISC N1 S TBD/10k TBD/7k S018-S $1250 **( Includes Front Camber Plates with pillow-ball upper mounts and thrust bearings.) ISC C-R TBD/12k TBD/8k S018B-R $1150 **(Available with solid top plates with rubber bushings) ISC S-R TBD/12k TBD/8k S018-R $1250 **(Includes Solid Top plates with rubber bushings, Top Camber Plate with pillow-ball upper mounts, and Thrust bearings) KW Street TBD-TBD/CSTM TBD-TBD/CSTM TBD $TBD$ Megan Street TBD-TBD/8.0 TBD-TBD/6.0 MRCDKSFR12 $999 Megan Track TBD-TBD/10.0 TBD-TBD/8.0 MRCDKSFR12TS $999 Nitron NTR TBD-TBD/TBD TBD-TBD/TBD TBD $TBD$ Ohlins BTO +0.2-1.2"/9.0k +0.2-1.0"/7.0k TBD $3674.88 PRS Soft TBD-TBD/6.0K TBD-TBD/6.0K TBD $TBD$ PRS Medium TBD-TBD/8.0K TBD-TBD/8.0K TBD $TBD$ PRS Hard TBD-TBD/10.0K TBD-TBD/10.0K TBD $TBD$ RS*R iSport Soft +0.6-1.6"/5.0k +1.2-3.2"/6.0k SPIF065S $TBD$ RS*R iSport Std +0.6-1.6"/6.0k +1.2-3.2"/7.0k SPIT065M $$1799 RS*R iSport Hard +0.6-1.6"/7.0k +1.2-3.2"/8.0k SPIF065H $TBD$ Sachs (no model) TBD-TBD/TBD TBD-TBD/TBD TBD $TBD$ Stance (no model) TBD-TBD/TBD TBD-TBD/TBD TBD $TBD$ Standard ENR 0.0-3.0"/CSTM 0.0-2.8"/CSTM SC01I2 $4595 Standard R3 0.0-3.0"/TBD 0.0-2.8"/TBD SC01R3 $1795 Standard R7 0.0-3.0"/TBD 0.0-2.8"/TBD SC01D7 $2095 Standard R7-TA 0.0-3.0"/TBD 0.0-2.8"/TBD SC01T7 $2095 Suivax Standard TBD-TBD/7.0k TBD-TBD/5.0k TBD $TBD$ Suivax 86 Edition TBD-TBD/8.0k TBD-TBD/6.0k TBD $TBD$ Tanabe Sustec Pro Z40 1.8"/5.0k 1.8/5.0k TSE4166 $2,190.00 Tein M/Flex *NOTE* 0.2-1.8"/8.0k +0.2-2.8"/9.0k GSQ54-F1SS1 $TBD$ Tein Street *NOTE* TBD-TBD/TBD TBD-TBD/TBD TBA $TBD$ Tein T/Flex *NOTE* +0.1-2.2"/7.0k +0.1-2.5"/7.0k DSQ54-61SS1 $TBD$ TRD FRA Set 0.6"/3.5K 0.6"/5.8K MS260-18001 $3289 XYZ Super Sport TBD-TBD/TBD TBD-TBD/TBD TBD $TBD$ *K-Sport SCS080-KP (FR-S) and CSB200-KP (BRZ) are identical *AirREX S-JP09006 (FR-S), S-JP07010 (BRZ) and S-JP01027 (GT86) are identical .
![]() Last edited by WingsofWar; 04-01-2014 at 02:49 PM. |
| The Following 127 Users Say Thank You to WingsofWar For This Useful Post: | 200hp/tonne (05-29-2013), ahausheer (09-10-2012), ajay (09-12-2012), AJUSA.com (08-03-2012), akahenry (10-24-2013), Akai (09-10-2012), Allch Chcar (01-11-2014), Anthonytpt (02-07-2013), azian_advanced (08-19-2013), BatStig (06-14-2014), benjoke (06-18-2012), Bonburner (09-28-2016), Boxer 86 (09-10-2012), Bristecom (10-05-2012), brybot (08-19-2016), buzznasa (06-26-2013), Calum (01-19-2013), CaptainSlow (10-16-2012), Choco (01-21-2015), Christina_Marie (10-20-2012), chutrain (09-11-2012), CkOne (12-08-2018), Cotnoir (06-18-2012), cto424 (11-18-2012), cwpbrz-ji (11-28-2015), CxG (10-29-2015), D-VO (02-22-2013), danthedirt (10-23-2012), Darkparadox911 (07-23-2015), DetroitJake (07-30-2012), DieselDog (04-08-2015), diirk (09-21-2012), Drift-Office (06-27-2012), DriftEightSix (09-10-2012), driver01 (07-30-2012), EN2_Squirrel (09-21-2013), Enraged21 (04-10-2013), Ess Vee (06-14-2012), feldy (03-17-2014), fernan2 (10-04-2013), finch1750 (05-10-2013), flippy (04-17-2015), Fly Guy (06-15-2012), Frs x3 (10-31-2013), FRSapex (09-03-2013), ft86Fan (09-04-2012), ft_sjo (04-27-2013), FutureFT86 (10-29-2012), garf (04-17-2013), gonzo (10-23-2012), gtengr (11-30-2016), Guff (06-18-2012), Gyzm0 (01-26-2016), Hachiroku (06-14-2012), Hags86 (08-22-2013), hmong337 (08-25-2013), ill86 (06-24-2012), JACK 8URT0N (08-07-2013), JDM-dono (06-19-2012), jedichimp (09-10-2012), JMon85 (04-05-2018), Josue Cafe FR-S (08-12-2015), junior_reyez (03-06-2014), Kakawate (10-24-2013), Keenercarguy (10-20-2015), Khyron686 (03-02-2014), kwood9000 (09-08-2012), LivingLegend (06-26-2012), lucchesi423 (06-20-2012), lxs (03-30-2014), MALAJSTD (04-01-2017), manonastick (09-04-2013), MattR (06-14-2012), MaXimus (04-22-2014), mit_peid (05-17-2013), MJones_RB (04-30-2016), Mo7ammed (05-05-2013), MoarGeesPlease (09-11-2012), Mooseknuckle44 (03-31-2014), Moto-P (09-17-2013), Motopythons (06-17-2012), Mr. (06-17-2013), mugen79 (07-03-2013), nikitopo (10-18-2015), Obja (10-07-2012), Pin Flare (03-04-2013), Pooverdam (12-02-2014), RaceR (09-10-2012), raul (04-26-2013), Rulin (12-09-2014), RYU (09-10-2012), sal (09-10-2012), Scooby South (06-27-2012), SG-RS1 (09-01-2015), shawnperolis (04-21-2013), ShikoBariki (04-20-2013), ShoNUFF (01-12-2013), Sideways? (05-22-2014), Sigh-on-Rice (09-21-2012), Slartibartfast (12-14-2012), slim blanco (08-17-2014), Snoopyalien24 (09-10-2012), solidONE (04-12-2020), soonami77 (10-02-2013), sosick (05-11-2015), stockysnail (04-29-2013), Style (08-23-2012), Sugi (12-22-2014), Tad_07 (09-12-2012), thatweebaaron (08-27-2024), tnt (08-19-2012), TofuJoe (08-21-2016), Totality (07-05-2014), TouchMyHonda (03-24-2013), travelmonkey (06-19-2013), Tristor (02-28-2018), Turbowned (09-10-2012), unsurety (08-05-2014), usptwins (12-30-2012), Valentino (05-17-2015), VersionUp (06-22-2012), VIXEN (07-16-2013), whataboutbob (11-02-2012), wheelhaus (09-10-2012), WRB-DZA-BRZ (09-10-2012), zAnSh1n (09-10-2012), zoomzoomers (06-03-2013) |
#2 |
NW Region Moderator
Drives: FR-S No More
1st post handed over to WingsofWar because I don't have time to maintain this topic anymore.
| The Following User Says Thank You to DarrenDriven For This Useful Post: | CaptainSlow (10-16-2012) |
#3 |
NW Region Moderator
Intrax, Tokico and Suspension Techniques emailed, waiting for a response.
I called H&R and they have springs in R&D that should be available in two months.
#4 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
RaceComp Engineering "Yellow" springs will be a 20mm drop F/R with 250in/lb rates front and rear. They are due out in July. (which can't come fast enough, I want these springs!)
I believe they will be also releasing "Black" springs which will have milder drops and rates. But no info on those yet as far as I know. |
#5 |
Random Internet dad
Drives: 2013 FRS and 2010 Mini Cooper
You should add RS*R iSport coil overs. I went directly through RS*R.
The front +/- is 0/-40 The rear +/- is -5/-50 Max adjustable range is: F: +10/-40 R: +25/-80 Spring rates are: F: 6kg R: 7kg Item code from their site is: SPIF065MP Price SHIPPED to my door after assembly in Japan was $2600 |
#6 |
Random Internet dad
Tein already has the Flex and mono-flex listed. No dates yet though.
Cusco also has their coil overs, and I know a few vendors have them or can get them soon as well. |
#7 |
NW Region Moderator
Thanks Draco-REX, I added them to the list.
#8 |
Drives: 86 ZN6
jdm TRD springs 15mm drop priced around $500
wow that's only half an inch drop |
#9 |
NW Region Moderator
I was able to find the Flex info on Tein's site, but nothing about the Mono Flex. I am adding this stuff to the list right now...
#10 | |
NW Region Moderator
I wasn't able to find any information on these... only the TRD coilovers: http://www.trdparts.jp/english/86_pe...s_chassis.html Can you point me to the info on the springs?
#11 | |
Drives: 86 ZN6
i believe those are not coilovers, but rather a shock and spring combo set but not really sure you can purchase them as a set or separately |
#12 |
NW Region Moderator
Ahhh... it appears that the shocks are threaded-adjustable coilover type and the fine print indicates that they are shipped with the height at 15mm. That doesn't necessarily mean that the springs are a 15mm drop, right?
#13 | |
Drives: 86 ZN6
but i read somewhere that you can use the springs on the stock shocks. but you only get that 15mm drop. that's why they are selling the springs separately |
#14 |
NW Region Moderator
I'm gonna leave the TRD info as TBD until we actually get better info, but they are up on the list now.
| Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 03:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
| Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 12:52 PM |
