Old 03-04-2016, 05:58 PM   #15
swarb
Originally Posted by Chase1996 View Post
Why the camber bolts & what for?
I thought you were done?
Stock camber is not adjustable and is anywhere from 0-1 degree, most of the time very near 0.
For handling purposes in our sports car, camber is good. For a daily driver, 1.3-2.0 is a good starting point. Ideally you want more camber in the front than the rear. Your rear probably has 1.5 or so from lowering, while the front is less.
You should also get a side skirt to hide that scratch I see in your pic on the right side of the car. And a front lip to match.
Old 03-04-2016, 05:59 PM   #16
Chase1996
Drives: Scion FR-S Black
Originally Posted by Tectoniic View Post
Car looks great! The TS-10s have been my top prospect for a while and seeing them on your car has really cemented my decision.
You accidentally have a car in the background of the dog picture, just a heads up
I know...shes quite the jealous picture taker.
Chase1996 is offline   Reply With Quote
The Following User Says Thank You to Chase1996 For This Useful Post:
Tectoniic (03-04-2016)
Old 03-04-2016, 06:02 PM   #17
Chase1996
I meant major/unneeded mods & Why do I NEED that? I dont see why i need more camber. What will it do?
Old 03-04-2016, 06:18 PM   #18
swarb
You don't need it. But it is a sports car. Do you want sports car like handling? It does make a difference.
Smoke/semi smoked side markers would look really nice on your black car too.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Cole (03-04-2016), MisterSheep (03-04-2016)
Old 03-04-2016, 07:07 PM   #19
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Poor guy wanted to tell us he's basically done with his "build"... and we're being assholes and telling him to buy more parts the mod bug is addictive.
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
Celica00 (03-05-2016), TSC19 (03-05-2016)
Old 03-04-2016, 10:53 PM   #20
......and it's contagious ........
It's spread via the Internet!
Cole (03-04-2016)
Old 03-04-2016, 11:16 PM   #21
None of your mods are "major" and they are all "unneeded".
Swarb already clearly told you what it will do and why you should do it.
It is a relatively cheap and easy thing that will improve the car. Why only do part of the job and call it good enough when for a little more you can finish it and call it done right?
86kahl (03-05-2016), Cole (03-05-2016)
Old 03-05-2016, 01:57 AM   #22
@Chase1996 to add to what others have said, here is a link that kind of explains what aftermarket camber bolts do and why they are beneficial.
http://www.phasteksport.com/2013-FRS...mber-81305.htm
Basically, when you lowered the car, the camber will be off (because the OEM camber bolt is "fixed") therefore the suspension geometry will be "off".
The fix is to put a different bolt in there, so as the camber can be adjusted a bit.
You're almost "done" ...... a couple of bolts and an alignment and you're good to go .....
Tcoat (03-05-2016)
Old 03-05-2016, 02:40 AM   #23
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
need moar tint
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
Marco_86 (03-05-2016)
Old 03-05-2016, 03:04 AM   #24
TSC19
Takeshi
TSC19's Avatar
Drives: 2014 FRS Whiteout
You're not done.
"Be kind whenever possible. It is always possible." Dalai Lama
TSC19 is offline   Reply With Quote
Old 03-05-2016, 03:22 AM   #25
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Heh, like all has already said. You're never ever "finished" with a build.
10k+ now and I thought I was done for good after all the exterior tS parts... Now I'm going to have to do some more under the hood and then work my way inside the interior...
You're NEVER finished.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 03-05-2016, 07:04 PM   #26
Chase1996
So get front camber bolts? and set the camber to what on the front and back?
Old 03-05-2016, 07:45 PM   #27
Let's see how many times I can just use @swarb 's existing response to answer the questions.
This is two.
Cole (03-05-2016), humfrz (03-05-2016)
Old 03-05-2016, 09:22 PM   #28
DANG, @Chase1996 ... you're bout to push ol @Tcoat over the edge ...... and he just returned from R&R ....
This is a good review:
http://www.ft86club.com/forums/showthread.php?t=25001
For your DD, I'd suggest you just ask the alignment shop to put the front and rear within spec ..... maybe the camber a little on the negative side of the range.
So I just finished detailing my car... Phantobe Scion FR-S / Toyota 86 GT86 General Forum 43 01-09-2015 09:43 PM
WTB: OEM Tails Finished RED dizzario Want-To-Buy Requests 5 09-01-2014 05:01 AM
Finished My Stereo Install! michaelahess Electronics | Audio | NAV | Infotainment 14 08-02-2012 01:36 AM
just finished this photoshop dieselstation BRZ Photos, Videos, Wallpapers, Gallery Forum 19 03-30-2012 07:34 PM
