Old 03-03-2016, 04:10 AM   #1
hayden55
Drives: 2013 FRS
Contemplating LS swap, brakes to suit the package?
Going the l33 route.
Stock aluminum l33, meziere electric water pump, EPAS retained as well, 25% UDP, LS6 intake and cam, t56 magnum xl. Should be right at a conservative 400bhp around 6200ish rpm (350rwhp).
Now onto the brakes.
Been looking at ap racing standard 4/6 pot, radi-cal 4 pot, stoptech, wilwood. What would you say would be a good match for the car?
Aiming for purely function over anything and weight reduction would be a plus.
Price isn't really a factor.
hayden55 is offline   Reply With Quote
Old 03-03-2016, 10:25 AM   #2
Traktor
Drives: Subaru BRZ Limited
This says 'Essex Sprint Kit'.
Traktor is offline   Reply With Quote
The Following 2 Users Say Thank You to Traktor For This Useful Post:
CSG Mike (03-03-2016), wparsons (03-04-2016)
Old 03-03-2016, 11:22 AM   #3
Racecomp Engineering
What kind of tires do you plan on running?
Are you planning on lots of track days? What's your track experience like?
- Andrew
Old 03-03-2016, 12:17 PM   #4
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Checking out RR racing. They are vendors on this forum I just installed there brake kit and it was really easy and not terribly expensive. I think it was like 1800 shipped front and rear
Sent from my SAMSUNG-SM-G890A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 03-03-2016, 12:18 PM   #5
batlwagn
ALL THE MODS!!
Old 03-03-2016, 01:05 PM   #6
CSG Mike
CSG Mike's Avatar
If you're doing a no-expense-spared V8 swap, you should also give the brakes the same consideration.
Old 03-04-2016, 12:52 PM   #7
hayden55
Drives: 2013 FRS
Tire: 255/40/17 re-71r's. More of a track day toy and occasional daily driver.
What does everybody think of the Stillen AP brakes?
Supposedly they are touted for their forged rigid body, light weight, and high thermal capacity.
But, i've never seen anybody actually use them. Anybody know specific weight reduction for each kit?
How does everybody feel about just the front kit, versus kits that offer front and rear? Seems like the replacing the rears isn't absolutely necessary since majority of braking is done at the front of the car.
Also looking for a kit where i can just pull the pin and swap brake pads in and out easily.
Old 03-04-2016, 03:13 PM   #8
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Your best bet is our front Essex/AP Racing Endurance Competition BBK. We have plenty of customers running 350+RWHP on our smaller Sprint Kit (299mm disc), but the larger disc in the Endurance Kit is going to give you greater headroom for future modifications to the car. You'd be able to turbo the LS and still not have to worry about your brakes. Our Endurance kit uses a wicked 325x32mm, 72 vane AP Racing J Hook. That disc actually has the same mass as our larger 355x32mm discs, and packs the biggest punch you can cram into a small space. We have those 325mm discs and our CP8350 calipers on plenty of 500-600HP Corvettes, Evos, etc. without issues. It is an extremely stout setup. Below are a couple examples of very fast, heavier cars, with big, sticky tires winning with our CP8350 calipers and 325x32mm discs:
C5Z06 wins 12 events in one year
SCCA Regional Championship on C5Z06
E46 M3
Evo winning regional TT events
Winning NASA Super Touring Races in Evo
Track record on Evo with 497HP/471 torque
Again, all of the above are running our CP8350 and 325x32mm disc. You absolutely don't need anything larger or heavier than that.
A couple of the really killer features:
  • It's compact. Even though it has a huge amount of thermal mass, it is small in diameter and clears a ton of wheels.
  • The whole package is lightweight. Even though the disc is beefy, our Endurance Kit shaves 5 lbs. of unsprung weight off of both sides vs. the OEM brakes, saving 10 unsprung lbs. off the nose of the car.
  • It comes with a super trick caliper bracket that integrates a brake duct (see below). That will save you a good deal of money, and you'll know you have a properly designed duct solution that puts the air where it needs to be.
  • It uses 20mm thick pads, and can take a pad with a radial depth up to 50mm. That means the kit has a large pad volume to absorb heat and provide outstanding pad wear.
  • Our kits use one hex bolt for incredibly fast and easy pad changes.
The Stillen/AP Racing kits are nice, but they are very much a street-focused product. The calipers in the pic you posted weigh over 50% more than the CP8350 caliper we use, they have very limited racing pad options, aluminum pistons, dust boots, no AKB springs, etc. The discs are massive and heavy in that kit as well, and that whole kit is going to be heavier than OEM, and be tough to fit inside small, lightweight wheels.
The rear brakes typically aren't problematic on these cars, even with significant power upgrades, swaps, etc. Your far better off installing the best front BBK you can afford, which is what I believe we offer. Our front kit is designed to properly integrate with the OEM master cylinder and rear brakes, and will integrate seamlessly with ABS while maintaining proper brake bias/balance.
Check out our blog for owner reviews...many of the customer reviews on our Evo, STI, M3, and Corvette kits are in reference to a kit that contains the same CP8350 caliper and 325x32mm disc in our Endurance Kit. In terms of bang for the buck and future headroom, it will have you covered in spades. You mentioned pure function, and that's what our kits are all about. Our Essex Designed Competition Kits are designed with the sole purpose of helping you go faster, for longer, without issue, for less money in the long-run.
Here's our duct...all billet aluminum. It's a killer piece and a huge value to be included in the kit price.
We also offer excellent customer support, lots of spares on hand, and will jump through hoops to help you out if you need it. Thanks, and feel free to PM, email, or call me at any time.
Here's one of our customers with the Endurance Kit tearing up the Nurburgring
JRitt is offline   Reply With Quote
The Following 3 Users Say Thank You to JRitt For This Useful Post:
bfrank1972 (03-05-2016), Calum (03-04-2016), wparsons (03-04-2016)
Old 03-05-2016, 10:48 AM   #9
bfrank1972
Drives: 2013 FR-S Argento
Lol well sold, makes me want to buy them even though I don't need them! Drool...
Sent from my SM-N920V using Tapatalk
Old 03-07-2016, 03:42 PM   #10
hayden55
Drives: 2013 FRS
I agree^.
I'm definitely sold on the function, and size of these brakes. Looks like 12.8" x 1.25" rotors are a great package to work with. Still stock piling parts until i can line up a swap kit from a company still working on their kit, so i was wondering if you guys run any sales throughout the year? Not in a rush at the moment so i figured I'd ask.
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 02:37 AM
'07 Sti Brakes, experience with this swap? Subie_Nubie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-06-2015 07:29 AM
Contemplating new ARP studs ... anyone with bad experiences? donoman Tracking / Autocross / HPDE / Drifting 20 06-02-2015 12:50 PM
Contemplating buying used BRZ with tons of mods but is it worth it? Sebaru BRZ First-Gen (2012+) — General Topics 48 07-19-2013 11:25 AM
Contemplating Raven Purchase Please Advise steve87j Scion FR-S / Toyota 86 GT86 General Forum 27 11-29-2012 10:44 PM
