Old 02-29-2016, 01:09 AM   #15
Knshro13
Drives: 10 series FRS
Originally Posted by JoeC View Post
I actually wasn't planning on hood pins. So, is the reason because the latch mechanism will eventually fail on the carbon hood?
Your carbon hood CAN fly off. It gets torn off the skeleton by the wind. Hood pins should be a must when getting a carbon hood.
Knshro13 is offline   Reply With Quote
The Following User Says Thank You to Knshro13 For This Useful Post:
Drakiv (02-29-2016)
Old 02-29-2016, 01:22 AM   #16
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
Are you getting the roof replacement or just the cover? If you're getting the replacement I wouldn't worry too much about the roof.
Johnny. is offline   Reply With Quote
Old 02-29-2016, 01:25 AM   #17
ARTBRZ
Aloha!
ARTBRZ's Avatar
Originally Posted by FRSBRZGT86FAN View Post
Uh... no the dash cam is inside, carbon fiber outside camera if wired and hidden correctly won't even be a target and entering the vehicle for a thief is more of a risk.
Not that higher of a risk. If you have a carbon fiber hood and trunk I would break into your car, disable the alarm, pop your hood and trunk and use a power tool to unbolt. Be done in no time...hypothetically. Just for the hell of it, I'll take your camera too!
ARTBRZ is offline   Reply With Quote
The Following User Says Thank You to ARTBRZ For This Useful Post:
Cole (02-29-2016)
Old 02-29-2016, 03:56 AM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You literally are not going to be able to steal either the hood and trunk as someone else said without smashing a window or attempting to lockout slim jim the lock which regardless will set the alarm off on a BR-Z at least...
Old 02-29-2016, 01:45 PM   #19
zman
zman's Avatar
Drives: scion frs
Is special care required for cb parts ?
zman is offline   Reply With Quote
Old 02-29-2016, 03:06 PM   #20
JoeC
Drives: Subaru BRZ Limited
To prevent damage to the antenna, some people will mount it like this:
Otherwise, CBs are pretty rugged.
JoeC is offline   Reply With Quote
The Following 2 Users Say Thank You to JoeC For This Useful Post:
Cole (02-29-2016), Drakiv (03-01-2016)
Car Theft Concern kash BRZ First-Gen (2012+) — General Topics 63 06-16-2014 08:01 PM
Clutch Adjustment Concern ZackZ Scion FR-S / Toyota 86 GT86 General Forum 19 09-07-2013 06:01 PM
gearbox/shifting concern Kosmos Issues | Warranty | Recalls / TSB 9 05-10-2013 09:53 PM
height concern dtrop BRZ First-Gen (2012+) — General Topics 25 01-21-2013 07:14 PM
