Drives: 13' Scion FRS Track car
Water pressure warning light
Did anyone install a water pressure warning system in their car.
We all know that if you blow a hose or loose a radiator car, by the time the water temp rise to alarming level, your engine will be toast. I found this cheap water pressure warning light system $20 from longacre: http://www.longacreracing.com/produc...34&prodid=7416 I was wondering if anybody has something similar. I have a @Mishimoto radiator and their website documentation is pretty weak, I don't know if the 1/8 NPT plug would fit on there.
2013 Scion Frs Track Car - Sold.
#2 |
I've never had a modern car rupture a radiator or coolant hose, but generally the massive amount of white smoke, coolant smell, etc. are enough of a warning to make having a water pressure gauge kind of unnecessary.
#3 |
Drives: Sterling BRZ Ltd
That light would come on after a problem, sort of redundant at that point.
Your looking for a gauge to show when something maybe about to happen, problem is what pressure is that? burst pressure of the hose? radiator? connection some place? Better off just running quality stuff and keeping an eye on it.
#4 | |
[insert cool phrase here]
Drives: BRZ Premium
And guess what, even if your car over heats it will still be fine. Unless you keep running it for more than half a hour. Or you really want to blow it up.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#5 | |
The SquadWhisperer
Don't overheat your car. Coolant system pressure is not a concern you could have. TEMPERATURE on the other hand........ Yeah, you already have a gauge and a light for that.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#6 |
The water temp gauge is good enough.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#7 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Why the hell are you worried about overheating anyways. You can run a 30min track session no problem without over heating your coolant. Your oil temp is a bigger issue, just my $0.02 Canadian so it isn't worth all the much vs your American money
#8 |
Drives: 2015 BRZ
Water pressure sensors are common on Corvettes. They run a bit hotter, but the utility is still there. If you lose a water pump, it'll show up in a pressure warning before the temperatures spike. In theory it might detect cavitation at high RPM.
Uncommon but not a "foolish" sensor to have. |
| The Following User Says Thank You to GSpeed For This Useful Post: | philooo (03-03-2016) |
| Tire pressure warning!!! | ikkomaji22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 03-08-2014 10:59 PM |
| tire pressure warning light kinda wonky? | chickdigger802 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 10-27-2013 12:00 PM |
| Tire Pressure Warning | pinoyplaya | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 12-21-2012 10:55 PM |
| Tire pressure warning on | sa1126 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-27-2012 08:26 PM |
| phantom tire pressure warning | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 06-04-2012 09:04 AM |
