| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Will -1 camber get rid of this tire poke?
![]() I want the top of the tire to be flush, will -1 camber accomplish this? Thanks. Sent from my HTC One_M8 using Tapatalk |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
edit: read updated post, I would say 3-4 maybe to get where you need, but I am no expert on "hella-flush" hahaha |
#3 |
Drives: FRS
whats your wheel specs and tires? that "looks" like something similar to a 9" width with 245 tires, and on stock suspension...
| The Following User Says Thank You to 8R6 For This Useful Post: | clbembry (02-25-2016) |
#4 |
245 with 18x8.5 +30, anything I can do do the suspension to reduce poke? Doesn't need to be flush I just don't want to be kicking up rocks and ruining my paint/hitting people behind me.
#5 | |
#6 |
Not Bаnned Anymore
Just by eyeballing it I would guess -3 is were you should start
#7 |
/scion
Drives: '13 86 M/T
You will likely need more negative camber. Add camber, possibly lower it (if the height bothers you, aesthetically), add mud flaps.
"Practice makes better. Only Senna is perfect." - CSG Mike
| The Following User Says Thank You to LOLS2K For This Useful Post: | clbembry (02-25-2016) |
#8 |
#9 |
Drives: 2013 Firestorm FRS
lowering+camber is gonna be the best you can do
| The Following User Says Thank You to continuecrushing For This Useful Post: | clbembry (02-25-2016) |
#10 | |
Toe has more of an effect on tire wear. Just hit up the track/canyon to keep things even. |
| The Following User Says Thank You to continuecrushing For This Useful Post: | go_a_way1 (02-25-2016) |
#11 |
#12 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
I would say that approx -2 camber will help pull in the top as much as possible and still won't promote excessive shoulder wear. Once you pass 2 ish and don't flog the car at a track, you will start to notice the uneven wear on a McPherson type front suspension setup. I got 17x9 +35 and got neg 1.7 up front with a single set of camber bolts (with lowering springs) and it made it much better. I'm not as familiar with your wheel width and offset however...
#13 |
Panda Trueno
Drives: No twin now.
You would need to have different wheels / tires to run less camber and not poke.
#14 |
Shibby!
| The Following User Says Thank You to Toyarzee For This Useful Post: | go_a_way1 (02-25-2016) |
| Immobilizer - where is it? How can i poke at it? | im_topher | Engine, Exhaust, Transmission | 8 | 11-10-2015 01:29 PM |
| What can I do about poke? Don't know what I'm doing | rinnamon | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 04-05-2015 10:38 PM |
| Eibach Pro-Kit Camber adjustment & tire question | JMOrem | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 06-07-2014 04:02 PM |
| Poke's BRZ build | Pokeguyjai | Member's Car Journals | 5 | 03-15-2014 12:10 PM |
| Help with poke on rear | Ash.B | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 11-23-2013 08:19 AM |
