Old 02-02-2016, 10:27 AM   #2227
AJ124
Drives: 13' Toyota GT86
Hi guys/gals, I know this has probably been covered but I can't find a proper answer. Have tried searching a few times to no avail.
Does this head unit work with an iPhone (6s) for Bluetooth audio streaming and hands free calling?
Not too fussed about usb connection as I have a 12v charger already.
Thanks in advanced for any help.
AJ124 is offline   Reply With Quote
Old 02-02-2016, 10:49 AM   #2228
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I dont think Iphones and this unit have been getting along, but dont quote me on that
Old 02-11-2016, 08:47 AM   #2229
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Out of stock for months, did they discontinue it
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 02-12-2016, 07:20 PM   #2230
DC2R
Drives: 2014 Scion FR-S
Originally Posted by dinoniel View Post
On my BRZ Limited I was able to run the wire to the side of the light and have it sit flush without cutting/drilling, but my wire went to the left of the license plate light whereas yours is to the right. I'm not sure if maybe theres more space towards the left of the light, but your wire may just be too thick. It might be worth a shot to try.
Also in case you didn't know, you can run the wire from the trunk lining to the inside of the car through that rubber grommet on the left of your first picture.
this was installed on a rush for testing. I have wires running through that grommet from when I had backup tag lights.
Maybe in misunderstanding but aren't the two lights the same? Can't see you having better luck in the other side. This is a Siamese RCA so probably just too thick...
Sent from my SM-N920T using Tapatalk
DC2R is offline   Reply With Quote
Old 02-15-2016, 05:35 PM   #2231
dinoniel
Yea I think some of what I said wasn't clear my bad. Here's a pic of mine (sorry for quality, was in a rush).
But you can see the size of my wire and where it travels. I didn't have to cut or drill anything. I just popped the license plate light out, ran the wire and popped the light back in. Like I said it's possible your wire is too big and u may have to cut some of the plastic light housing or drill
dinoniel is offline   Reply With Quote
The Following User Says Thank You to dinoniel For This Useful Post:
DC2R (02-17-2016)
Old 02-17-2016, 01:25 PM   #2232
DC2R
Looks good. How did you mount? Tape? Any problem having it off to side rather than exact middle? I find having in center helps me center car in spot.
Old 02-18-2016, 02:11 AM   #2233
dinoniel
The camera came with 3M tape it's stuck on pretty good with that. Been through many car washes and heavy rain/snow without signs of coming loose. It's been over 2 years since the install.
I didn't have the option of mounting in the middle of the trunk since I have BRZ Limited which has the keyless trunk button in the middle.
DC2R (02-18-2016)
Old 02-20-2016, 05:18 AM   #2234
sNake89
Drives: 2012 GT86
Just bought one of these off someone 2nd hand, didn't get the wiring harness for toyota as they bought it for a nissan..
I'm not very familiar with wires,stereos and whatnot..
How do I go about getting the wiring harness for it? can I go to any audio store and ask them, or does it specifically have to be one for Cafi to match ?
sNake89 is offline   Reply With Quote
Old 03-30-2016, 02:02 AM   #2235
hthought
Drives: awesome
SWC Issue
Hi guys, I've never really connected SWC, but I am having a weird and really bad problem.
I was playing a bit with cafi and i opened up the SWC application at one point. It was showing that key #0 was always getting tapped and that was pointing to volume increase. All of a sudden, the unit volume was going up and i couldn't stop it !
I eventually switched the hotkey to volume down, but it always decreases my volume automatically even when on the home screen. Looks like it things that key 0 of SWC is always getting pressed for some reason.
The problem is that there's not an option not to bind that #0 key to anything. And so, I pretty much don't know how to fix that. I was looking of ways to disable SWC but can't see anything.
Did anybody else have that ? Doesn't get fixed on reboot. I'm really on the verge of factory resetting and hoping that would work
hthought is offline   Reply With Quote
Old 03-30-2016, 08:09 AM   #2236
DC2R
Had same problem twice. Factory reset was only solution.
Old 03-30-2016, 08:10 AM   #2237
DC2R
You should be able to buy a harness at the store. I bough mine on amazon.
Old 03-30-2016, 06:27 PM   #2238
Calum
That Guy
Drives: 2013 asphalt FRS MT
Yup, I also had this issue twice, except my volume went up to max, not down.
I ended up doing a factory reset, but I also found that a wire in my harness was connecting IIRC, the cars illumination wire to the Ca-fi's SWC wire. Removing that was the more permanent fix.
Old 03-30-2016, 06:51 PM   #2239
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Same here. Just removed the connection to the SWC and all was fixed.
Pwolf is offline   Reply With Quote
Old 03-30-2016, 09:40 PM   #2240
DC2R
Oh yeah I did that too lol. Chronic got me
Sent from my Nexus 6P using Tapatalk
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
