Old 01-02-2016, 12:55 AM   #2213
dinoniel
Originally Posted by DC2R View Post
Many thanks.
Anyone got a good setup using viper and subwoofer? For some reason xfhifi is the only viper working for me. Anemic when using sub out. Barely moves speaker. Regular speaker RCA out works.
Sent from my SM-N920T using Tapatalk
Don't quite have your setup since i have the OEM audio plus system. But what do you mean xhifi is the only one that works? Are you sure you're installing the right version because when you download you get 2 versions (2.3 and 4.x). I don't mean that as an insult to you btw, I mention it because I made the mistake myself. Make sure you're using the 4.x apk.
Also use covolvers. If you're not using covolvers you're not unlocking the potential of V4a IMO. The best I've found is here:
http://forum.xda-developers.com/show....php?t=2439254
fyi majority do not work for me. But BBE-2 is the best of the ones that work. Also towards the bottom of your v4a options there is an option for max output did you try turning that up? Hope some of this helps!
dinoniel is offline   Reply With Quote
The Following User Says Thank You to dinoniel For This Useful Post:
DC2R (01-09-2016)
Old 01-07-2016, 09:55 AM   #2214
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by 3ananaPie View Post
Just installed this today and having a bit of a problem. If I connect anything via USB it doesn't get picked up. And I can't seem to connect any phones via bluetooth as I get the message "No device connected. Device name: ERROR" Pair code:" despite the phone telling me they are both connected.
Anyone know how to get around this? Thanks!
USB in the car from factory or USB from headunit??
Bluetooth is odd with this thing. Works find on my Edge but any Iphone will not pair
Old 01-07-2016, 10:14 AM   #2215
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
No I'm using the USB cables connected to the back of the unit. If I go into the bluetooth menu it displays the error, whether I have a device "connected" or not.
hmm I am not too sure then. What does the error say?
Old 01-07-2016, 10:30 AM   #2216
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Pic is broken for me
Old 01-07-2016, 10:45 AM   #2217
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Now?
Yeah I can see it now. What OS are you on?? Mine looks way different
Old 01-07-2016, 11:00 AM   #2218
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
4.1 Android - Quite liked the previous Pioneer unit but figured I would try android. Well if it ain't broke... :/
I have to check what mine is now, yours looks much nicer haha! Sorry I have no insight for you on the bluetooth issue.
Old 01-09-2016, 06:54 PM   #2219
DC2R
Drives: 2014 Scion FR-S
I'm using the bottom one. Not many options in that version. To test amp/sub I hooked up RCA to my phone and it thumped clean and hard.
Removed it and having trouble adding back. Last it addled new what cpu and I just choose the last one.
DC2R is offline   Reply With Quote
Old 01-09-2016, 08:15 PM   #2220
dinoniel
I see, I am not using the Xhifi version because they no longer update it. When you go to the official site here:
http://vipersaudio.com/blog/?page_id=48
I use this one: FX version v2.3.4.0 (Android 2.3~5.0) and in there is a 2.3 and 4.x version. I installed the 4.x version. Works perfect
DC2R (01-09-2016)
Old 01-10-2016, 11:11 AM   #2221
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Has there been anyone on here that didn't have a SD card reader installed in their head unit? I've contacted cafi with no response. Also my C: drive says I have 5gb available but I can't even update any apps or download any. Please help someone!!!
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 01-10-2016, 11:27 AM   #2222
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I remember hearing about this a long time ago. Apparently an update fixed it and TBH I haven't even looked at my SD card slot haha
Old 01-10-2016, 11:28 AM   #2223
texasbound972
USMC
Yeah I went to put in my 64 GB micro SD and it fell through. I was pretty pissed. Even more so when the tuner I bought it from wouldn't warranty it.
Old 01-17-2016, 10:32 AM   #2224
Neil_turbo
Drives: GT86 trd
Hi All
i am just installing my dashlinq4 in the UK
I bought this second hand with the main plan to use the DEFI app linked to the advance series gauges - that and spotify!
The app works fine on my phone / tablet but struggling to get it to connect to the dashlinq..
connection from in the app seems to go ok, though it notes "connected to phone" though when i go into the bluetooth settings it is as a obd device and shows as disconnected
Am i missing something or am i looking at a need to root it? (hope not as havent got a clue on rooting!!!
Thanks
Neil
Neil_turbo is offline   Reply With Quote
Old 01-20-2016, 08:33 AM   #2225
DC2R
Finally got my camera connected. Couldn't find anywhere good to run the wire. I have 2 cameras but 1 would require i cut a hole in car to push through. I pulled the surround piece off and ran the cable for this one for now. Ran cable through the license plate light but it doesnt seat fully. Any ideas?
I had to remove my LED license plate bolts due to being to wide to fit through the camera mount points. I already had to drill out my license plate and frame lol.
I MAY just drill a hole and mount the other camera but not sure about having the camera set off to the side...
Old 01-22-2016, 09:38 PM   #2226
dinoniel
On my BRZ Limited I was able to run the wire to the side of the light and have it sit flush without cutting/drilling, but my wire went to the left of the license plate light whereas yours is to the right. I'm not sure if maybe theres more space towards the left of the light, but your wire may just be too thick. It might be worth a shot to try.
Also in case you didn't know, you can run the wire from the trunk lining to the inside of the car through that rubber grommet on the left of your first picture.
DC2R (02-12-2016)
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
